Hdm 111bk Koss speakers
Will not show up in "Playback Devices" i might need a driver can anyone help find me one?
5 Suggested Answers
Open SKy
  • 620 Answers
SOURCE: Need a wiring diagram for connecting KOSS HD 50 COmputer speakers
Hello there! lellya
First,
1) you have to tell , what kind of sound card you got? on board audio? A7, or Creative Audigy? 5.1 or regular.
2) then, you have to connect one speaker to the other, one two way connector cable, for the 2 KOSS speakers.
3) another cable that goes in back of your koss and from the out of your KOSS Speakers to the input of your sound card, at back of your PC, this input is your sound card jack.
4) its supose to work like so.
good luck
Posted on Oct 17, 2008
Luisjhernand
  • 84 Answers
SOURCE: Digidesign MBox 2 micro doesn't playback sound from windows vista
make sure that windows recognizes it on your hardware devices...right click on My Computer and go to properties...clck on the hardware tab and click on Device Manager....makes sure that all Yellow Exclamation points are resolved and that windows has installed their drivers etc by clicking on them and updating driver...you may need to specify the location of the drivers whether they are on disk or on your computer somewhere...after this is done...try going back into the sound properties and seeing if the newly installed device is coming up...
Posted on Apr 08, 2009
bronk50
  • 27725 Answers
SOURCE: i have installed sound drivers but no sound is
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Posted on Oct 05, 2010
  • 161 Answers
SOURCE: Hi. I have an amplified
need to install the audio driver of your computer...
Posted on Jul 25, 2011
I am running windows 7 ultimate, using a p5q pro mobo with realtek onboard sound, or lack there of, tried all manner of drivers, none work, so i bought a sound card, a creative 5.1 vx...still have the same...
click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to
be updated if you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers
right click on the speaker icon in the bottom taskbar select playback devices make sure it has a green tick and the correct speakers are selected
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker
you might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down
list in the advanced tab select dvd quality or another then apply
hope this helps you W7
Mar 22, 2012 | Logitech LS-21 2.1 Speakers
Have Koss hd-50 (hand me down) would like a diagram, have no sound, running winxp on dell xperion 8400, says "no active mixer devices"
i will go through the process of setting up sound on your computer
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
if you need more help with this post a reply
hope this helps you
Sep 21, 2011 | Koss HD 50 Computer Speakers
Hi the sound in my speakers is reallllly low and i can't turn it up with the volume button like i used to, is there a wire missing or something ?? really annoying.. :S
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
Sep 15, 2011 | Koss HDM 11 Computer Speakers
Wiped my hard drive and lost my drivers
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers if you dont have a motherboard disk or the drivers you will need to download them
this driver package will support a multitude of devices
http://download.cnet.com/%7Bvalue=http://www.download.com/agfxy00-exe/3000-2122_4-120567.html
  • ESS Allegro PCI Audio (WDM)
  • ESS Allegro Sound Blaster Compatible (WDM)
  • MPU-401 Compatible MIDI Device
  • hope this helps
    Jun 30, 2011 | Koss HDM 11 Computer Speakers
    My computer has no sound driver after installing windows 7
    If you have a sound icon(speaker symbol) in your toolbar, right click on it. Click on " playback devices", a window should come up. If nothing is in window then right click on it. See what you have. If nothing comes up, Right click on playback devices again and click on disconnected devices. If you have drivers show up when you click playback devices,right click on the one you want to use. See if there is an option to "enable". Click enable and see if this works. You can also check in Control Panel under sounds or, in device manager, under audio/playback devices.
    Mar 05, 2011 | Computers & Internet
    Speakers are plugged in and power is on but no sound
    Could be a couple of things.
    Step 1. Check to make sure the speakers are plugged in all the way into the aduio jack.
    Step 2. Ensure the audio cable is plugged into the correct audio port.
    Step 3. Check to ensure that the speaker knowb is turned up.
    Step 4. Check to ensure that your volume on your computer is turned up.
    Step 5. Check to ensure that the volume on your computer is not muted.
    Step 6. Check to see if your Audio hardware is enabled on your computer.
    Apr 22, 2010 | Koss HDM 11 Computer Speakers
    Cano't change from speaker 2 earphones. volume on speaker alltime
    It is a conflict of drivers in some PC's.
    First make the sound device to speaker as default.
    1. Click Start, type Sound in the Start Search box.
    2. Click Sound in the search results at the top of the Start menu.
    3. Click the Playback tab. Notice the check mark next to the default device. For most users, the default device is Speakers. Make sure that your audio settings are configured as expected.
    4. On the Playback tab, select the playback device, click Configure, and then make sure the configurations are set correctly.
    5. In the Playback tab if you are unable to find the Speakers then please right click on any of the devices under playback tab and select Show disconnected devices and Show Disabled devices.
    6. Select Speakers, and then click Set Default. (If you find Conexant or anything similar to that click on it and select Set Default)
    7. Click OK to save your settings and to close the Sound dialog box.
    If speaker is set as default, then re-install drivers.
    Uninstall the Sound device:
    1.Click Start, and in start search type device manager and press enter.
    2.Expand sound,video and game controllers, and right-click on the Sound driver and choose uninstall.
    3.Check the option for delete the device software for this device.
    4.Now restart the computer and boot into normal mode.
    Now, uninstall the programs and features:
    1.Click Start, and in Start search type programs and features.
    2.Choose the audio application and click on Uninstall.
    3.Restart the computer.
    Upon restart, install the audio driver from the disc which is given by manufacturer of the computer.
    Please let me know if this works.
    Regards,
    Nags
    Jan 27, 2010 | Computers & Internet
    Let's play "Jeopardy".
    Alex, let's take 'Squares' for $1000.
    Alex: 123
    What is the square-root of 15129?
    Alex: correct! Choose again.
    Jan 07, 2010 | Koss HDM 11 Computer Speakers
    They wont give out sound there plugged into the front of the computer and in the outlet plug in BUT IT WONT WORK :( help
    Be sure to plug into the "green" socket on the front of the computer, not the "pink" (microphone) or "blue" (headphone output from iPod) socket.
    Try the speakers in the "green" socket on the back of the computer, to ensure that the speakers work, and the volume control is "high", and that you have not "muted" your speakers.
    Some motherboards have a small "jumper" to enable/disable the front audio-output sockets.
    Try the speakers when connected to the headphone-output from your iPod, to confirm that they work -- they could be quite quiet.
    Nov 25, 2009 | Koss HDM 11 Computer Speakers
    Televison & Video Logo
    Top Televison & Video Experts
