Westpointe infrared heater model WI-0035 not working
Display panel lights up, but no heat or fan
4 Suggested Answers
SOURCE: Comfortzone heater displaying error message doFL.
According to the call line, hold down the up, down and enter buttons all at the same time and it should clear it. I took mine back and had it replaced so I never had a chance to try this.
Posted on Nov 19, 2010
  • 5370 Answers
SOURCE: which wires are together on thermostat for fasco
Yellow wire is light. Blue is vent. Red is heat element and fan after going through a circuit breaker and thermostat. Brown is night light. White is common to ventilator housing. Black is power to switch cluster. ---------- this will help.thanks.Helpmech.
Posted on Dec 17, 2010
Heat pure 1500 shuts down and displays 90.
over heating its self, it could be a blocked and not getting the right air flow or the sensor for the heat control is on its way out. check the filter if this model has one remove all dust from the intake, check that the fan is working, if the motor has been making any buzzing or funny sounds this can be the problem too. buzzing is the starter motor humming or clicking the motor is failing.
Mar 23, 2014 | Advanced Tech Infrared Heat Pure 1500 -...
West point infrared heater makes a loud buzzing sound when truned on
What does this have to do with PC laptops ??? Please post in correct category.
Dec 18, 2013 | Computers & Internet
MY DURAFLAME HEATER COMES ON BUT ONLY BLOWING OUT COLD AIR?
Sounds like something in the control module. I have 2. One bought used about a year old. Lasted about 3 months and something in the control module or panel died so would not light or power up. I hard wired the blower and Infrared bulbs to manual switches so I can manually turn on and off heat. Have separate switches so can leave the fan blowing after turning off the elements to allow them to cool. The other heater was bought new and laster about a year and a half. Then the thermostat reading worked and fan worked cycling as should but elements would not light. Did a factory reset holding power button while plugging in. That fixed it for a day then back to same. took back off and while trying to trouble shoot voltages on the power supply module the elements started working again. Not sure what the issue but seems to be a definite issue with short lived control modules. To date have not found a resource to buy new control boards or other replacement parts besides bulbs which with the fans seem to be the most durable part of the whole heater.
Feb 20, 2013 | Duraflame Heating & Cooling
Westpoint microwave oven when it is switched on the power trips off
see this cause and fix it: Otherwise you must call a profesional repairman. You must act with carefully. God bless you
All microwaves have some sort of a cooling fan to help keep the magnetron and controls at a tolerable level. Most OTR models will usually use the vent motor for the cooling fan also. Countertop units have a small fan behind the control panel somewhere. Either way, if the cooling fan is not working and heat builds up, it is going to open a thermostat. On some makes, this thermostat might re-set itself as soon as the temperature cools down. Other makes, you will have to replace the thermostat or fuse.
If this is your microwave oven repair problem, you will need to check the operation of the fan. Below in the component testing chart, you will see how to test the fan. Also, if possible, make sure the fan is not obstructed somehow and not turning. Also check your fan relay at your control board for voltage, if no voltage, replace control board. This fan should come on at the same time any cooking starts.
Sep 16, 2012 | Westpoint Microwave Ovens
Westpointe infrared heater shut off
The tilt switches normally go bad in these. It's a square black switch with a round bulb looking unit on top, wired near the power switch. The lower wiring pin will be drooped down as the case melts- test by temporarily jumpering between the two posts. If the heater works with a jumper, the switch is bad. A replacement switch is available for $13 at: (888) 775-1330 AZ patio heaters or http://azpatioheaters.com/product.php?productid=32&cat=3&bestseller=Y#images part no. THP-ATM
Feb 04, 2012 | Heating & Cooling
Not sure if a blower is in this model because feel no air comeing from unit
The blower is/was a $69.00 optional add on feature for that heater. To be quite honest, a blower does little on an Infrared Heater. Infrared, unlike Blue Flame Convection Heaters, doesn't waste energy heating the air. It heats objects (floor, walls, furniture, etc). From that the room air heats up. Simply put, it heats a room like the sun heats the earth. It's really more efficient than a gas convection heater. Rated 99.9% efficient at 15,000 Btu's, it will heat a good sized room easily.
I've selling these heaters for several years and I always try to talk the customer out f wasting their money on a blower. It's simply not needed on an infrared heater.
I hope this helped you and thanks for choosing FixYa.
Aug 20, 2011 | Empire ECS HearthRite HR25EL Heater
My fostoria spacer stop producing heat model 1520 3A. Smell a burn odor fan still works. Sounds different too. can you help? Dennis
Your electric space heater works by using a quartz infrared element, something that can eventually burn out due to use/defects. To fix your space heater, you will have to get another element specific to your model fostoria. While I did a quick search online, I could not find any matches to a replacement, but you can still call the company for one. Before calling, though, check to see if your heater is still under warranty, probably 1 to 2 years. The number for fostoria is 1-800-495-4525. Best of luck.
Mar 03, 2011 | Fostoria FES - 1520 - 3A Heat Wave Utility...
Mine is only a few months old. It is a Westpointe radiator type. The orange light is lit. It just doesn't heat anymore. D. Weaver/ DWeaver272@aol.com
if you dust sweep vacuum around these heaters they pick-up small particals of dust which rises up thru the heater and get deposited on the curcuit board and wiring thru convection and they go into default mode, clean thoroughly, make sure it's unplugged be fore you start
Jan 31, 2010 | Pelonis Oil Heater HO 157
Heating & Cooling Logo
800 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
