Question about Danby DWM5500 Front Load Washer
How do you replace the cycle switch on this machine? the light is out on one side and when I touched it I got a puff of smoke. Everything else seems to be fine - but the washer won't run at all. PS got the coin out ;)
Small puff of smoke on startup - intermittent
I have seen this on old cars, my suspicion is that the seals on the valves are a bit worn. This allows some oil to get through during start up. Since it quits smoking, I would not be overly concerned. However, since it burns a quart every 1-2K miles, I am curious what the compression is. My Fiero does the same thing (occasional puff of smoke on start up) but does not need oil between 3,000 mile chages. It is a 2.5 liter. Here is nice tip: check compression on all cylinders, then recheck it adding a teaspoon of 2 cycle oil to the cylinders (one cylinder at a time). Some have said to use conventional oil for this, due to higher viscosity, but I always thought it might foul the spark plugs. If the compression goes up, it is ring wear, if not it is leaking through the valves.
Oct 01, 2013 | 1988 Pontiac Fiero
Puff of smoke from air vents.
You have a better idea than us, you saw and smelt the smoke.
Nov 01, 2017 | 2000 Ford Taurus
How to replace valve seals. when cycle is on side stand for a day or two and you start engine it smokes for a few seconds
This has been an issue for ALL Goldwing's (1000, 1100, 1200, 1500, and probably 1800's). It does not hurt anything. If you center stand you cycle it will never happen. but all Goldwing's are known to let out a puff of smoke if left on the side stand. The oil may be leaking past your piston rings and not your stem seals. If you want to change your stem seals you need to put the cylinder on top dead center compression stroke, remove the spark plug, screw in an air hose from your air compressor to pressurize your cylinder, with air pressure hold the valves in place compress the valve springs with a valve spring compressor, remove the parts (washer, cotter keys,and springs), pry off the seal, pop on the new one and reassemble. It is a lot easier living with the puff of smoke, Happy Trails.
Jul 18, 2011 | 1993 Honda GL 1500 Aspencade Gold Wing
Puffs of smoke coming out of the steering column
the problem is your signal light switch circuit board is worn out. Ive replaced that same part cause i was having the same problem. Then i had to replace my steering column for other reasons and now guess what .......MORE SMOKE!.
Sep 18, 2009 | 1992 Pontiac Grand Prix
89 chevy s10 blazer puff smoke out tailpipe when 1st started
A puff of smoke when you start up indicates worn valve seals.That's why all your work didn't fix the problem and it doesn't show a code. It's a pain in the --- job that requires some specialized tools so I guess it depends on how bad it bugs you,if oyu want to fix it.
Jul 13, 2009 | 1989 Chevrolet S-10 Blazer
Wiring problem, puff of smoke came from hazard button
I have got the smoke *** well from hazard button. The fog lights switch was melt.
May 26, 2009 | 2005 Chrysler PT Cruiser
Heard a pop when I started it, now no blower or blinkers
sounds like the ignition switch shorted out like a wire was rubbing and im sure it blew the fuses your going to replace the egnition switch and repair any wire thet is bad and replace the fuse
Nov 14, 2008 | 1992 Dodge Caravan
Hp L1490 monitor
problem in smps output diodes or the output transistor located near the FBT/EHT
mail me ur response @ vishwas_4u@rediffmail.com
Apr 06, 2008 | Computers & Internet
Washer emitting burning smell and smoke on fast spin
Yes, the heating element is coming on when it shouldn't. A likely cause is the pressure pot (Level sensor sender unit) being blocked with sludge. You'll find this under the machine, either screwed to the RH side of the tub, near to the front of the machine secured by three Philips screws, or attached to the side of the big hose that goes from the tub to the pump,secured by a Jubilee clip, underneath the machine. disconnect the power and remove the pressure pot, in both cases it's a long rigid white plastic tube, from one end of which comes a narrow flexible plastic hose which goes up to the top of the cabinet and is attached to the pressure switch itself. This tube is likely to have a load of muck in it, as its bottom end. Clean this out, and if your element didn't burn out, then everything should now be fine.
Oct 28, 2006 | Hotpoint WMA35 Front Load Washer
Danby DWM5500 Front Load Washer Logo
20 people viewed this question
Top Danby Washing Machines Experts
shaun taylor
Samyfam
Samyfam
Gerry Harvey
Gerry Harvey
Are you a Danby Washing Machine Expert? Answer questions, earn points and help others
