Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
Bosch sgs4072au/36 dishwasher no water washing
Water comes in and pumps out but there is no water washing.
SOURCE: Dishwasher pumps water in and out, but does not wash
Try tilting the machine back 45 degrees for one minute 7 then try one of the programmes. Serousely outr Bosch diswasher was firstly not draining water then not taking in water & another forum suggested this odd manouvre & all is fine now
Posted on Aug 13, 2008
SolutionGuy
  • 331 Answers
SOURCE: bosch dishwasher motor keeps running no water
Hola Lewis!
This is such an easy repair, you'll be shocked and surprised! The reason this is happening is that the computer or timer has detected a "flood" condition and has permanently energized the drain pump to clear the "flood".
What you'll need to fix it...
1.) Shop-Vac (for vacuuming water) with a crevice tool (like one of these)
2.) T20 Torx bit with a driver. Torx sizing here. (You can get a set at Home Depot or Lowes)
All you gotta do now is get down on the floor and remove the kick panel. Then remove the screws holding the water valve and lift it up out of its' plastic holding. Now your shop-vac w/ crevice tool can be used. Stick the crevice tool in there (about 10") and vacuum up all the water that's been trapped in the basin. (you may need a flashlight to see what's going on back in there...) After the water is gone, your DW will work fine.
Here's how it works... About 10" behind the inlet valve is a "float" made of styrofoam. When water gets into the basin, the float rises and eventually trips a "flood condition" switch. This switch shuts the unit down and will only allow the drain pump to operate. So what you want to do is get the water out of the basin.
There may be a reason for the basin flooding, though. Suds (caused by too much (or the wrong) detergent), an actual water leak from the valve, etc... So after you get the water out of there and the unit is working again, you may want to monitor it (like, only run it when someone is home) for a while just to make sure that a real flood does not occur.
Hope this helps.
SG
Posted on Mar 23, 2009
BIKER T
  • 909 Answers
SOURCE: Bosch Dishwasher with very little water pressure or power
It all stems back to your incomming water supply. Either the sieve is dirt or the valve is blocked with sedementation. Some valves are servicable and some are not,if your valve has screws then its revicable. (low water pressure restricts movement on arms.)
Posted on Sep 18, 2009
heatman101
  • 43501 Answers
SOURCE: bosch dishwasher no water coming from arms but not blocked
Here is a tip that I wrote about that....
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Posted on Apr 21, 2010
SOURCE: Bosch sms 4012 dishwasher
hiya,
Can't solve this problem unfortunately but I however have been given a Bosch sms 4012 without the manual and was wondering if you could tell me how to make it go.
Posted on Oct 21, 2010
Is anyone have Bosch dishwasher SGS4072AU/36 user manual?
Search the internet for:
Make + Model + the word "Manual"
or contact the manufacturer.
Mar 16, 2016 | Bosch Dishwashers
Pumps water in don't wash and pumps out again
Not sure whether a schematic will help unless you have some understanding of the location of the components. It would help if you are able to clarify what you mean by pumping in. Usually you should hear the water inlet valve turn on to let water in. Then the wash motor should run to churn the water around and then the drain pump should drain the water out. What is happening is the dishwasher is leaking water as soon as it fills. This causes the flood switch to turn on and that triggers the drain pump to empty the water. Usually Bosch dishwasher have an inline water leakage detector. Check under the sink where water inlet tap is located. There is a device connected through which the water get in. The hose is detecting leakage. Need actual model number of the dishwasher to investigate.
Apr 07, 2014 | Bosch Dishwashers
Bosch classixx dishwasher wont drain
Ive had this happen on mine too. remove the filters in the bottom. squirt washing up liquid into the space-- liberally dont be shy!
Boil pans of water, boil the kettle. pour water into the space where the filters normally are. Fill the base of the dishwasher completely. Next close the door and repeatedly use the Reset feature. Eventually the pump will clear and kick back into life. Its a build up of fats, and sludge that causes the pump to appear to seize--the washing up liquid and boiling water see to that.
Feb 05, 2012 | Bosch 24 in. SGS43C12 Classixx...
Bosche dishwasher serial no, SGS 456 . The machine won't admit water, but it makes all the washing sounds
Are you please able to provide the actual model no. of the bosch dishwasher. The serial no. is not much help.
The reason it may not be admitting water is because the flood switch may be triggered. This means it will not take any more water and the sound you hear is the pump running to empty the dishwasher. YOu will have to find why the flood switch is turning on. Are you using the AquaSafe circuit in the dishwasher inlet circuit? If water is leaking then this circuit will trigger and stop water from coming through inlet. But then you should also get some alarms on the display.
Please provide the model no.
Sep 30, 2010 | Bosch Dishwashers
Our dishwasher is five years old and now it is not
Sounds like you might have a bad water valve. Before you change the water valve, see if the valve under your sink is your problem... Turn it off and and back on to see if it helps. Sometimes hard water will clog the valve. If that doesn't help, you may need to replace the dishwashers water valve. Definitely worth fixing. Hope this helps
Dec 10, 2009 | Bosch 24 in. SGS4072 Free-standing...
Bosch dishwasher model SMU4052UC/14, Won't fill
you need to check the water solenoid valve. if you follow the water line coming into the dishwasher you will find the valve(first spot in the water line with two wires coming from it) if you pull the wires off you should see 110 v when it is trying to fill with water if you do then test the valve for continuity.
May 06, 2009 | Bosch 36 Inch Pyramid Chimney Hood - Black
Dishwasher keeps stoping
Favorite for bosch is the water inlet modual which monitors the water flow in could be faulty, If incorrect pulses take place the motor wont proceed. Otherwise listen for a hum after water stops filling. If there is a hum, the main wash pump is jambed and has to be sorted out.
Jun 08, 2008 | Bosch 24 in. SGV43A03 Built-In Dishwasher
Bosch Excell Dishwasher
drain pump is running all time. cause is a leak. remove bottom front panel and mop out water or can also tilt at 45deg and water shud run out. machine shud then run but you then hav to find leak
Mar 04, 2007 | Bosch 24 in. SHU66C05 Stainless Steel...
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
48 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
