Question about 3Com 3C16985B /REF3COM SSII 24-PORT SWITCH (3C16985BREF)
Link and activity lights on 3Com Switch ports without connection
I have this problem with three 3Com switches. There are link and activity lights on ports that have no cable connection on them. The lights remain on and blinking even when I remove the RJ45 plug. how can I repair the switch.
  • 47 Answers
Do the ports work when the cables are connect?  I did some re-search and this seems to be an ongoing issue with 3com switches.  It should not effect the use of the switch
Posted on Oct 27, 2007
3com Switch Intermittently Losing Connection.
this could be a problem with the second switch unit. what happens if you connect a pc to this cable, is that intermittent, if so, that is your problem. try fault finding with a LAN cable tester to see if there's any issue with the link cable.
Jul 16, 2013 | 3Com Baseline Switch 2024 24-Port...
HI, I have two 3com patch panels 3C17302 Superstack 3 Switch 4250T, connected to a switch panel. One of the patch panels does not work e.g. the connected pc's are not able to have Lan connection. Only...
I don't know anything about these units, nor do I have time to source any docs for you, but maybe you can try connecting a PC directly to the port your patch panel is connecting the the switch from, you can at least see if that port is working.
My next and only other suggestion is to invest in a "LAN cable tester". In my area, you can find cheap ones for U$20.
The tester will allow you to check connectivity between any two ports, and allows you to test both patch links and individual CAT5/6 cables.
Nov 22, 2017 | 3Com Computers & Internet
3Com Baseline Switch 2024 - Switch - 24 ports duplex light blink continusly
Is it hsappening with all the 24 ports or with some ports ?
Might be an indiacation towards the duplex mismatch.
are you getting CRC errors on the interfaces ?
Dec 05, 2010 | 3Com Baseline Switch 2024 - Switch - 24...
I have a 3com 4500 connected to 2 5500s (A & B), which are the the GWs for the 4500. I issued on the 4500: ip route-static 0.0.0.0 0 192.168.0.254 preference 60 (5500 A) ip route-static 0.0.0.0 0...
From your scenario what i guess is the two 5500's (A&B) are connected to each other also. Thats why the link between B&4500 is remaining down due to STP ( to avoid Network loop).
Please correct me if I am wrong.
What is the status of the link connecting 4500 to 5500 B when 500A is active and when 5500A is down .
If you are running STP i will suggest you to wait for 2 minutes after 5500A goes down and STP will be recalculated and the link connecting to 5500B will become active and then the route will also become active.
Best regards
Nov 02, 2010 | 3Com 4500 24-Port Ethernet Switch
Connecting a 3Com 2952 Plus switch to a Cisco 3750 switch
If you also have a standard copper cable (or a second fibre cable) connecting the two switches (for resilience perhaps?), this issue is probably being caused by something called Spanning Tree. This is implemented on switches as a 'loop avoidance' system, and can look like you have described with one end 'ip' and the other end no lights.
On the Cisco switch, get to a telnet/ssh/console session, log in and enter show spanning-tree and press enter.
have a look to see if the fibre interface has a status (sts column) of BLK. If it has, then this is called 'blocking' and will remain like that until you remove the second link to the other switch.
Hope that this has helped!
Mar 03, 2010 | 3Com 3CSFP91 Transceiver
Uplinking Using Gig Copper
hello, use the plugin modules for the rj 45 connection port to uplink it.
Aug 04, 2009 | Computers & Internet
CONNECTIVITY PROBLEM WITH 8 PORT D-LINK SWITCH FOR MORE THAN 3 PC
First thanking to using d link switch
Tell me Your dns
and using pppoe ya proxy
KETAN PATEL
Mar 11, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
I cann't connect to my switch
The primary connection method for those switches would be serial connection. In the box there should have been a DB9 serial to RJ45 cable. Hyperterminal default settings would allow you to connect.
Jul 25, 2008 | 3Com 4500 24-Port Ethernet Switch
Enter the switch configuration
page 22 of the 3com user guide for your switch talks about how to use the console cable and how to connect to your pc, I included the link below for your manual, if you don't have it:
http://support.3com.com/infodeli/tools/switches/baseline/3Com_Baseline-Switch-2916-2924_User-Guide.pdf
Jun 18, 2008 | 3Com Computers & Internet
D-Link Switch
well in your case, somethings wrong with your switch, because it doesnt work in a full scale operation, it will just work for 20 mins, well, theres no existing kind of performance like that.
you better replace that one with another brand. well, you try to use 3com or CISCO, well you could use linksys, its from CISCO but catering the small business side.
Mar 13, 2008 | Computers & Internet
Computers & Internet Logo
1,085 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
