Question about Baby Lock Ellure
How di i turn off speed controller mode - Baby Lock Ellure
  • 20 Answers
In the Setup pages. Power on your machine. Press the Settings tab. Arrow (>) through to Width Control ON:OFF. Select ON
Posted on Dec 06, 2013
My Bernina 730E is varying in speed even though I am pressing foot pedal to thr floor. The speed does not stay steady, somestimes running extremely slow in full speed mode. What is wrong?
it could be pedal control or the speed control unit on the motor as it is reasonably common for that machine
take it in for a service to ensure that other factors ( thread around bobbin shaft, fluff etc is not slowing the machine
Nov 01, 2016 | Bernina Sewing Machines
I was given a brother cs-8150. The manual says it will operate without foot feed. I tried to use auto sew and machine tells me to change speed controller mode to off. Where do I do that.
Not able to find any online instructions for your machine, so here goes. There may be some confusion as to what foot feed means.
I believe foot feed refers to the feed dogs. When you disable the feed dogs (drop them), then you must manipulate the fabric manually--used mostly for darning or free motion quilting. In essence the feed dogs are no longer moving the fabric for you. Instead, you manually move the fabric and control the speed at which it stitches with your foot control. Perhaps that is why you need to turn off the speed control because you will determine the speed with your foot.
Foot control refers to the foot pedal that you use to control the speed that the machine sews (much like the gas pedal in your car). Some machines have the ability to sew without the use of a foot control unit. To do so, there is usually a button or lever somewhere to start and stop the machine. When activated, the machine will continue to stitch until you stop it.
Hopefully this will help you find a resolution.
Mar 28, 2016 | Brother Sewing Machines
What is the difference between a variable and non-variable speed sewing machine foot control?
variable foot control==the farther you push it...the faster the machine goes....
non variable....only has stop...and run....
Jun 05, 2015 | Sewing Machines
Baby lock elizabeth how do you turn the speed controller mode to off
The slide switch with arrows towards the top is what will do this.
Apr 28, 2015 | Baby Lock Sewing Machines
Change the speed controller mode to off
Touch the icon at the bottom of the screen that looks like a sheet of paper. The screen that pops up should have a slider icon in the upper right. You can set it to stitch width or speed control.
Nov 23, 2013 | Baby Lock Ellure
When I step on one side of my foot pedal the machine works, but pressure on the other side does not turn the machine on.
That foot pedal had a feature of High speed on one side of the pedal and low speed on the other. Either your speed control unit inside the pedal is slightly burnt or the spring inside the pedal has moved out of position slightly. Even dirt could be the culprit if it found it's way into the speed control unit inside the pedal.
Oct 07, 2009 | Husqvarna Viking 1
I need to know how to thread a bobbin?
TRY THIS, itma not be your model, but should help Title:
ac093.jpg Pre-tension disk ac094.jpg Bobbin winder shaft ac095.jpg Bobbin
1. Pull up the spool pin as far as possible, and then put a spool of thread on this pin. windingbobbin_a0991.jpg
2. Pass the thread around the pre-tension disk. Make sure that the thread passes under the pre- tension disk.
windingbobbin_a0992.jpg ac098.jpg Pre-tension disk c_b4.jpg Pulling it in as far as possible
Caution If the spool of thread is not in the right place, the thread may tangle on the spool pin.
3. Pass the end of the thread through the hole on the bobbin from the inside of the bobbin. windingbobbin_a0993.jpg
4. Put the bobbin onto the bobbin winder shaft and slide the bobbin winder shaft to the right. windingbobbin_a0994.jpg
5. Turn the bobbin clockwise, by hand, until the spring on the shaft slides into the groove of the bobbin. windingbobbin_a0995.jpg ac099.jpg Spring on the shaft ac0991.jpg Groove of the bobbin
7. While holding the end of the thread, gently press the foot controller or press start/ stop button (for models equipped with the start/stop button) to wind the thread around the bobbin a few times. Then stop the machine. windingbobbin_a0997.jpg
Note
  • If the sewing machine is to be operated using the foot controller, connect the foot controller before turning on the machine.
  • When the foot controller is plugged in, the start/stop button cannot be used to start sewing (only for models equipped with the start/stop button).
Caution Make sure you follow the instructions carefully.
If you do not cut the thread completely, and the bobbin is wound, when the thread runs low it may tangle around the bobbin and cause the needle to break.
9. Slide the sewing speed controller to the right (to set the speed to fast).
(For models equipped with the sewing speed controller.) windingbobbin_a0999.jpg ac0992.jpg Sewing speed controller
10. Press the foot controller or press start/stop button (for models equipped with the start/stop button) to start. windingbobbin_a18.jpg
11. When the bobbin seems full and begins spinning slowly, take your foot off the foot controller or press start/stop button (for models equipped with the start/stop button). windingbobbin_a19.jpg
12. Cut the thread, slide the bobbin winder shaft to the left and remove the bobbin. windingbobbin_a191.jpg
13. Slide the sewing speed controller back to its original position (for models equipped with the sewing speed controller). windingbobbin_a192.jpg
Caution Not winding the bobbin properly may cause the thread tension to loosen, and may break the needle.
woundbobbin3.jpg ac0993.jpg Wound evenly ac0994.jpg Wound poorly
Note
  • When the sewing machine is started or the handwheel is turned after winding the thread around the bobbin, the machine will make a clicking sound; this is not a malfunction.
  • The needle bar does not move when you slide the bobbin winding shaft to the right.
Sep 02, 2009 | Brother LS-2125 Mechanical Sewing Machine
Foot controller stays in slow speed mode -- won't go any faster -- but did previously
it probaly is worn out or bad contact, as described it needs to be replacedor cleaned
Jul 17, 2009 | Sewing Machines
Sewing Machines Logo
133 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
SewTechWayne
SewTechWayne
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
