Hard disk security primary master hitachi HTS543216L9S lock
What is the lock of primary master hitachi HTS543216L9S
  • 1684 Answers
SOURCE: acer 5315 recon harddisc security password required
Bad news, someone has set the hard drive security option. The hard drive is hardware locked and can't be unlocked without the password. Not even putting the hard drive in another machine will bypass the security. You can send the drive to hitachi repair in Dallas, Tx. for recovery but it is very pricey.
Posted on Jun 18, 2009
  • 34 Answers
SOURCE: primary hard disk drive 0 not found no bootable
Your hard disk is disconnected, or not configured correctly in the CMOS. Go to the BIOS and be sure that the computer recognizes the hard disk. If doesnt happens, check the connectors, and if it doesnt fix your problem, you need a new hard drive.
Posted on Jul 18, 2009
Turk_97
  • 131 Answers
SOURCE: I can not get passed a Master Lock on my computer.
This depends on if this was set in the cmos (which it sounds as it was). There are some of the newer cmos hd-locks that will NOT enable you to even format a drive with this lock enabled. Sometimes you have to use a method that will nuke the hardrive and everything on it. I used to use a program called "boot & nuke" You can find it for free on the net. dariks boot and nuke is freeware. Use this as a last resort tho. Good luck
Posted on Sep 24, 2009
rahimhd
  • 31 Answers
SOURCE: primary master hitachi hts543212l9alock
For HDD password, clearing CMOS will NOT reset the hdd password. This ata password is not stored inside CMOS.
This site can help you with your hdd password / bios password problem
http://bit.ly/a0n3IS
or
http://www.acersnoop.co.cc
Search around and you will see that this is the cheapest one!
Posted on Feb 23, 2010
sourabh_035
  • 45 Answers
SOURCE: My daughters laptop does not
you restart your laptop and go in to bios setup check the bios setting and hdd security setting in the bios if u cant found than press "F9" key in to bios and press "F10" from you key board and exit....
Posted on Dec 17, 2010
Aspire one laptop I turn acer on and screen shows Harddisk Primary Master ST9160310AS lock
All solutions point to having to contact the drive manufacturer or laptop manufacturer. There is good explanation in the Tom's Hardware thread at the end, about a 'master password' ...
4.June.2014
Hard disk security primary master lock
harddisk security primary master lock
Jun 04, 2015 | Acer Aspire One D150-1587 Netbook
MY QUESTION IS HOW DO I Disable the "SECURITY FREEZE LOCK" on my hitachi HTS54503289a300, 320 GB sata hard Drive? originally WAS INTALLED IN MY ACER TRAVELMATE LAPTOP NANUFACTURED IN 2012 BUT THE LAP
Maybe if you can format the disk-but you loose data, maybe there is a program that can do it, probably in linux, or bootable itself, maybe ask acer for master password or something, if you still own original laptop and it runs then try to remove disk encryption while the hdd is accessible with laptop (i think its in bios), otherwise the hdd may be unusable to prevent data theft. you can plug any sata hdd into any sata device if you can hook all the cables, no compatibility issues there. try googling and youtubing for more answers
Sep 14, 2014 | Computers & Internet
When I turn my computer (aspire one *acer*) on it shows up saying "Harddisk Security" -Primary Master Hitachi HTS543216L9ALock
The hard disk is locked. Since you weren't the one that activated the hdd password it means that the hdd is defective - you will have to replace it and reinstall using an external CD_ROM unit and the recovery disk that you must get from here
https://secure.tx.acer.com/RCDB/Main.aspx?brand=acer
Aug 19, 2011 | Computers & Internet
I have a aspire one Acer and when I turn it on it says in a blue box, Harddisk Security and under it says Primary Master Hitachi HTS543216L9SLock. What can I do to restore it?
The drive is locked by a BIOS level Hard drive password. You can either contact Acer about a master password or replace the HDD since the password data is stored on the drive itself
http://www.fixya.com/support/r3894261-remove_bios_or_hdd_password_from_acer
Aug 13, 2011 | Acer Computers & Internet
Cloned hard drive "C" (WD 40GB) to A Deskstar 8oGB using external enclosure. When I remove the old drive and install new drive and boot up I get Msg drive 0 not found retry or enter setup. If I enter setup...
there are few thing you ahve to keep in mind
there are two type of hard disk
1. IDE
2. SATA
As per your hdd capacity it should of IDE type.
Now there are two IDE slots on motherboard. One is Primary and other is Secondary
You can fix two hdd with one IDE Slot that mean you can fix up upto faour IDE hdd at a time
Now again there are Primary master and Primary Slave
and
Secondary Master and Secondary Slave
Now You have to examine what was the location of previous hdd
1 Primary Master
2 Primary Slave
3 Secondary Master
4 Secondary Slave.
Now you have to make a HDD master or Slave.
just in between data cable connector and power cable connector there is a jumper. that specify the master or slave. do reply me if it works well thanks
Oct 01, 2009 | Hitachi Deskstar 7K250 80GB...
Acer 5315 recon harddisc security password required
Jun 18, 2009 | Acer Aspire 5315 Notebook
HDS728080PLAT20
plz connect the another Hard disk to the primary drive and restart the PC.
Sep 14, 2007 | Hitachi Deskstar 7K80 Hard Disk 80GB,...
Computers & Internet Logo
134 people viewed this question
David Payne
David Payne
