Question about Sony BRAVIA KDL-52W3000 52 in. LCD Television
I have a Sony Kdl-52XBR KDL-52X3100 Bravia. I was watching it and suddenly with no warning I could not see the picture any more. A message saying "no channel available, please scan" appeared on the bo
I was watching it and suddenly with no warning I could not see the picture any more. A message saying "no channel available, please scan" appeared on the bottom of the screen. When I try to scan for digital channels it scans but when I try watching TV in digital form the screen is black and again, it says "no channel available, please scan". It works on analogue. Does any body know if there is some kind of setting that I might need to reset so the digital system on my TV starts working again. Thanks.
budmrtn
  • 11361 Answers
SOURCE: Sony Bravia KDL-V40XBR1, no picture
You either have failed 24vdc power supply section or failed backlight inverter board, check for 24vdc first, look for caps with leaking/bulging top.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Sony+BRAVIA+KDL+-V40XBR1+
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jun 13, 2010
ssemul
  • 202 Answers
SOURCE: I have a Sony Bravia
(1)Reset your tv from setup menu then auto tune analogu chanel.
(2)if still no sound then update your tv softwear from sony site.
(3)If still sound not then need to replaced main board problem.
Posted on Oct 20, 2010
BElectric
  • 1140 Answers
SOURCE: My Sony Bravia television froze
Your TV has a dual tuner - one for analogue and one for digital although they are contained on the same tuner board. It's possible that the digital tuner has failed, in which case the tuner board will most likely need to be replaced, but often this problem can be resolved with a "hard" reset. Turn the TV off and unplug it. Remove all the cables from the back, leave it for at least 5 minutes and then re-connect only the cable from the tuner source. i.e aerial/antenna. Make sure you are in Digital TV mode (DTV), then run the channel scan again.
If it works turn the TV off, re-connect all of your other devices and you should be able to resume using the TV as normal.
If this doesn't work, you may need to have the digital tuner replaced. The analogue and digital channel feeds are from the same source. As the analogue channels are working there is no obvious fault with the feed or cables.
Please try this first and then post back for further assistance if needed.
Regards,
BElectric
Posted on Dec 23, 2010
SOURCE: problems with sony bravia lcd
We had this trouble with our sony bravia, had to get a repair man in to look at it and the digital tuner within the tv went cost $180.00 to have a new digit tuner put in.
Posted on Jan 17, 2011
I have the same problem, the only solution I found so far is to disconnect the TV from the mains supply - not very comfortable. The problem seems to happen more and more frequently.
Posted on Mar 13, 2011
Please run channel auto scan
NO picture just error message "please run channel auto scan"
Feb 14, 2013 | Insignia 37" LCD Flat-Panel HDTV
On my Visio tv channel 3 all of a sudden doesn't
The DVD player should also have jacks for image and audio on the back that can be connected to the same type on the set presuming it has those.
Dec 05, 2012 | Televison & Video
Scan says all channels locked out
Please try this,
If the scanner's display locks up or does not work properly after you connect a power source, you might need to reset or initialize it. If you have problems with the scanner, first try to reset it to retain the memory. Warning: Initializing the scanner will clear all channel memories and reverts it the state it was in right out of the box.To Initialize the scanner, turn off the scanner then turn it back on. Press 0 when the welcome screen appears. 'Please select factory tests. Exit if no key is pressed' will briefly appear. Then quickly press 1. 'Initialization clear all memory Enter to confirm Clear to exit' will briefly appear. Quickly press ENT to initialize. 'Initializing, Please stand by' then appears. Do not turn off the scanner while it is initializing. The display should then show M000 on the top line and Bank 0 CH 00 when finished.
Hope that helps!!
Happy Scanning
Nov 22, 2012 | Radio Shack Pro-97 Handheld Scanner
How can i tune all my sky channels to my dvd/vcr combo box
Hi sounds like the remote may be in the wrong mode , you can scan channels into the sky box or the TV/combo.
Make sure you are scanning them into the box not the combo.
Jun 14, 2012 | Daewoo Televison & Video
Hi there. I'm getting a "Please run channel auto scan" message on my Insignia flat screen. Please advise.
I am assuming this is your first digital television. Unlike the old analog television digital televisions
must have the channels scanned into the set. This what you have to do.
> Connect the signal source to the back. Antenna/Cable/Satellite.
(You may have already done the above step.)
> Go into the menu for the signal input source and set it to what was set on the back of the set.
> Click on scan or channel or whatever it's called and wait for it to search for available channels.
> Save the channels found.
You may exit menu and watch television.
The owner's manual gives this and more information.
Feb 16, 2011 | Insignia LCDTV26 26 in. Television
Some HD channels won't work on new Samsung tv.
Some hd channels can only be viewed by watching thru a cable box. If you are using a cable box check with your cable provider to see what the issue is.
Dec 23, 2009 | Samsung LN52B550 52 in. LCD TV
Same thing... suddenly will not "allow" one channel to be seen
go to tv menu, do an "autoprogram" and it will select all available channels.
You can also do an add/remove channel and manually delete the channels you know you don't have.
You can also change your tv from air to CATV (cable) On cable tv you can still get all the air channels and Fox just the numbers will be different, but you may have a better signal
Jul 10, 2009 | Olevia LT42HVi 42 in. LCD Television
Black screen on digital channel on my vizio
I had the same problem. Check out my solution by viewing the subject titled Vizio 37L suddenly stopped getting all digital... Hope it helps!
Jun 20, 2009 | Vizio VX37L Television
I can't change channels,message on TV says,'' no input available''.
Have you tried reprogramming the Dish remote with the Sharp code? That might bring back the TV control. Another option is to use the TV's control panel menu button (if available), go to the setup choices and have the TV scan for channels while the Dish receiver is on. It will find channel 3 then, and probably nothing else, so the set will stay on that channel.
Mar 20, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Channel scanning
yes file for repair as everything you would have to do to fix this means opening it. and likely voiding the warranty.
Feb 19, 2008 | Samsung LNT3242H Television
Sony BRAVIA KDL-52W3000 52 in. LCD Television Logo
113 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
