Question about High Flow VG30 Fuel Rails - Nissan 300zx
Cutting idling while engen is running - High Flow VG30 Fuel Rails - Nissan 300zx
    New Friend:
Add a race fuel pump you need more psi for youre rails
Posted on Nov 23, 2013
Idle is at 1500
the idle speed control is out is the check engen light come on
Nov 12, 2012 | Cars & Trucks
Poulan snow blower will not idle down engen running to fast
usually when a 2 cycle won't idle down and runs too fast it's a sign of vacumn leak (sucking Air) into the crankcase,at crank seals
Dec 04, 2011 | Garden
01 ford expedition. its hard to star all the time, i can run only if i hit the gas pedal if idont the engene is gonna die but once the idle kick that means its good
may be low fuel pressure at start up. Try this, turn key to ON and wait 5 seconds for fuel pump to stop humming. Then try starting. If it starts up faster, you have a bad check valve in the fuel pump, change it. It's in the fuel tank.
Slim chance it could be the fuel pressure regulator on the fuel rail with the injectors. very seldom fails.
Finally, your cold fast idle circuit is not wokring right. Clean passages.
Aug 30, 2011 | 2001 Ford Expedition
1990 wrangler with 90k-- runs great once and a
Taps or Knocks ?? Knocking indicates gas mixture to rough, possible dirty fuel injectors, try a gas system/fuel injector cleaner and either lower the octane or increase it for 1 tank of gas
Jul 11, 2009 | 2000 Jeep Wrangler
Idle goes up and down
The check engen light should be on if it's a fuel prob. or other senser such as an idle air controll valve. If no light is on, clean the throttle body and add fuel system cleaner.
May 19, 2009 | 2003 Ford F150 Regular Cab
Idling Control Valve
If the check engen light is on, it's probly the idle air controll valve. The only way to know is to find a shop with an old scan tool (almost impossible). The controll valve is not servicable.
May 19, 2009 | 1993 Toyota Celica
My jeep wants to die
Sounds like it's time for a Major tune up including a new timing belt, plugs wires, sensors,plugs, belts and fluids transmission flushing,radiator flushing and tune, new hoses, clean battery post and cables replace if damaged. Oil change, new idle adjustment screw and check exhaust system for leaks.
aymloekh0fg4hpz2e87n86udvs4fowqwshuaaaaasuvork5cyii=
Apr 22, 2009 | 2000 Jeep Grand Cherokee
High Flow VG30 Fuel Rails - Nissan 300zx Logo
Top 300 Degree Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a 300 Degree Vehicle Part and Accessory Expert? Answer questions, earn points and help others
