Question about LG WM2101HW 4.0 cu.ft. Washer
Knob turns but does not light up selection - LG WM2101HW 4.0 cu.ft. Washer
How to reset a3 light on 06 Honda odyssey?
Reset the Oil Maintenance Light on a 2005-2015 Honda Odyssey:
  1. Turn the ignition to position "On" without starting the engine.
  2. Press the Select/Reset button until it displays the "oil life percentage"
  3. Then, press and hold the knob until the oil life percentage begins to blink.
  4. Release the knob.
Aug 29, 2016 | 2006 Honda Odyssey
How do i reset my manint req's light after an oil change on a 2003 Honda pilot
Reset oil service light Honda Pilot. From years: 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010, 2011, 2012.
How do you reset oil service light Honda Pilot. From years: 2003, 2004, 2005.
  1. Turn off the engine. Press and hold the SELECT/RESET button in the instrument panel and turn the ignition switch to run (one position before starting).
  2. Hold the button for at least 10 seconds, until the indicator resets.
  3. Turn the ignition off and then start the engine to verify the indicator has been reset.
How to reset oil service light Honda Pilot. From years: 2006, 2007, 2008, 2009, 2010, 2011, 2012.
Resetting the Engine Oil Life Display if maintenance service is done by someone other than your dealer, reset the maintenance minder as
follows:
  1. Turn the ignition switch to the ON (II) position.
  2. Press the select/reset knob repeatedly until the engine oil life is displayed.
  3. Press the select/reset knob for about 10 seconds. The engine oil life and the maintenance item code(s) will blink.
  4. Press the select/reset knob for another 5 seconds. The maintenance item code(s) will disappear, and the engine oil life will reset to 100.
All information is taken from the Honda Pilot owners manual.
Mar 09, 2015 | 2003 Honda Pilot
2010 honda crv how to turn oi life light off
  2. Push the Select/Reset knob repeatedly until the engine oil life is displayed.
  3. Press the Select/Reset knob for about 10 seconds. The information display shows the reset mode initial display as shown.
  4. select the "OIL LIFE" indicator by turning the select/reset knob. The display begins to blink. Push the same knob to enter the setting.
  5. The engine oil life and the maintenance item code(s) will begin to blink. Press the Select/Reset knob for another 5 seconds.
  6. The maintenance item code(s) will disappear, and the engine oil life will reset to "100."
Oct 19, 2013 | Vehicle Parts & Accessories
Demo not turning off
Press the volume knob to bring up [FUNCTION]. Turn the volume knob to select [DEMO MODE] and press the knob. Turn the knob to select [OFF]. Press the curved arrow button to the left of the knob to set it.
If you need a manual you may download a copy here. Demo mode instructions are on page 6.
Aug 15, 2012 | Car Audio & Video
How do I turn off the demo mode in my jvc kd-hdr44 radio deck?
Press and hold MENU. Turn volume knob to select group, press volume knob to select item, turn volume knob to select, and then press volume knob to save.
Mar 01, 2012 | JVC Car Audio & Video
How to turn off the swicht of need maintenace
I assume you are talking about resetting the light:
Press and hold the Select/Reset knob (odometer) in the instrument panel, then turn the ignition switch to ON (II).
Hold the knob for approximately ten seconds until the indicator resets.
Hope this helps you.
Jan 01, 2010 | 2005 Honda Civic
Maintenance required light just came on and I have
1. Turn off the engine. The car should not be running when performing these steps.
2. Press and hold the select/reset knob. This knob is located on the instrument panel. It will be sticking out on the bottom right of instrument panel. It's the same knob that is used to reset the trip mileage or change what is displayed in the mileage/temperature box.
3.While holding the knob, turn the ignition switch (the key) to on (II) position. Continue holding the knob for approximately 10 seconds. The MAINT REQ'D light should turn off.
Oct 11, 2009 | 2004 Honda Accord
How to turn off maintenance required light
Information courtesy of: synthetic-direct.ca
To reset MAINT REQ’D light, press and hold select/reset button on right side of instrument panel. Turn ignition on and hold until the light goes out.
Best of luck.
Greg
Jul 28, 2009 | 1999 Honda Accord
Cd player clock settings
Press and hold SEL (select) button on left for 3 seconds
Select CLOCK H on the left or right side of the knob on on the right.
Adjust hour by turning the outside of the select knob
Press SEL to lock hour
Select CLOCK M on the left of right side of the knob on the right
Adjust minute by turning the outside off the SEL knob
Press SEL to lock minutes
Press DISP button
Sep 11, 2008 | JVC Car Audio & Video
LG WM2101HW 4.0 cu.ft. Washer Logo
21 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
