Question about Samsung Refrigerators
HOW CAN I REMOVE THE EVAPORATOR TRAY ON MY SR215MW SAMSUNG REFRIGERATOR?
I AM HAVING HARD TIME ON HOW TO REMOVE IT. I AM AFRAID TO REMOVE IT
3 Suggested Answers
  • 135 Answers
SOURCE: removing evaporator tray from kenmore side by side
Can you pull it out the back or the bottom? If not, you will have to remove the filter casing. they are built as if the tray will never break.
Posted on Sep 01, 2009
aviral_srms
  • 1216 Answers
SOURCE: On a Samsung RF266ABPN refrigerator
watch the diagrams here
Posted on Jun 25, 2011
Samsung SRS 535 I have to melt the ice from the drain on my freezer once a month. When I finish it is draining freely into the evaporator tray. One month later it is frozen again.
have you checked to see if the tray defroster works? i would suggest the heater has failed or the hole is partially blocked allowing ice to gradually block up over time.
Aug 20, 2017 | Samsung Refrigerators
Water inside refrigerator
Because your model has an evaporator located inside the fresh food compartment it also will have a drain opening below that evaporator. This is a common problem with these dual evaporator models that have drain blockage caused by ice or gunk blocking the drain and causing water to flow below the crisper drawers. Sea Breeze
Nov 19, 2013 | Samsung RS275AC Refrigerator
I have a pool of water under the cool tray of my Samsung RF26ABRS refrigerator. Can this problem be fixed
Sounds like defrost water drain plugged, you needed to find the defrost drain under the evaporator coil and **** it out and pour some hot water down it. Requires removing a panel so get a tech if you need but its not an expensive repair
Jun 22, 2011 | Refrigerators
My samsung bottom freezer refrigerator makes ice but wont drop it in the bucket. whats wrong?
clean the ice tray hard water depossits some times cause the cubes to stick if it is clean it may be the heater on the bottom of the tray
Feb 21, 2011 | Samsung RB2155 Bottom Freezer Refrigerator
My Samsung refrigerator makes a funny whooshing sound.
Try removing the ice tray and look for cubes jammed between the ice maker and the wall. After I cleared them out the whooshing stopped immediately.
Feb 01, 2011 | Samsung RF265AA Bottom Freezer French Door...
Removing evaporator tray from kenmore side by side
Sep 01, 2009 | Refrigerators
There is water pooling inside the vegetable crisper of my samsung refrigerator #rb215lash.
Your refrigerator has a defrost drain blockage behind the evaporator in your your fresh food compartment. Some models like yours have 2 evaporators. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution in the drain will help you locate the leak and where. I do have the manual on yours and can help you solve this. Let me know, Sea Breeze
Jun 30, 2009 | Samsung RB215LASH
Outside door under water and ice tray is rusting--what to do??? admirial side by side
hi there,
most common ice tray is made of hard plastic materials that hold any defrosted water from evaporator,if rust occured this due residual water dried produced rust,it easy to remove rust,have it wipe bu anti rust remover mc compound,and wash carefully by detergent and water,on have rub it by sand paper w/ smooth size #
if your tray is made of metal,have it anti rust,wipe it out and paint it by epoxy aclyric spray paint,after dry washed by detergent and water in order to remove paint odor.have a nice day.
Apr 30, 2009 | Admiral 26 cu. ft. Side-By-Side...
This unit has a history of problems on the refrigerator side. the basic reset is press and hold down the 2 middle buttons on the freezer at the same time. As a general rule the number one problem is in the mother board. usually you can replace it and everything will work.
David
Dec 22, 2007 | Samsung RS2534 Side by Side Refrigerator
Refrigerators Logo
29 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
