Question about Watches
Mambo Men's Ranger Watch Stainless Steel.Cant figure out how to get the analog to work on this watch??
ItsRixTime
SOURCE: how do change a battery of a watch?
If you do not have the proper tools,(proper tools are recommended) and depending on the type of backing, this may help you :
  1. Locate a very small tab (or recessed area) on the edge of the back cover. This is the access point for removal.
  2. Get a kitchen knife with a rigid blade. It doesn't have to be razor sharp, it only needs to be inflexible. You can also use a small fine screwdriver.
  3. Very carefully slide the blade under the tiny metal protrusion on the back cover (or across the length of the recessed area, depending on which type of cover your watch has). Do not attempt to insert the point of the knife. Use the length of the blade.
  4. Get under the tab or recessed area and gently but firmly turn the blade upward, popping the cover off.
  5. Locate your battery(Small round disc type) remove and check the numbers on it. Go to most any local dept. stores (Wal Mart, Target, Radio Shack, etc.) and purchase same.
  6. Install battery with numbers up.
  7. Place cover over watch, and snap back into place.
Hope this helps. If not, please let me know and I will get back to you.
Posted on Feb 07, 2008
  • 17 Answers
SOURCE: I can't get the stainless steel back off my watch
Does it screw off or is it a pop off? If it is a screw off you need a jax tool and read the instructions. If it is a pop off you need a tool and find the indentation or tab to lift up on to pop off the back. I use a Testors razor knife because it is strong and thin but Always Use Eye Protection when doing this. Most folks do not undertake this. If you do remember you have to more often than not need a watch presser to press the back back on. You can find them on watchmaker supplie sites (or Ebay or similar shady places). This is a necessary item to have to do this and most people do not undertake this unless they plan on doing this often. Novices using a case press often includes shattering the crystal when they do not know what they are doing. It takes experience and research to do the most common watch repairs.
Posted on Nov 19, 2008
escapement
  • 2334 Answers
SOURCE: stainless steel band won't snap into my watch
Stainless steel bracelet ends (so called wings) must be curved flush to the watch case.
Another way is to use curved spring lugs (pins).
Posted on Dec 17, 2008
  • 51 Answers
SOURCE: Watch band sizing
OK, I make an attempt:
I saw on other pictures on the web that the links have small holes at the side. There should be some links with arrows r another marking. These are usually the links that can be removed to shorten the strap.
If there is a small arrow on the link, it means that you can push out the pin inside the hole in the direction of the arrow. Then the link can be detached.
You can push it out with a blunt sewing needle (break off the tip).
Remove links on both sides of the watch when resizing it.
Hope that helps.
Critter
Posted on Dec 27, 2008
  • 19 Answers
SOURCE: How do I remove watch band links from m Stainless
I've got a great article that helped me out with this same problem! I thought this article explained things pretty well. http://hubpages.com/hub/How-to-Size-a-Watch
Posted on May 24, 2010
How do i set the day ? Mine is stuck on sun.
I would try removing the battery for 10 minutes reinstall the battery if it doesn't help there's a problem with the circuitry.
Hope it helps thank you.
Jun 10, 2015 | Novelty 30M Waterproof Analog & Digital...
How to change a battery
If watch expensive, take it to Shop to get it changed , if watch waterproof, it needs to be changed at a shop, as when battery changed , shop checks that the watch is still 100% waterproof.
Mar 07, 2015 | Tw Steel Grandeur Diver chronograph Quartz...
Swiss Legend Chronograph Stainless Steel Case- how to change the battery
Take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving in doing it yours
Feb 24, 2010 | Swiss Legend Chronograph Stainless Steel...
I cant work my fossil FS4251 BLACK STAINLESS STEEL WATCH
You can obtain instructions for your watch by going to "fossil.com".
At the bottom of the page you will see "customer care", click on this and under product info you will see a section called "watch instructions". Click on this and you will see a list of diagrams and instructions.
Pick the one that looks like yours and download the instructions.
Jan 30, 2010 | Fossil Watch Style # FS4251 Watch for Men
Oakley crush 2.0 watch with broken rubber strap. Where do you get replacement part?
Did u manage to het one ? Because i have THE Same problem. Oakley cant help me
Jul 15, 2009 | Oakley Crush 2.0 Stainless Steel Case with...
Watches Logo
22 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
