Onida dvd player optic lens red light is not comeing while the unit is on
2 Suggested Answers
ekcnoel
  • 998 Answers
SOURCE: I had onida black 300
Try to check the connection or cables that connecting your dvd and tv. There may be a loosed connection or or damage plugs.Try to replace a new wire or cable connectors.
Posted on Jul 13, 2011
When I push the select button to DVD I get Err and the red VCR light stays on. The screen displays INCORRECT DISC. What can I do?
Did you try with other disk?
If you get same error for any disk, the optical reader is defective.
You might use an optical cleaner
Cleaning CD DVD or Blu ray or Other Optical Drive
How To Clean Slim DVD Drive Lens and Laser From Dust
How to Clean CD DVD Laser Lens in Computer
Memorex CD and DVD Lens Cleaning Kit
If you don't get any result afterr the cleaning, you've got an electronic issue and should decide if you repair it or buy a new one.
Aug 15, 2015 | Televison & Video
Lost the piece that fits over the lens, won't start the dvd.
Possible that the optical head is damaged and so might need a replacement. If the piece you mentioned has come off the optical unit then the unit is damaged and will not read or pass on information to the processor to run the disc..
Jul 03, 2012 | Insignia IS-PDO40922 Portable DVD Player
Coby TF-DVD 8503 will not turn on, if on video skips and turns off
Optical pickup unit might be faulty. Try by cleaning the optical lens, by inserting a lens cleaning disc into the player and play ti at least 2 times. If this do not belp you; optical pickup unit [Laser reading unit] should be replaced.
Jun 05, 2012 | Coby Televison & Video
You can hear the dvd spinning but no picture or sound.
The optical lens of your unit is dirty try to clean it using a cotton buds but wipe very gently and be sure not to touch the lens. And if still not working the optical lens must be adjust there is a potentiometer under the the optical lens it must be adjust very little turn only if wrong adjustment is applied your optical lens may not work again or you can contact a technician to do it for you. Good day and best regards.
Aug 07, 2011 | RCA DRC612N Portable DVD Player with...
No read dvd and cd
Sir this trouble indicates that the optical lens of your unit is weak or just dirty. Try to clean the optical lens using a cotton buds then wipe it very gently but be sure not to touch the optical lens. Feel free to send feed back good day and best regards.
Aug 04, 2011 | Coby TFDVD7009 7 in. Portable DVD Player
DVD Player is not reading DVDs. when switched on NO DISC prompt appears.
It could be cause by a dirty optical lens. You can try cleaning it by using commercially available CD OPTICAL LENS CLEANER. Just follow the instructions given by the manufacturer. If nothing happen and if still under warranty just bring it back to the store or to the authorized service center. If not try to follow this simple step before you call a local repairman. Sometimes a dirty optical lens cannot clean by a commercially available optical lens cleaner. (1) Unplug the unit from the wall socket. (2) Unscrew the unit to remove the protected cover.. (3) The optical lens is located in the middle section of the CD tray assembly. here is the picture. Never touch the optical lens because it may add more add more damage on the unit. (4) use a cotton buds and a drop of cleaning solution or a drop of water if you don't have... Clean the optical lens but do not push so hard, just enough touch... After you finish cleaning the lens just return the protected cover from its original position... then plug the unit again to the wall socket and try if the problem is solve... Tyhomearceo_0.jpg homearceo.jpg
Jun 28, 2011 | LG Televison & Video
Dvd player goes through the motions then says no disc why
hope you're using a good dvd... but if this is happening more often... just bring it back to the store or to the authorized service center if its still under warranty.... if not, try this simple steps...(1) try to insert a optical lens cleaner cd if available.... (sometimes a dirty optical lens is the cause of the problem...). once you cleaned the optical lens try to insert a good dvd... check if the problem is gone... if not (2) unplug the unit from the power supply socket. (3) remove the protective cover.. (4) plug the unit again to the power supply socket again. but please be careful not to touch the electrical circuit of the unit...(5) insert a good dvd... check if the dvd is spinning normally?... if not or too slow maybe the problem is the motor... (6) check if the optical lens is flashing a red light... if not, check the ribbon wire. check if its not broken... sometimes a broken ribbon wire may cause the problem. (7) if the the optical lens is flashing and the cd or dvd is spinning too fast than the normal speed, and the optical lens is moving back and port, and you hear a noisy sound like skipping. then the problem is the ptical lens... ty
Jun 18, 2011 | Toshiba Audio Players & Recorders
I have a Toshiba DVD Video Player Model SD 260. I
Hello, The problem could be dirt on the surface of the lens, you can clean this by removing the cover of the dvd player . Gently use a dry cotton bud to clean the lens because the lens is fragile. Insert the disc plate into the dvd player and press play, if it does not play try the second method. Ensure the cover of the player is open, connect the power plug to the mains socket and observe the lens if it beam a red light, Also check the ribbon cable use to connect the lens to the printed circuit board, then gently clean the lens with a dry cotton bud , insert the disc plate and press play to see if it play. If it does not play the disc, then this require a change of the lens
May 20, 2010 | Televison & Video
I have onida dvd modal no. is dfx-2000. it having
Plz change ur dvd player bcz it was 2 old
Jul 18, 2009 | Televison & Video
Unit plays DVD but no longer Blu Rays
That is because of a dirty or defective lens. When lens is dirty, the unit may still operate on regular CDs and DVDs and not be reading BD.
Try first using a lens cleaner for Blue Ray: Maxell 190054 Blu-Ray Lens Cleaner
If that does not work, the unit may be disassembled, and lense cleaned with q tips and isopropyl alcohol or cleaning solution. See below:
How to Clean the Laser Pickup Lens on your DVD Player
How to safely clean a DVD lens?
Clean DVD lens, or replace player?
Clean CD or DVD ROM lens with a brush?
Cleaning your DVD drive
How to clean a DVD player
How do I clean my DVD player optical lens isoproponol alcohol
Being this a blue ray unit , I would suggest calling support instead of disassembling the unit by yourself.
Regards
Feb 08, 2009 | Samsung BD-P1400 Blu-Ray Player
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
