Question about Lenovo IdeaTabTM A1000 Tablet With 7in. Screen
A1000-T not charging
My A1000-T is not charging. i think i drained all the power and when i tried to charge it a battery symbol will appear but not charging.what is the best thing for me to do?
3 Suggested Answers
MerlinTech
  • 197 Answers
SOURCE: battery appears charged, but computer will only run when plugged in
does your battery have one of those charge indicator panels on bottom?
also, it's possible that the connection from battery to the internals is shot..if that's the case, then you're looking at a major motherboard swap
Posted on Jun 15, 2008
  • 6771 Answers
SOURCE: Laptop will not charge battery. Issue with internal power converter, etc.
The motherboard has charging circuits built in to regulate the charge to the main battery, in rare causes it fails leaving a choice to attempt a repair or replace the motherboard. I suspect this is what has happened to your system.
Posted on Apr 06, 2012
Tablet not charging while plugged in
Turned off the tablet, unplugged the charger and kept the tablet off for about 30 minute to one hour, plugged in back the charger, then turn on the tablet. After that I you might see the tablet started charging. Good Luck.
Jul 10, 2015 | ASUS MeMO Pad HD 7
How to fix my Lenovo tablet A1000-F it won't charge?
If you ask "how to disassemble, repair, and reassemble" it, you should not be trying to do it -- take it to the nearest Authorized Repair depot. Check Lenovo's web-site to find the location of that depot.
Mar 08, 2014 | Tablets & eReaders
What is wrong with my 2003 BMW 525i?Battery Drain
excessive power loss due to alternator bad..take to parts store so they can check it..diode trio is bad letting power back thru the alternator..basically it wont shut off now and will kill the battery after several hours..
Dec 26, 2013 | BMW X5 Series Cars & Trucks
My Iphone was working fine until an hour ago when I accidentally let the battery drain. Now the low battery icon has shown for 1 hour without the Iphone coming to life. I need my iPHONE as i live remotely.
I know how desparate this feels - try powering it off completely and remove / replace the battery - make sure the charger is connected securely and try again - you should be able to use the phone whilst it is on charge. If the charging symbol does not appear when in charge mode then the charger itself may be faulty. Try hooking it up to a USB cable from your PC - it should still charge but not as quickly.
Mar 18, 2011 | Apple iPhone Smartphone
My 3G iphone stopped charging anymore,it happened only once i just delayed the charging and the battery indicater displayed full drained.there is battery symbol indicating only red charging level and power...
possible battery problem, i suggest you visit the nearest service center for your phone to be check by a professional.. if it still under warranty much better so you dont have to pay any charge for the repair.
Oct 01, 2010 | Apple iPhone 3G
Xperia x1 won't charge. The charging symbol will appear on the screen for a short period of time (perhaps 2 or 3 minutes) before disappearing a showing the full battery symbol. This shouldn't appear...
First try to replace the battery, a drained or low voltage battery won't charge up.
For infos on how to fix the Sony Ericsson Xperia X1 Not charging:
http://mobilephonerepairguides.blogspot.com/2011/01/sony-ericsson-xperia-x1-not-charging.html
Aug 31, 2010 | Sony Ericsson XPERIA X1 Smartphone
Screen frozen on slide to power off
Turn iPod touch off and turn it on again.
If the iPod will not turn off, try to reset it. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until either the Apple logo or battery symbol appears. If the battery symbol appears, continue to charge iPod touch until it is fully charged.
If this doesn't work, try restoring the iPod
Nov 18, 2009 | Apple iPod touch
The Backlight won't come on. i went to general settings and made sure the auto light was on.. and i even turned the brightness all the way up thinking that would help.. but nothing has changed. what else...
Try the following
Turn the ipod off and then on again.
If that does not work reset the ipod while it is connected to the power. You do this by pressing and holding the sleep/wake button and the home button at the same tme for at least 10 seconds, until either the apple logo or battery symbol appears. If the battery symbol appears, charge the ipod until it is fully charged.
Hope this helps.
Nov 15, 2009 | Apple iPod touch
Flashing Battery Symbol on GPX PDL805
The appearance of a battery symbol while you are using just the battery means that you are using just the battery.
That's it.
No Problem.
The flashing battery symbol is a constant reminder to you that a power intensive function is only supported by the battery, and that you should make external power available so as to complete the task without losing power in a battery drain event.
May 07, 2009 | GPX PDL805 Portable DVD Player
Symbol MC50 battery power problem
you need to check your power management settings, idle / standby as it sounds like your terminal is just "on" all the time
Oct 10, 2008 | Symbol MC50 Portable Terminal
Lenovo IdeaTabTM A1000 Tablet With 7in. Screen Logo
67 people viewed this question
Top Lenovo Electronics - Others Experts
Are you a Lenovo Electronics - Other Expert? Answer questions, earn points and help others
