Question about Teac AD-600 3-Disc CD Changer
CD CHANGER DO NOT OPEN - Teac AD-600 3-Disc CD Changer
Jammed cds in a 6 cd changer ford ranger 2002
sounds like the tray inside was misaligned when the cd went in. and it probally sent the disc into a occupied slot. you will have to remove radio and disassemble to repair. also try just unpluging radio and plug back in. sometimes it resets the radio and will start ejecting the cds
Feb 05, 2010 | OEM Systems Car Audio & Video
Our Sony 400 disc changer won't open. I can hear
If ure an expert, then open up the set, check for alignment balancing for the gears and see if the belting has worn out. Pioneer till today uses belt for ejecting. Belt usually the issue.
Jan 16, 2010 | Sony MegaStorage CDP-CX455 400-Disc CD...
Cd 6 from the cd changer has stucked. do i have to
Dismount the cd changer so you can open it, and unstucked the cd tray.
Sep 27, 2009 | 2007 BMW Z4 Roadster 3.0si Convertible
How do you open c/d changer in trunk?
front of changer has a sliding door,slide open & below cd magazine is a small button,press this&magazine will eject,this will not work if changer is disconnected from the vehicle,
hope this helps
Jul 02, 2009 | Nakamichi Car Audio & Video
Jeep RDS CD Problem
Did you change the battery ? If so try disonnecting and reconnecting the CD changer.
Dec 27, 2008 | 2005 Jeep Grand Cherokee
Cd changer is jammed in denon dcm 360 5 cd changer
Simply remove the outer casing and remove the jammed disc
Nov 28, 2008 | Denon DCM-360 5-Disc CD Changer
2003 Gran Cherokee CD Changer
Hi
I don't know if anyone's helped you with this yet, but to find the CD changer, open the rear door, and if you look just below the rearmost right window you'll see a hatch with a release button. Press the button, lift the lid, and there's your CD changer. Hope this is helpful. Good luck!
Aug 02, 2008 | Cherokee Jeep Grand CD Changers - 10-Disc
Panasonic stereo with 5-cd changer
Hi, I have a Panasonic SA-ak25 system. I played one cd then inserted a second. When the second cd had finished it ejected but the first cd is still in the player, When i try to eject it the lights start to flash and it always stops on no (4) can anybody help. Bob.
Jun 15, 2008 | Audio Players & Recorders
Cd changer drawer won't open
the common problem for this would be some of the disc/discs are out of place . just opening the shell
and removing the discs can resolve the problem.
Feb 23, 2008 | Technics SL-PD5 5-Disc CD Changer
CD CHANGER
This only happens to me with burnt cd's.
Nov 04, 2007 | Panasonic SCAK410 5-Disc CD Changer
Teac AD-600 3-Disc CD Changer Logo
23 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
