Question about Kyocera Mita Office Equipment & Supplies
Km 2820 copying process was done but gets stuked inside the machine
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
    Problem Solver:
  • 19 Answers
What error code are you getting? It could be a lot of reason for paper to get stuck, there is always a error code associated with each jam
Posted on Nov 23, 2013
Why does the Kyocera KM-3060 Freeze at "Program Loading"
the firmware needs to be updated with the full version overwrite not turbo upgrade
Jul 28, 2014 | Kyocera Km-3060 Mfp Copier Copy Machine...
DIRTY COPIES BOTH SIDE OF PAPER
don't always believe what they say. just because its "supposed to " last a certain amount of time, doesn't mean it will. Once you get the insides dirty, its hard to get them straight again. Sometimes there is build up on the printer head from a leaky cartridge. I'm just guessing cause I had a similar brand that was brand new act up on me and because I was printing bold it started rolling the paper. I put it on economy printing to save toner and after a few runs, it cleared up. plus using a watermark helped but don't think that will help you in your situation.
Sometimes when I get a streak on one side its from light coming in from somewhere and it thinks its part of the image and prints it. If you make sure that your material is flat and not allowing light to come in or its firmly against the glass it might help.
Feb 20, 2014 | Kyocera Km-1820 Copier Fax Machine
Error messgae
sir i have panasonic fax KX-MB2030 call servic 3 error i try #900* 550 but it is not work
Nov 28, 2013 | Panasonic KX-FL611 Plain Paper Laser Fax
Machine is making loud noise and unable to pick up paper to print fax.
the wheels are stuked and work with difficulty better oil it or replace the wheels if they are worn out.
May 02, 2011 | Brother IntelliFax-2820 Laser Fax
Every time i ask for 1 print. the machine pulls a 2nd sheet of paper .the 2nnd one gets jam inside. if i ask a report (1 sheet) it always pulls 2. i blow air in all the sensors,got no effect. im starting...
...I'm starting to think the feed rollers clutch can be the cause..
Yes, it is!
(Dal nome credo che tu sia italiano, dunque il problema sta nel gommino antirumore che si trova sul solenioide presa carta che fa rimanere incollata la leva di sgancio. Basta che lo togli e hai risolto.)
Ciao
Mar 11, 2011 | Brother IntelliFax-2820 Laser Fax
Kyocera KM1820 spots on copy about one-half down horizonally. Do
Based on your discription it is the process unit. The toner cartridge wont cuase spots on this machine.
Feb 19, 2010 | Kyocera KM-F650 Plain Paper Laser Fax
Print Quality Problem with Brother 2820 Fax
sounds like you are using generic drum and toner. try OEM (brother brand). you say copies are coming out completely gray. try printing an internal report from the control panel. if that is gray or received faxes are gray, then the problem is not in your scanner area, and i would wager you are using "generic" supplies.
hth,
razors
Apr 10, 2009 | Brother IntelliFax-2820 Laser Fax
KYOCERA MITA KM-1500 ERROR CODE C7980
C-7980 - Means that the waste tonerresevoir in the process unit is full with less than 100,000 copies onthe unit.
Clean/ empty the waster toner and vac.Also clean the sensor.
You may have to change the Process unit if cleaning does not work.
Mar 02, 2009 | Kyocera KM-1505 Copier
No image
door stuck, must open. check the latches.
check cartridge, have toner in it?
check scanning lamp ( thin strip of glass inside the machine)dirty?
Aug 19, 2008 | Brother IntelliFax-2820 Laser Fax
BLACK PAPER
the scanning lamp is most likely not working\
here is the manual go to the maintenance section to see the scanning lamp
http://www.retrevo.com/s/brother+2820+fax++manual
Dec 18, 2007 | Brother IntelliFax-2820 Laser Fax
66 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
