Question about Dryers
Dryer rattles dryer runs and over heats in a few minutes. make a whining noise but the drum turns. then it will shut down
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
Sometimes a blower wheel will become worn out on the motor shaft and just spin freely cusing very noisy and no air movement causing overheating
Posted on Nov 23, 2013
docjohn174
  • 943 Answers
SOURCE: Kenmore 80 series dryer.
thanks for the question The noise might seem like its from the front but theres nothing at the front Now at the back you have 2 drum kollers By the motor you have aidler pully most times the idler is the problem you can buy a repair kit that comes with all the parts you need to fix noise belt , 2 drum rollers and idler pulley .replace them all . Thanks for the question The appliance doc
Posted on Sep 11, 2008
huuum
  • 750 Answers
SOURCE: KENMORE DRYER
Hello ENRIGHT11 Welcome to Fixya
My name is Huum,
You said,
DRYER MAKES VERY LOUD NOISE WHEN RUNNING. ALTHOUGH IT HEATS UP AND BEGINS TO DRY, IT STOPS RUNNING COMPLETELY AFTER ABOUT 5 MINUTES. IF YOU WAIT AN HOUR, YOU CAN START IT AGAIN, BUT IT AGAIN SOUNDS VERY LOUD (ALMOST A RATTLING SOUND) AND THEN SHUTS OFF AFTER 5 MINUTES
Faulty Blower Wheel
If you hear a great deal of noise coming from the blower area of the dryer when it is running, then the blower wheel could be defective.
The are many different designs for blower wheels and just as many unique failure modes. Vanes (fins) can break off the wheel and bounce around in the blower breaking more pieces. The blower can break around the coupler with the shaft. This can cause the blower to spin loosely on the shaft. The blower can form cracks which cause it to vibrate, etc.
You should also not be surprised to find foreign debris in the blower. The occasional bird, rodent or squirrel has been known to bypass the out vent cover. If they crawl into the exhaust tube the first thing they come into contact with is the blower wheel.
If the blower wheel is not spinning, or if it is missing vanes, it is not moving air efficiently. As a result, heat is not removed from the heat source and it can trip the high limit switch or blow the thermal cut-off.
Worn Belt
A worn belt can stretch and/or become brittle with age. The belt can then slip on the drum or motor to cause squeaking. If this is the case, the solution is to replace the worn belt.
The belt is not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, worn drum glides or worn drum rollers depending on brand and style.
When replacing the Belt is is a good idea to also change the Drum Support Rollers, Drum Glides, Idler Pulley and Clips. All of these items are economical easily changeable when replacing the belt. The upside is that your dryer will operate like new.
Recent Customer Symptoms:
Dryer makes loud noise when turned on. Dryer works and heats up OK but makes too much noise.
Worn Drum Glides
Some dryer models are equipped with Drum Glides. The front of the dryer rests on these glides. They provide a low friction surface on which the drum spins. After time however, this glides wear down. Much like an automobile brakes, these glides make a load grinding noise when they wear thin. This griding against the drum usually leaves a bare metal stripe that is visible at the point of contact. If the glides are worn, the solution is to replace them.
The drum glides not the only items that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, a worn belt or worn drum rollers depending on brand and style.
When replacing the Drum Glides it is a good idea to also change the Drum Support Rollers, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new.
Worn Rear Drum Bearing
Some dryer models are equiped with a Rear Drum Bearing. The rear of the drum rests on this bearing. It provides a low friction surface on which the drum spins. After time however, this bearing will wear down. If the bearing is worn, the solution is to replace it.
The rear drum bearing not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum glides, a worn belt or worn drum rollers depending on brand and style.
When replacing the rear drum bearing it is a good idea to also change the drum glides, drum support rollers, drum belt, idler pulley and clips depending on make and model. All of these items are economical and easily changeable when replacing the rear drum bearing. The upside is that your dryer will operate like new.
Worn Drum Support Rollers
Some dryers such as Whirlpool/Kenmore brands are equipped with Rear Drum Support Rollers. The weight of the dryer drum rests on these rollers. They provide a low friction surface on which the drum spins when in operation. After time however, these rollers wear down. When they wear, often times they begin to elongate and form a non-round 'cam' shape. The result is that when the dryer is turned on it creates a rumble that sounds as though you are trying to dry a pair of tennis shoes. This sound is usually the drum being forced up and down on the non-round wheels. If the rollers are worn, the solution is to replace them.
When replacing the Drum Rollers it is a good idea to also change the Front Drum Glides, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new. Whirlpool
Kenmore models have a dryer maintenance kit that contains all of these items in a single kit.
Thank You For trusting us with your question
Please remember to leave a
solved rating before you leave!
Posted on Jan 23, 2009
barkencoa
  • 3463 Answers
SOURCE: tumble dryer makes whine noise but doesnt spin
Sounds like the drive belt has gone,and the noise you can hear is the motor going round.
The red glow you can see, will be the heater element glowing..
To check the belt, remove top cover, and you will be able to see if the belt is on or not, if you can see it round the drum, try to lift it up, if it has not broken,then you will not be able to remove it, and that means the motor or drum could be siezed, try to turn the drum by hand, it should be fairly stiff to turn, but not that stiff that you cannot turn it at all.
Please rate my fixya solution.
Thanks.
Posted on Feb 01, 2009
  • 63 Answers
SOURCE: Dryer runs for a few minutes, then shuts off
thermo sensor inside is bad (are you sure ALL vents and pipes are clear?)
Posted on Mar 13, 2009
  • 12 Answers
SOURCE: Gas dryer Amana Model LGA30AW, rattling noise, no heat.
I was experiencing a similar problem. I just repaired mine yesterday, with the help of this web site. Remove the front bottom panel. The are two screws located on the bottom of the panel. They are there, just slightly hidden. Turn on dryer to heat. Look inside where the panel was. Wait a minute or two and you will see the igniter glow. After a minute or so you might hear a click and the gas valve will open to start flame. After a while flame will go out until it cycles again. If your igniter glows and you hear the rattling noise and then the igniter glow goes out and you have no flame, it might be your solenoid coils are bad. These are the two black round things located on top of the gas valve. Make sure your gas dryer is unplugged. There is a wire clip attached to each solenoid. Unplug them. I needed to pry them off carefully with a flat screwdriver. There is a metal bracket holding those two solenoids in. There are two screws that you will need to remove the bracket. Use a flashlight to see them. Slide them up and off the gas valve. One is a 2 prong and one is a 3 prong. I bought a new set for 26.75. Put the new ones back the same way as you took them off. The is little nips on the top of the solenoid that line back up with the holes of the top bracket when reassembling them. Plug your machine back in and turn on and watch to see if the ignitor glows again and watch for the flame. Put panel back on and enjoy dry hot clothes again. GOOD LUCK
Posted on Sep 18, 2009
My tumble dryer is making a loud banging noise when it turns. It is on for a few minutes and seems to happen when it switches to turn the opposite way
It will be worn slipper pads that are around the front edge of the drum. If your dryer can run when inverted that will stop the noise until the pads wear down again.
Purchase some new slipper pads and remove the back panel of the dryer moving the drum back about 1 inch. You will now see were the slipper pads are fitted around the inside edge at the front.
There will be about 6 of them, you can take the top ones and move them to the bottom. This will also stop the banging until they also wear down.
Oct 24, 2015 | Dryers
Kenmore 700 series Dryer shuts down after a few minutes in heated cycle, runs forever with no problem in Air Dry (no heat) mode, I disassembled the entire machine drum, motor, vents and removed every spec...
Brian, look inside your drum for some curved strips of metal that may be 6-8 inches in length. There may be two of them that run parallel to each other about half an inch apart. This is your moisture sensor. If you use dryer sheets like a lot of people do you may have an issue where there is a build up of residue from the dryer sheets on the sensors. Take some rubbing alcohol and some cotton balls or a rag and wipe down the sensor strips. If they come back blue in color there is build up on the strips. Keep wiping down until you no longer get any blue color. That build up can make the dryer think that the clothes are dry and shuts the dryer down. Hope this helps, I have done this on a couple of different dryers and it made a big difference.
Mar 18, 2014 | Kenmore Dryers
Does not get hot
As the clothes gently toss about inside the drum, a temperature control thermostatic disk regulates the heat. It is set for 160f for cotton and it mounts on the blower housing. As air is drawn into the drum and out the backside of the dryer the heat is regulated by this control. It sends 120 volts to the gas assembly. Right next to it is a fuse. The duct fuse is set to blow at 250f. Should that control fail to open and allow for heat to build to abnormally high temps. Note: the fuse will kill the heat source only on most dryer, the dryer will however continue to run. Lint and vent blockage can restrict the airflow and make the heat inside build to dangerous levels.The control thermostat powers up the heat for a minute then shuts down for a few minutes, then repeats this all throughout the drying process, the gas does not stay on! That would burn the clothes. If both of those items check ok and the dryer vent and lint has been cleaned, I next take a look at the gas assembly. I check the flame sensor first. If the flame sensor is open the ignitor will not glow. If that turns out to be good I next check the ignitor itself for continuity. If it turns out to be good I replace the coils. Those coils cannot be checked because they do not act up until energized. Sometimes the coils will work, get hot and fail, cool down and work again. I have some repair photos: HERE
Jan 11, 2010 | Whirlpool LGB6300 Gas Dryer
Dryer won't heat and shuts off
Go get you a new thermostat or have the appliance guy fix it under warranty.
Oct 26, 2009 | Kenmore 84152 Electric Dryer
My Maytag gas dryer makes a loud rattle and clanging noise.
Prob. some failure of a bracket or loose inside...
Have a local tecnician check it out.
i think that ll be best cause i can't imagine that will be an easy fix.
I hope this is useful, and greets,
Olivier.
Oct 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Aug 09, 2009 | Amana ALG331RAW Gas Dryer
DRYER RUNS TEMPERARILY WITH WHINNING NOISE THEN SHUTS OFF.
take off front of the dryer the drum will fall out clean drum and replace belt
Feb 10, 2009 | Whirlpool LER5636P Electric Dryer
KENMORE DRYER
My name is Huum,
You said,
Faulty Blower Wheel
Worn Belt
Worn Drum Glides
Jan 21, 2009 | Kenmore 63942 Dryer
Dryers Logo
46 people viewed this question
Top Dryers Experts
