Question about Canon PIXMA MX860 OFFICE AIO-2.5IN LCD 19.4X17.1X8.9IN All-In-One InkJet Printer
Mx860 prints too light
I just replaced all of the ink cartridges with generic. Did it before and was fine. Now it prints very faded. I've cleaned, deep cleaned, aligned and printed test pages to no avail.
  • 24 Answers
Replace your ink cartridges again. Seem like the print heads are busted already. Try returning the cartridges to the seller or ask to have them replaced.
Posted on Nov 23, 2013
  • 59 Answers
SOURCE: Magenta printing as yellow
Well, first off, are the alignment, and nozzle check sheets looking good? If not, then work on that. If so, then we have a problem. Try creating a test sheet in Word. Make red, yellow blue & black text and see if anything else prints wrong. Get back to me!
Posted on Jun 19, 2007
artifixit
  • 59 Answers
SOURCE: Unclear Printing
Your print head is most probably blocked.
First try and run the cleaning program a few more times, it make penetrate deep enough to get through.
If that doesn't work you can either replace the print head or try and clean it.
To clean it you could soak it in a mixture of window cleaner and water (filtered best), but don't let the electronics get wet by this and try to avoid wetting the rubber seals where the ink tanks go get wet by this too, it should only soak the very bottom part of the head.
Let it dry off and wipe any residue with a soft cloth especially on the bottom where the print heads actually are. You may need to soak it a few times to get all the gunk out.
Posted on Jan 25, 2008
SOURCE: smeared lines
Okay, this was the problem I posted a few days ago. It's fixed now, so in case you have the same problem with smearing, here's what the help desk from Canon suggested: Open the cover and remove the ink cartridges. There is a gray lever in front of the cartridges. Lift this lever and the printhead can be easily removed.
Our printhead had a buildup of black ink on the surface. I carefully removed this with rubbing alcohol. I let the printhead dry and replaced everything. No more smearing. Imagine a help-desk that actually helped!
Posted on Nov 21, 2008
rhoncruz
  • 134 Answers
SOURCE: #5 black ink cartridge skips through the middle occasionally
Replacing the print head
The print head may need replacing if, after all print head and ink tank troubleshooting has been performed:
  • The nozzle test appears broken or to have horizontal white streaks.
  • One or more of the colors is missing from the Nozzle Test.
  • The colors are incorrect on the Nozzle Test.
  • A print head error is indicated on the unit.
  • The printer powers off when the print head is installed.
I hope it helps!!!
Posted on Dec 02, 2008
  • 68 Answers
SOURCE: Canon iP90 only prints blank pages
Did you try to wipe the cartridge.Maybe there's a clogs. inside.
Posted on May 28, 2009
Canon mx860 printer not using ink from PGBK 220
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Mar 07, 2013 | Canon PIXMA MX860 All-In-One InkJet...
Brand new printer with brand new ink prints BLANK pages
Hi Mike This is an odd one. If it prints the bars then ir should print everything else - cleaning is just wasting ink in this case.
I'm guessing that this is still under warranty, so I would take it back and get it replaced.
Mar 06, 2013 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Cannon mx860 fails to print in black ink. loaded new cartridge, still doesn't print in black. will print in color..
With the Canon MX860 you can removed the print head assembly quite easily and clean it with water. I have posted a youtube video for your reference.
DOCUMENTS PRINT IN FADED GREEN OR FADED BLACK
do a test print and check to see if the nozzles are firing properly and the colors are correct. if you are using generic ink that could be an issue.
do a couple cleanings and then another nozzle check to see if it has improved.
if you replace the ink cartridge, remember that it will take time for the new ink to creep into the printhead system.
Sep 02, 2010 | Brother DCP-110C All-In-One InkJet Printer
Head cleaning not working
Doesnt sound like you Used Genuine Cartirdges?
Did you use Epson Genuine Cartridges? ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Apr 04, 2010 | Epson Stylus Color 740 InkJet Printer
My prints are all coming out faded and light- i;ve tried to clean the nozzles and head adjust, the cartiges are all new. Any advice?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
This is the only advice I can give you. If you find this helpful, pls rate me.
Feb 09, 2010 | Epson Stylus Photo R1800 InkJet Printer
Pages are coming out blank with no typing on them and the ink cartridges are fine
Did you just replace the cartridges? In some cartridges you will have to remove, a taped plastic before installing them.
Try cleaning, the print heads using your printer software.
Good luck
N Sabre
Dec 09, 2009 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Printing won't work.
Good day sir/maam, hi, when you test print it usually prints letters and no lines are printed. try first if the printer is setup to economy/draft or pictures, if lines are faded, the ink cartridges maybe dirty. manual cleaning is needed, the ink path starts from the ink cartridge to the cradle or carrier then to paper. so any dried ink that blocks the path can affect the printout. you can use warm water to loosen dried ink. remove the cartridges and cradle from the printer as you clean them.
Oct 27, 2009 | Office Equipment & Supplies
Printer doesn't print well
Hav you replaced with original cartridges or 3rd party/refilled ones? This is a common problem when using generic/refilled cartridges. Let me know that first..
When you say poor quality, do you mean faded printouts, or broken print? Kindly explain in detail, so I can assist you further.
Nov 07, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Faded print on one side of page
I have a SCX-4100 Samsung, replaced the tonger cartridge, it was working fine for a few hundred sheets of printing, but after that, the left side of the page was printed very light, faded.
If I run the "Clean Drum", it will print a litter better, but still faded.
What can I do to correct this problem?
Thank you
TT
Nov 24, 2007 | Samsung ML 1710 Laser Printer
Canon PIXMA MX860 OFFICE AIO-2.5IN LCD 19.4X17.1X8.9IN  All-In-One InkJet Printer Logo
96 people viewed this question
old marine
old marine
