Question about Dryers
Replacing switch start on GE front loading dryer with control above
I have a stackable washer/dryer, and need to replace the switch start. I received the part today, but cannot figure out how to install. Do I remove the two screws on the front where all of the knobs are or are they they two in the back? Thanks for you help
  • 11 Answers
SOURCE: How to seperate a Kenmore dryer from the washer under it?
This is probably a model that has two access holes at the bottom front of the dryer -about 4-5" from each side- usually closed off with plastic discs. Just an inch up from the washing machine.  Pry out the plastic discs with a flat screwdriver and you should see a screw inside each of the two openings.  Remove the screws and you will be able to tip the dryer up and slide it back a few inches to detatch from the back.
Use two people to lift the dryer down as it is bulky but not too heavy.
Posted on Oct 12, 2007
  • 2267 Answers
SOURCE: ge gas dryer
Check this site for info:
Posted on Feb 21, 2008
  • 3587 Answers
SOURCE: removing front panel on electric dryer model number 110.66732500'll need to unplug the machine, tip it back a bit, and access those screws from underneath. Do NOT lay this unit on it's back. 45 degrees at most.
and by the way, put something underneath it while working on it.
Posted on Mar 09, 2008
  • 943 Answers
SOURCE: Stackable washer dryer
hi thanks for the question the washer has a separate cord for 110 volts see if its plugged in thanks the appliance doc
Posted on Sep 27, 2008
  • 7 Answers
SOURCE: asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
Posted on Feb 25, 2009
  • 304 Answers
SOURCE: how to get into dryer to convert to LP
Disconnect power. Turn off gas.
Open the door and look along the front upper edge of the door opening. In the top left and right rounded corner of the door opening you will see screws going upward into the top. Remove both screw and raise the top.
Look down inside the open top dryer from above on each left and right edge there will be a screw holding the front assembly to the case of the dryer. Remove 1 on each side.
The dryer front can now be pulled toward you about 3 inches at the top and then lifted off the bottom clips and swung away to the right from the case. Be careful not to strain any wires connected between the case and the front.
This will expose the underside of the dryer along with motor, Gas valve and venting for checking and vacuuming. Be careful of the ignitor. It is very brittle and can be easily broken
Gas service should should be done by professionals only as improper servicing can cause fires, explosion or death from asphyxiation. TEST for leaks after reassembling gas parts.
Perform thorough vacuuming and reverse the above process for reassembly. Good Luck
Posted on Sep 11, 2009
Testimonial: "Thank you...looks like great instructions. I'll try it."
0 characters
1 Points
The machine is not spin after wash, motor pump is work, and for wash is turn one shot left and one shot right and stop,...where is the problem???
Reasons Why Your Washing Machine Won't Spin > News
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
Spin Cycle Not Working on Washer ' ThriftyFun
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
How to fix a washer that will NOT spin ONLY. THE EASY ...
? 3:56
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
Feb 09, 2016 | GE Dryers
Machine won't complete cycle.i was told it was a pump,replaced it and still inop; Any suggestion ?
Your problem likely is in the control panel. Try other settings to see if it is isolated.
Mar 20, 2015 | Frigidaire Front Load Stackable Washer
Stackable dryer replace switch
Drop the splash plate below the front panel first. That reveals screws under the controls. Here is my crappy cell phone video:
Apr 09, 2014 | Dryers
No power to washer, dryer has bpower...
Might be a broken wire going down to the washer portion. I found that once on a stack dryer: Remove the control panel and look for a loose quick connect or broken wire.That was what was wrong with this un I think. Drop the splash pannel first then remove the screws to control and drop it out then check quick connects and wires is what I would do. -PawPaw
Dec 23, 2013 | Frigidaire Front Load Stackable Washer
Error code E70 What is it?
E70 Stuck key Continuous key read for 60 seconds. Power down (unplug) machine, wait 30 seconds and retry. Use t04 test to test keys. Separate control and control housing from front panel - clean and remove foreign debris. Ensure all keys can be operated freely without sticking. Replace control panel if actions do not resolve. Maybe this will help
Oct 27, 2013 | GE Adora Front Load Washing Machine Washer...
I have a stackable washer and dryer. Both have worked fine except recently clothes started getting caught between the drum and the front frame of the dryer. My husband pulled it apart checked the screws...
You may have a felt seal in the front that needs replaced. A wire off the pin switch could be off, and you will see the pin switch when you open the door, and make sure it is clicking.
Jun 22, 2010 | Kenmore 63942 Dryer
Start Switch Broke
Hello Friend, Its easy to replace the start switch on your dryer. Just remove the four screws at top of control panel. You will need a start tip bit to remove the screws. Once removed just pivot the panel towards front of washer exposing the inner backside of panel. Now you can easily remove the screws that hold on the start switch and replace with new one. Happy to help, Tim. Please rate my help to you. Thanks.
Jun 29, 2009 | GE DBSR453EBWW Electric Dryer
Kenmore stackable washer dryer. Dryer buzzer is
Just solved this problem for a Kenmore stackable washer dyer! Sorry I don't have the model number. I have a baby on the way and a small house. I was pretty sure I would get no sleep between the baby crying and the baby crying because of that darn buzzer!
The buzzer is attached to the timer with a quick connect post. Access the controls by unscrewing the large panel above the washer door. You will need a square screwdriver or a very small flathead and some vice grips to get it started. The panel will fall forward onto the washer. In mine there was a pouch with an electrical diagram of the unit. To release the controls, two more screws must be removed from the sides of the small panel housing the controls. Once again you need a square screwdriver or a very small flathead and some vice grips to get it started. Once these are out you should be able to lift the control panel up and it will fall forward. Get a small box or stand to put on the washer. This will support the panel as the wires are not that long. On the left side of the timer controls you will see a quick connect post marked with an "H". Disconnect this wire and your problems are solved. Beautiful silence! I put electrical tape on the quick connect wire. Not sure if I needed to as I'm not an electrician. Hope this helps.
Apr 09, 2009 | Dryers
Dryer trips breaker as soon as i try to start it.
Use or borrow a volt ohm meter and check for a grounded hot wire. You may also be exceeding the start up load on the 20 amp breaker. Test this theory (after you make sure that there are no ground faults) by starting the dryer in a "air fluff" mode without heat. If the dryer starts in the "no heat mode", switch the heat on - if you blow the breaker you know that the 20 amp breaker cannot handle it. Before you do any of the above - check your dryer manual for the service requirments. If you don't have the manual go to the mfg. web site and download it.
Feb 04, 2009 | GE DBXR463GB Gas Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
