Question about Husqvarna 155HP DualHydrostatic 42" Cut ZeroTurn Radius Mower
No drive husqvarna rider 155
No drive forward or reverse.
    Problem Solver:
  • 6 Answers
Can you push the mower by hand?
Posted on Nov 25, 2013
  • ShedThoughts Apr 10, 2014
    Have you checked the transmission drive belt
4 Suggested Answers
SOURCE: I have a Husqvarna Rider 155. Does the
Not an expert but have a rider 155. After looking at diagram on partstree.com, it does not appear to have a filter. Just a magnetic drain plug. This is the only site I have found for info and parts.
Posted on May 23, 2010
philwalker78
  • 608 Answers
SOURCE: I have a husqvarna rider
Hi, remove the battery and battery carrier, clean all grass and debris from the hydrostatic drive, cooling fins and fan. Your problem is most likely the hydrostatic drive over heating. Hope this helps, regards Phil.
Posted on Jul 04, 2011
  • 63 Answers
SOURCE: Husqvarna Riding mower wont reverse gth2350 riding mower
I think theres 2 flow paths forward and reverse try checking the fluid level you may have to lower the rear end out of the machine or most all ridders ive seen allow you to take the backing plate off and then block the rear tires off the ground the fluid level should be about and inch from the top of the threads... if yours has a resivor off to the side with a breather fill it to the bottom of the threads... now that the fluid is full and up on blocks or jack stands start the engine and at an idle put it all the way forward to flush the bubles out this has to be done in small chunks 5 minutes forward and then laiter go 10 back let sit for 20 minutes in between and check the fluid level a couple of times to see if it whent down from this... best of luck hope this helped
Posted on Oct 05, 2012
The bike will go in reverse but won't go forward. how do I fix this?
Lil' Rider FX 3 Wheel Battery Powered Bike, Black - Amazon ...
www.amazon.com/Lil-Rider-Wheel-Battery-Powered/...
Amazon.com, Inc.Amazon.com: Lil' Rider FX 3 Wheel Battery Powered Bike, Black: Toys & Games. ...On Motorcycle 6V Toy Battery Powered Electric 3 Wheel Power Bicyle, Red ... VTechGo! ... sound effects, working chrome colored headlight, and forward and reverse ...power wheels vehicle more to handle size, weight, and your child won't ...
Lil' Rider FX 3 Wheel Battery Powered Bike, Blue - Amazon ...
Amazon.com, Inc.Amazon.com: Lil' Rider FX 3 Wheel Battery Powered Bike, Blue: Toys & Games. ...Sold by: Global Supplies (We currently can't ship to, HI, AK,APO,FPO, POB) .... Ride On Motorcycle 6V Toy Battery Powered Electric 3 Wheel Power Bicyle, Red ... sound effects, working chrome colored headlight, and forward and reverse ...
KB901 Lil' Rider FX 3 Wheel Battery Powered Bike ...
? 8:05
https://www.youtube.com/watch?v=fED8N8DTQfU
Oct 21, 2013 - Uploaded by TMKGL
Jan 07, 2016 | Lil' Rider FX 3-wheel Battery Powered Bike...
How do you replace a brake cable on a Husqvarna rider 155
There is 8 versions of this mower out there and there are two versions of this cable. You may simply look-up the wrong version. If your mower serial label has a product number look it by that number; otherwise, give cable 576712101 which superseded 535489601 a try.
Oct 29, 2014 | Husqvarna Garden
My Lt155 ride on wont engage in forward or reverse
(Simple answer)Hydrostatic drive machines have a setting that allows you to push them. machine won`t move if this is engaged.
Also If park brake is on. Otherwise check drive belt has not snapped is loose or broken. Jack machine up and see if wheels will drive without weight of machine.
Jul 26, 2014 | John Deere Garden
My Husqvarna Rider 16c wont reverse - first it was slow in reverse then not at all
You need to check the cable, it is a push pull telescopic style so it is possible to get forward and no reverse, if it was a hydro problem you would not get forward or reverse, there is also timing gears on the forward and reverse pedal, you nee to make sure they have not jumped a tooth as this would reduce movement on the cable at the hydro
Feb 12, 2013 | Husqvarna Garden
I have a husqvarna rider 155, the transmission loses power after I have ben mowing for an hour
Jul 04, 2011 | Husqvarna Garden
I have a Husqvarna Rider 155. Does the transmission oil ever need to be replaced? Is there a filter ? If so how do I change it? Where can I get a SERVICE manual?
Apr 21, 2010 | Husqvarna Garden
Husqvarna rider 155 won't start
I took a wire and jumpered all of the switches until I found the one that would let the mower start. The switch was still good, but vibration or whatever had moved the plug just enough to lose contact. Plugged it on more firmlly - problelm solved. Thanks.
Nov 25, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
try checking the ignition switch for any damage and replace if necessary
Nov 25, 2008 | Garden
Husqvarna 155HP DualHydrostatic 42" Cut ZeroTurn Radius Mower Logo
147 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
