Question about GARDENA Water Timer
Wont turn off
Timer won't turn off manually
Paragon model 8141-00 defrost timer wont turn.
Is this a used timer?
8141-00 is 120 volt timer.
Is your 120 volt Hot wire on terminal 3 and Neutral on terminal X?
Test across 3 and x for 120 volt.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
Don't buy used defrost timers... they always look good when you inspect, but never work when connected... that's why the timer was taken out of service and sold as used timer.
Save the old trippers for use on new timer.
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 28, 2015 | Paragon Hardware & Accessories
Timer doesn`t work,doesn`t rotate.
If this is an electromechanical timer and the dial will not rotate, you can be pretty sure the timer motor is no good
May 21, 2013 | UPM 120V/240V Heavy Duty Outdoor...
Won't stop, have to manually open door
Sounds like a bad timer. Your dryer is a Whirlpool product.so a replacement timer should be easy to locate. If the timer is advancing but the dryer won't stop, the problem could be the control unit. Run another load of clothes and take notice of the timer's position. If it doesn't run out, then it's very likely the timer. The video below shows step by step instructions for replacing the timer unit.
Mar 30, 2012 | Estate TEDS740JQ Electric Dryer
I returned from vacation last night and noticed all four of my coach lights were off. I thought...the timer needs to be reprogrammed due to a power outage while I was away. The red indicator light was...
1) You performed correct troubleshoot steps down the line.
Last thing would be to install defect timer on another light circuit in house, and see if problem is the timer or wire going to coach lights.
http://waterheatertimer.org/pdf/Intermatic-ej351c.pdf
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
2) EJ351C has 1 year limited warranty.
Buy new EJ351c and install single pole light switch until timer replacement is available.
Timer has easy 2-wire installation. Turn off power. Connect new timer just like old one was connected. Either timer black wire connects to either wire in switch box.
http://www.smarthome.com/25077/Intermatic-EJ351C-24-Hour-Mechanical-In-Wall-Timer/p.aspx
http://www.amazon.com/Intermatic-EJ351C-Programmable-Mechanical-Security/dp/B000Q9YUGU
Aug 08, 2011 | Intermatic Hardware & Accessories
Dryer wont shut off unless turned off and dryer just tumbles with no heat.
If it won't turn off or heat then it is probably the timer or if it is a newer unit the control board.
Aug 06, 2011 | Kenmore Dryers
Timer wont turn on, is the manual switch below the dial suppose to be in on or off position?
the manual switch is to override the timer and turn on what its controlling, for the timer part to work it is supposed to be in the off position, this should let the timer work like its supposed to.
Aug 08, 2009 | Intermatic Hardware & Accessories
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Won,t drain on rinse cycle
There could be several causes for this, but probably a bad timer. One test for this...when it stops...is to turn it off...and turn the timer slightly clockwise...to the middle of the rinse cycle...and turn it back on. Does it run then?? Try advancing it to the spin cycle after the rinse. If it runs okay after you manually advance the knob...the timer is probably defective.
Jan 13, 2008 | GE WNCD2050AWC Top Load Washer
GARDENA  Water Timer Logo
64 people viewed this question
Top GARDENA Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Bill Boyd
Are you a GARDENA Hardware and Accessory Expert? Answer questions, earn points and help others
