Question about Sanyo Refrigerators
My refrigerator model SR2000 F sanyo cool only the from the upper part
  • Zeinab Rahman
    Zeinab Rahman Nov 23, 2013
    all these mentioned part are changed and still the refrigerator is not cooling well in the lower part but the freezer cool well
  • richie46 May 09, 2014
    Did you check what the freezer temperature is? Should be at least 5 degrees or less. If the freezer temp is on the high side, the refrigerator temps will be high also. If temps in freezer are low, check to make sure that there is nothing obstructing the flow of cold air from the freezer to the refrigerator section. Also check refrigerator door gaskets for leakage of cold air.
    Top Expert:
  • Sanyo Master
  • 12,962 Answers
Evaporator is frozen with a block of ice preventing airflow into bottom of refrigerator. If you turn off the unit and allow it to completely defrost (all ice in freezer melted) unit will work again until the ice builds up again in few days or week..
The defrost circuit on unit is not working. Check the defrost timer, defrost heater, or defrost thermostat. One of these is responsible for the problem.
Posted on Nov 23, 2013
  • richie46 Nov 23, 2013
    If you have replaced all of the parts mentioned and you are still not getting adequate cooling then you may be low on refrigerant due to small leak that has developed over the years. Confirm by taking temperature readings in freezer and refrigerator compartments. after a normal cycle. Freezer shld be at zero or close to it and the fridge should be around 39 degrees. If you do not have guages or want to throw in a shrader valve to measure the charge you can always turn the witch off and turn her back on in the morning. Then let it run for at least an hour in a room at ambient temperature. The suction line to the compressor should be cold to the touch and might even have small beads of sweat on it. If it is warm to the touch you are low on gas..
Sanyo SR-4800W freezer is ok and cold stoeage is warm. Need to fix the problem.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 17, 2011 | Sanyo SR-4800 Top Freezer Refrigerator
Only the freezer cools, but the rest of the refrigerator does not cool
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 20, 2010 | Sanyo Refrigerators
Freezer icing and warm refrigerator section in upper freezer model TBX18TD
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Mar 08, 2010 | GE GTS22KBP Top Freezer Refrigerator
Sanyo 4.9cu.ft. compact refrigerator heats rather than cools
I'd already picked up a replacement (B&D 2.7cf) before I found the website and asked the question,,,, hoped for a quick fix answer and I'd be able to return the B&D.... oh well. With 'designed' obsolescence and 'disposable' appliances, Robert L's answer confirmed my 'fears'.
Now I'm trying to find someone locally (Conroe, TX) who would like to 'recycle' the Sanyo (everything but the compressor/motor is in great shape - door, glass shelves, etc. maybe even the coolant which I don't want to 'dump' in a landfill.
Jul 23, 2009 | Sanyo Refrigerators
Sanyo sr-1013w not cooling
sounds like it has a refrigerant leak somewhere in the unit.
Feb 20, 2009 | Sanyo BC-1206 Commercial Beverage...
Not cooling....
Sounds like you checked for the proper items, fans to move cold air, etc. and if stuck in defrost mode. If the compressor is running you would have to be cooling unless... the refrigerant has leaked out. And that is basically a bad thing. If in defrost cycle the compressor would stop while defrosting soooo it's looking like the refrigerant is gone. Can you take the back interior panel off to see if the coils have a full frost pattern?
Jan 04, 2007 | Sanyo SR-4911M Compact Refrigerator
Refrigerators Logo
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
Steve
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
