Question about Husqvarna 155HP DualHydrostatic 42" Cut ZeroTurn Radius Mower
No drive forward or reverse - Husqvarna 155HP DualHydrostatic 42" Cut ZeroTurn Radius Mower
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Check the tension on the drive belt if it's still there...check your dump valves. then check fluid level.
Posted on Nov 27, 2013
50 horse 4 stwont go into reverse gear due to shaft problems
the drive shaft just drives a pinion gear in the prop box that drives to gears that spin in opposite directions all the time
by selecting forward with the selector rod , a dog gear is moved forward to mesh with one gear that is turning or moves the other way to engage the other gear that is turning
that is the forward or reverse action for the prop
if you have forward but no reverse the it is not a drive shaft problem but a selector rod adjustment that is not moving the dog far enough to engage the running gear
Jul 08, 2017 | Cars & Trucks
WILL NOT DRIVE FORWARD OR REVERSE
It sounds like the drive belt has slipped off a pulley. With fuel turned off, tilt the mower to one side- so the fuel cap is at the highest point of the tank, and cannot leak fuel out the breather hole. One belt will drive from the engine and the other end goes around an idler pulley. The other belt will drive from the axle to an idler pulley and will be slightly loose. This is the one that may have slipped from its position and not be contacting one or more pulleys when tightened. There should be a pair of pulleys, each being one side of the drive belt. Pressing the forward control should move one pulley onto the drive belt and simultaneously tighten the axle belt. Pressing the reverse control should engage the other pulley(on the opposite side of the belt) and also tighten the axle belt. This loose belt may have been bumped off one or more pulleys in the collision, and be sitting between the pulley and the guide/guard. With the ENGINE OFF, and the forward/reverse selector in neutral you should be able to force the loose belt back over the pulley.
Whether the forward/reverse mechanism drives the engine or axle pulley, the principle will be the same.
Apr 17, 2016 | Husqvarna YTH22V46 46 inch 22 HP Briggs &...
Is there no reverse, just forward?
only forward gears no reverse Dolls, Playsets & Toy Figures ...
www.fixya.com > Forum > Tags > only forward gears no reverse
Ask your only forward gears no reverse doll, playset and toy figure questions. Get free help ... Could there be a problem in both of the drive motors themselves?
Ertl only forward gears no reverse Dolls, Playsets & Toy ...
www.fixya.com > ... > Dolls, Playsets & Toy Figures
Ertl dolls, playsets & toy figures only forward gears no reverse related ... as i drive itforward What is the last thing that happened before you noticed there was a ...
Farmall only forward gears no reverse Dolls, Playsets & Toy ...
Farmall dolls, playsets & toy figures only forward gears no reverse related questions and answers. Ask your Farmall questions. Get free help from doll, playset ...
PREVIEWSworld - Devolution Goes Forward In Reverse
www.previewsworld.com/Home/1/1/71/979?articleID=170370
I had just started doing Fear Agent and Strange Girl and a number of other ... But in terms of this there was some rule-breaking that I'm not sure I would do today ... Elliott Serrano: Okay, what would be one toy or action figure that you'd like to be ...
Dec 16, 2015 | Toys
My car goes into reverse but won't go forward. What's the problem?
10 Most Common Transmission Problems
www.transmissionrepaircostguide.com/10-common-transmission-proble...
A similar type of thinking goes into diagnosing car trouble. ... response issue, but after shifting into gear the engine's RPMs will surge, but the car won't move ..... Can anyone please explain why my car cant go in reverse but can drive forward
My car will not go in reverse but will drive forward. What could ...
https://answers.yahoo.com/question/index?qid...
Dec 26, 2007 - My car will not go in reverse but will drive forward. ... I tried putting it in neutral and pushing it backwards, but something catches and it won't budge. ... Either way, it's likely that the transaxle is going to require removal and ... the hood and movethe linkage by hand, then it would shift into gear ok for awhile. Why won't my truck go forward, it only goes in reverse? ' Yahoo ...
Feb 23, 2014
My car won't go into reverse, still okay to drive a 2 hour drive ...
Jan 12, 2011
My car won't go in reverse but it will go forward with no problem ...
Feb 6, 2010
My car will drive forward, but not in reverse... Could this be a ...
Sep 11, 2007
More results from answers.yahoo.com
Dec 16, 2015 | Cars & Trucks
My reverse went out of my truck and I put it in neutral to push it backwards and its like I'm in drive andcan drive forward what can I do to fix it
If reverse is done and you can only go forward is it shifting out of first. If its not then you need the transmission rebuilt. That's what happened on my truck.
Apr 03, 2013 | 1996 Dodge Ram
My Prop On My Larson Boat With A Mercruiser Alpha 1 Drive & A 5.7 Liter Engine Won't Turn The Prop In Forward Or Reverse. When The Engine Is Off & It Is Shifted Into Forward The Prop Can B
run the engine and watch the drive shaft behind the engine , is it turning ? also as your mate selects forwad and reverse ! does it stop turning ? pos flywheel damper or output shaft damaged ! pos gearbox damaged !??
Jun 04, 2012 | Mercury Boating
I have a 2000 Expedition 4.6L Triton. I've had truck about 7 years and love it. I have had all the transmission issues this truck can have...(I thought) until now this: SYMPTOM Transmission drives well in...
4R100 or 4R70W?
Geartrain
Power is transmitted from the torque converter to the geartrain components through the input shaft and forward clutch cylinder.
  • By holding or driving certain members of the gearset, four forward ratios and one reverse ratio are obtained and transmitted to the output shaft. The ratios are as follows:
GEAR RATIO 1ST 2.71 to 1 2ND 1.54 to 1 3RD 1.00 to 1 4TH 0.71 to 1 REVERSE 2.18 to 1
Input Shaft
The input shaft is supported by two bushings in the stator support. End positioning of the input shaft is controlled by the splines in the converter turbine and the overdrive planet assembly.
Output Shaft
The output shaft is supported by two bushings in the case and by the slip-yoke and bushing in the extension housing. End positioning is controlled by the parking pawl gear and snap ring or shoulder and by the reverse ring gear hub and snap ring.
Overdrive System
The overdrive planetary system consists of the overdrive planet assembly, overdrive sun gear, overdrive ring gear, coast clutch cylinder, overdrive one-way clutch assembly and the center shaft, as shown in the following illustration. The overdrive planet assembly is splined to the input shaft. The overdrive sun gear is centered by a bushing on the input shaft and held in place laterally by needle bearings on the reactor support and the overdrive planet assembly. The overdrive sun gear is splined to the coast clutch cylinder, which in turn is splined to the overdrive one-way clutch inner race.
The outer race of the one-way clutch is splined to the overdrive ring gear, which is splined to the center shaft. The center shaft is centered by the forward planetary assembly and is laterally held by needle bearings on the center support and the overdrive planet assembly. The center shaft is splined into the forward clutch cylinder.
Two friction clutches are assembled in the overdrive planet assembly. The coast clutch is splined between the coast clutch cylinder and the overdrive ring gear. The coast clutch is activated to perform engine braking in MANUAL 1, MANUAL 2 and third gear with the transmission control switch engaged.
The overdrive clutch is splined between the case and the coast clutch cylinder. The overdrive clutch holds the coast clutch cylinder and, in turn, the overdrive sun gear, to permit the planet assembly to overdrive the ring gear.
Forward Drive System
The forward drive system consists of the forward clutch cylinder, intermediate brake drum, intermediate one-way clutch, input shell, forward ring gear, forward ring gear hub, forward/reverse sun gear and the forward planetary carrier and forward planetary gears.
The forward clutch cylinder is splined on the center shaft. The forward ring gear is piloted on the forward ring gear hub. Thrust bearings on the forward planet assembly and forward clutch cylinder hold the forward ring gear hub in place.
The intermediate brake drum is radially supported by bushings on the center support and is laterally controlled by thrust washers on the forward clutch cylinder and center support. The intermediate brake drum has the inner race of the intermediate one-way clutch press-fitted on its pilot. The intermediate one-way clutch's outer race is splined to the intermediate friction clutch, which is splined to the case. The intermediate brake drum has lugs that are slotted into the input shell to form a mechanical connection. The input shell is splined into the forward/reverse sun gear. The forward/reverse sun gear is common to two planetary gearsets. The forward planet is splined to the output shaft and is laterally positioned by needle bearings on the sun gear and on the forward clutch cylinder, as shown in the following illustration.
Two friction clutch assemblies, the direct clutch and the forward clutch, are shown with the forward planetary assembly. The direct clutch assembly splines the forward clutch cylinder to the intermediate brake drum. The forward clutch assembly splines the forward clutch cylinder to the forward ring gear. The forward clutch is activated during all forward gears. While in third or fourth gear, both the direct and forward clutches are applied to hold the forward planetary assembly and enable it to act as a solid shaft.
In second gear, the intermediate clutch assembly holds the forward/reverse sun gears. It is applied, along with the intermediate one-way clutch, to hold the intermediate brake drum, input shell and forward/reverse sun gear. In higher gears, the one-way clutch overruns.
Low and Reverse Drive System
The reverse planetary assembly consists of the reverse planetary carrier, reverse planet gears, the reverse ring gear, the reverse ring gear hub, the reverse clutch hub and the low-reverse one-way clutch assembly.
The reverse ring gear hub is splined to the output shaft and to the reverse ring gear. The reverse ring gear hub is laterally held by a needle bearing on the inner race of the low-reverse one-way clutch and a snap ring on the output shaft. The reverse planet assembly is splined to the low-reverse clutch hub. The low-reverse clutch hub is connected by the reverse clutch to the case. The inner race of the one-way clutch is bolted to the case.
The reverse clutch assembly is activated in REVERSE gear and in MANUAL 1. The reverse clutch bypasses the reverse one-way clutch during coast and MANUAL 1. The reverse clutch holds the reverse planet assembly in REVERSE gear to enable the sun gear to drive the reverse ring gear in the opposite direction.
Apply Components
The following information describes the operation of the three 4R100 one-way clutches.
One-Way Clutch—Overdrive
The overdrive one-way clutch, shown in the following illustration, transmits engine torque from the overdrive sun gear to the overdrive ring gear in first, second and third gear range. The overdrive one-way clutch transmits power when the sprags are engaged between the inner and outer races. The inner race is splined to the coast clutch cylinder, which in turn is splined to the overdrive sun gear. The outer race is splined to the overdrive ring gear.
The overdrive one-way clutch engages whenever the overdrive planetary system attempts to drive the overdrive sun gear clockwise when the overdrive ring gear has a counterclockwise torque from the vehicle. When torqued counterclockwise, the overdrive one-way clutch engages and acts as a wedge to lock the sun gear and the ring gear together. During coast, the overdrive one-way clutch enables the ring gear to overrun or spin at a faster rate than the sun gear.
The overdrive one-way clutch overruns when in overdrive (fourth gear). In overdrive, the coast clutch cylinder is held by the overdrive one-way clutch, which in turn holds the overdrive sun gear. This causes the overdrive planet assembly to walk around the sun gear and overdrive the overdrive ring gear. The inner race of the overdrive one-way clutch is thus held stationary while the outer race is allowed to overrun clockwise.
Nov 10, 2009 | 2000 Ford Expedition
Rover racher auto drive no forward drive reverse
band is out in training time to rebuild training
Aug 29, 2009 | Garden
Driving forward in reverse and would not back up in reverse
??? Where's the rest of the information? "driving forward in reverse and would not back up in......."?
Jul 21, 2008 | 1995 Mazda 626
C 6 transmission
Forward drive in the C6 requires both the forward clutch AND the low/reverse, one-way clutch, or intermedaite band to engage. Since you have reverse but no forward, the forward clutch is most likely the problem, since it is needed only for forward speeds and does not affect reverse. Sounds like a trans rebuild.
Jul 14, 2008 | 1988 Ford F 250
Husqvarna 155HP DualHydrostatic 42" Cut ZeroTurn Radius Mower Logo
14 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
