Question about Brother IntelliFAX 560 Plain Paper Fax
I need help with a fax machine
When trying to fax to people it acts as though its going thru, but then they get a message saying line error. what do i need to do or is the fax machine broken
  • Brother Master
  • 1,113 Answers
Sounds like you may have a noisy phone line, incorrectly set transmission level or no filters installed if using broadband adsl service, also pick up phone is it free of any background noise or crackles? (tel phone company or cable problem if noisy)
In australia there is a service for test fax level across phone line called FOLDS (Fax online diag service) maybe your carrier have one too so you can test?
Posted on Oct 17, 2007
MY HP Fax machine won't send fax, sends error what is wrong with the machine it's a 2007 Model 1040. when I am sending the fax after one page it beeps a lot and then feeds the rest of the pages. then on...
You either have a noisy or Digital phone line.
Have your phone company check the line.
I have NEVER seen a bad fax modem, unless it was fried by a lightning strike.
Apr 28, 2010 | Office Equipment & Supplies
Magic Jack quit transmitting, but receives on Brother 775 fax
wheneva i start ma magic jack it say connect to internet an put password its says correct but thn again its comes again connect to internert.... an password an email id... but pls help me in tis..??
Jan 07, 2010 | Lands Phones
Intermittently, the confirmation page on the fax says the fax failed (didn't go thru) but it actually did. Why is this? The confirmation page is printing false results, indicating the fax failed to go...
This is because some faxes don't have Error Correction Mode capabilities.
If there's a slight distortion on the line, the receiving machine (without ECM) receives a fax with some minor errors. And even though for a human eye the resulting fax page is perfectly readable, for the machine, that thinks only zeros and ones, there was an error detected in the data, and hence the trasmission failed.
Faxes with ECM when they detect an error, ask the sending fax to re-send the last portion of data, and this way can bring the transmission to a 100% successful end.
So the only thing you can do is ask your recipients to upgrade their fax machines to an ECM-capable model :)
Oct 29, 2009 | Canon Office Equipment & Supplies
When machine was moved from one line to another it now gives a "handset" error message in the window constantly after you try to dial in a number and use the fax machine; the communications tech. says it...
Your fax tech is correct. There is another device on your fax line such as a credit card machine, a postage meter, computer, etc.
You should have a dedicted analog phone line for your fax machine.
Oct 12, 2009 | Ricoh Aficio 1515F Plain Paper Laser Fax
Using MagicJack for faxing; however, Brother MFC 290C is stating poor line condition - why? Also say's low ink Magenta - would that create this problem?
I had the same problem trying to send out faxes out using my Brother MFC 7340. I use a magic jack phone line. Page 106 of the user manual says if sending via VOIP phone line, you should press menu, then 2, 0, 1 to select "Basic (for VOIP) mode. Then press ok. Then press stop/exit. This cuts the modem speed down to 9600 bps and turns ECM off. Then retry to send the fax. I did that and can now send and receive faxes.
Jun 06, 2009 | Brother MFC 420CN All-In-One InkJet...
There may be some static on the phone line, try a line filter. If possible, you could plug the fax into another working telephone line, and have someone send a fax to that number (whatever number is attached to the new phone jack) to isolate whether or not it is the machine, or the wall jack.
May 20, 2009 | Samsung Office Equipment & Supplies
Error message 421*
error 421:
A handshaking error has occurred at some point in the process from the fax that originated the fax.
* Try the fax at a different time when telephone line conditions have improved.
In some cases this error can occur if the other fax machine is using a fax format incompatible with the HP fax.
- you can try to set the FAX SPEED to SLOW
you can locate this on ADVANCE FAX SET-UP...
Aug 13, 2008 | HP OfficeJet 6210 All-In-One InkJet...
X5495 wont receive a fax - can send one though..
that means that the fax machine on the other end, can't read your handshake from lexmark. Happens. has the drivers you'll need by model and operating system
Aug 07, 2008 | Lexmark X5470 All-In-One InkJet Printer
Hi, Remote Fax Error being displayed
What happens if you dial the remote fax number as a voice call on another phone? Does that number pick up? Does it give you the modem handshake noise? If not, the remote side has a problem.
Can you fax other numbers? What happens when you dial your own fax line from another phone? If your fax does not pick up and talk to you, your fax may have a problem.
Jul 24, 2008 | Dell 962 Photo All-In-One InkJet Printer
Brother IntelliFAX 560 Plain Paper Fax Logo
99 people viewed this question
James Cagle
James Cagle
Jim Keysor
