Question about Philips HTS3450 System
The power source will not stay on - Philips HTS3450 System
My nuvi 660 does not start
Have you tried resetting it?
  1. Disconnect from the external power source.
  2. Flip up the GPS antenna.
  3. Press the Reset button.
  4. Connect it to the power source. The unit should turn on.
Mar 05, 2008 | Garmin Nuvi 660 GPS Receiver
Why won't it recharge?
The charger or the wire that connect to the power source could be damaged, or the error can sometimes be resolved by the reset button.
Sep 05, 2015 | Finis Neptune Underwater MP3 Player
My Kenwood KAC 5001PS red light comes on and stays on but it still plays how's that possible
most if not all systems require a power source directly linked to the batterys main supply. depending on how your system is installed, you may also have it connected to a Switched Power Source, such as your car radio, that will only turn on when the ignition is switched to on. if im understanding your dilemma correctly, and the light stays on and such - possibly wire the system differently with a switched power source that will disconnect whenever you choose
May 11, 2014 | Car Audio & Video
New radio in truck wont power dont when truck is off
There are two 12 volt sources from the vehicle behind the stereo, one is a constant which the stereo requires to keep the clock circuit powered, the other is a switched ignition source which is designed to supply power to the stereo when the key is turned backward from the off position and or forward, you likely connected both wires from the stereo to the constant wire. Perform a Google search to obtain a wire color diagram of your vehicle.
Dec 22, 2013 | Radio Communications
The clock radio stays on with the ignition key turned off
reroute the power wire to a switched power source from the fuse block
Dec 18, 2013 | BMW X5 Series Cars & Trucks
Radio won't shut off on 2007 pontiac g6
Check wiring and see if power source is to wrong lead, usually the constant power wire would be wired to the clock or auto antenna. The poer source for turning the radio on should be wired to the power source that is tied to the ignition, so when you turn your key off the power will be off as well.
Jan 20, 2013 | Cars & Trucks
No power light on transmitter. Measured correct voltage at power-in.
the light does NOT stay on .....because it was not designed to.....takes INCOMING SOUNDwith the transmitter plugged into the sound source to make the light stay on......
Oct 02, 2010 | RCA WSP150 Main / Stereo Speaker
Stays on even if HU (CDA-9833) is off
It is possible that the SIR unit stays powered as long as the red wire is powered, since it is normally connected to a switched source. To test this, disconnect the red wire or move it to a switched source (you could even add a switch on the wire and flip it manually). If the battery stays healthy after that, then the red wire being constantly powered is the problem. Otherwise, it is possible there is a problem with the Ai-NET cable connected to the SIR unit.
Sep 26, 2006 | Sirius Satellite Radio Sirius SIR-ALP1...
Philips HTS3450 System Logo
24 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
