Question about Garden
Walker lawn mower wont go forward or reverse
I have a mcghs walker that wont go forward or reverse it slowly came to a stop and now wont move but the engine still goes and the blades still turn
  • 479 Answers
SOURCE: John Deere LT190 Lawn Tractor transmission problem
try to service the old transmisson it may work.but if that does not work just replace the transmisson.
purchasing a new hydrostatic transmission is much advisable as its definately the problem of hydrostatic transmission with out any doubt .but i hope servicing the old works.
Posted on Oct 01, 2008
SOURCE: Hydrostatic mower goes in reverse but not forward. Only 73 hrs on it!
On my hydrostatic there is an adjustment on the forward/back lever which can be made to run all reverse or all forward. Normal setting gives both of course. Look at that adjustment. Maybe something let go.
Posted on Oct 14, 2008
  • 52 Answers
SOURCE: craftsman 42" riding lawn mower blade free spinning but wont cut
It sounds to me that you need a new mower deck drive belt, or your blades need sharpening. If the blade edges are rounded, they won't cut butter... Also, when mower is off, check mower deck drive pulleys to make sure you don't have any that are locked up or are dragging. You can check this by pulling the belt away from pulley and spinning the pulley by hand. MOWER MUST BE OFF before attempting any of these checks. You would be surprised how many people would try this with the mower running.
Hope this helps
Posted on Mar 11, 2009
SOURCE: Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
Posted on May 15, 2009
wadembly
  • 513 Answers
SOURCE: Bolens clutch wont engage
check to see if there is something caught around the blades that won't allow to turn
Posted on Jun 27, 2010
Zero turn will not move forward reverse or turn
These units use Hydraulic pumps for motivation. If the unit stopped all at one time, I suspect a drive belt came off.
For both pumps to fail at the same time would be very odd. Check the v-belt driving the wheel pumps.
Apr 12, 2015 | Husqvarna Zero Turn Mower RZ4619
Cant get gear i to reverse on my Murry riding lawn mower
is your belt to tight? that will cause tention on the trans. and it wont go into reverse try it while its moving forward jerk it into reverse and see if it goes may be just hung between gears
Jun 29, 2013 | Mtd Garden
Blade engagement
PTO issue the blade should engage even if your not moving
Jun 21, 2013 | Cub Cadet 50 in. 23 HP Kawasaki Twin...
My Weedeater riding lawn mower will not move in forward or reverse after it has started
Check your drive belt that it has not slipped off.. also check your drive lever on the right side (speeds, neutral, and reverse). The mower uses this lever to angle the motor against the belt to move it..
It is most likely the belt or the angle misaligned if the engine is turning...
Apr 21, 2013 | Weed Eater Weedeater 26" Riding Mower
My 2001 chrysler neon wont reverse and sometimes wont go forward
I had this problem and it was the transmission was going bad. I am afraid you will need a transmission rebuild
Jun 12, 2017 | Chrysler Cars & Trucks
No reverse
adjust the rod there is ware in the linkage you need to adjust it back so it will move there is a rod that connects to the bottom of the handle
Aug 26, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
179 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
