Instruction Manual For nuova AS892C - Office Equipment & Supplies
My nuova Simonelli oscar doesn't heat
This is a good little machine. its basically a commercial machine shrunk down for home and is worth repairing even if you have to take it in. go to nuova simonelli usa website and download the parts manual and check the 009500014 thermal fuse and the 09500004 highlimit thermostat and see if one is gone or tripped. check the pressure stat, check if power to elements and if there is check to make sure the elements havnt failed from being heated with no water. like i said this machine is on par with a rancilio silvia so well worth repairing.
NUOVA SIMONELLI ESPRESSO MACHINES
Apr 08, 2014 | Nuova Simonelli Coffee Makers & Espresso...
Aurelia fuse replacement
go to nuova simonelli usa and download the parts manual and locate the fuse.
Apr 05, 2014 | Nuova Simonelli Coffee Makers & Espresso...
Nuova simonelli manual switch flashes
it means that no water is flowing on the flowmeters. need to check flowmeters if clogged
Jun 03, 2013 | Nuova Simonelli Coffee Makers & Espresso...
Nuova simonelli vip over pressure problem
Could be lack of water in the boiler, could be a faulty pressure stat or vent valve. Check the level probe first, then the vent valve and then the pressure stat. You can also use the manual fill to make sure water is getting to the boiler.
Jun 27, 2010 | Nuova Simonelli Microbar Espresso Machine
Instruction manual for nuova simonelli microbar expresso machine?
You can download the user manual in PDF format from the manufacturer's support website by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
May 13, 2010 | Nuova Simonelli Microbar Espresso Machine
Nuova MDX espresso grinder wiring help
Fixed it Myself
Red wire --> Cap1
White wire --> Cap2
Blue wire --> PWR Switch
Brown wire ---> Thermal Protection Switch
Nov 15, 2009 | Nuova Simonelli MDX Electric Grinder
OSCAR NUOVA SIMONELLI WONT" GO ABOVE 165F AT GROUPHEAD
Descale boiler and group then make sure steam gauge reads 1.2 bar. If not adjust p.stat.
Jun 08, 2007 | Nuova Simonelli Oscar Coffee Maker,...
288 people viewed this question
k24674
jasbo
jasbo
