Question about RIM BLACKBERRY TORCH 9800 TOUCH SCREEN DIGITIZER with LENS COVER REPLACE
Dust in screen - RIM BLACKBERRY TORCH 9800 TOUCH SCREEN DIGITIZER with LENS COVER REPLACE
  • 3 Answers
If it's really bothering you, you can remove the digitzer and just wipe everything down thoroughly before reassembly. Here's a video showing how to remove the digitizer
Posted on Nov 23, 2013
Dust inside screen
You would have to pull the case apart. depending on your tv you may also have to remove the lcd panel.
Nov 13, 2013 | Hitachi 42PD7200 42 in. HD-Ready Plasma...
My psp screen have dust how its not to have dust
to get the dust off, you will have to open up your PSP and lightly dust off the lcd screen and the top part of the PSP from the inside, with a clean cloth. dust will tend to get into the PSP no matter how much you take care of it. it can go in through the speaker holes, the memorystick slot, or the UMD tray ...
Jul 30, 2011 | Sony PlayStation Portable (PSP) Console
My new lg optimus one p500 is having a dust inside the screen.. within 15 days of purchasing the cell phone the dust is getting increase day by day.....after cleaning the dust from authorised service...
my new lg optimus one p500 is having a dust inside the screen..
within 15 days of purchasing the cell phone the dust is getting increase day by day.....after cleaning the dust from authorised service center its coming again on the screen.........ohhh ghoosh.. im fed up wth this new lg phone (lg optimus android 2.2 froyo.based) lgp500.
Feb 09, 2011 | LG KP500 Cookie black on T-Mobile U-Fix...
How do you open the hand held vacuum to empty the contents??
There is Dust cup release need where the power cord connect to the vacuum. Once you have released the dust cup from the vacuum. First the are 4 parts to the dust cup, The actual dust cup, the housing for the filter and mesh screen. The dust cup will unscrew from the the housing which holds the filter and mesh screen. You can also pull out the filter and mesh screen out of the housing, If you have taken it apart fully you will have 4 seperate parts.
Jan 24, 2011 | Fantom Vacums FM430 Handheld Vacuum
Have a JVC HD-Z886 61inch, there appears to be some black spots behind the screen. Looks like dust, most at top of screen, not a big problem. Is there any way to clean behind the screen? When new the TV...
  • The most severe problem dust can cause in an LCD TV is a short circuit. This occurs when dust enters the television's casing and settles on one or more of the internal circuit boards. Enough dust can cause a short circuit, which will prevent the TV from working at all. In other cases, it will damage picture quality or prevent certain features from working properly.
    Because a short circuit can only occur when enough dust is present inside the TV, this problem happens after the TV has been in use for a number of years, meaning that it will not be covered under the manufacturer's warranty. In many cases of short circuits, repair is expensive, and you are better off buying a new set.
  • Image Quality
  • Dust can also have an effect on an LCD TV's picture quality without entering the LCD's casing. Dust that settles on the surface can distort the picture and decrease its brightness. While it's easy to wipe the dust away, use only a soft cloth and mild cleaning solution to avoid scratching the screen or causing permanent damage with caustic cleansers.
    Dust under the screen can be more difficult to clean. Using compressed air to blow the dust out is the best option, short of disassembling the set to clean the screen from the inside. Keeping the surface of the screen free of dust is usually sufficient to prevent dust from getting under the screen.
  • Control Problems
  • Another effect dust can have on a an LCD TV occurs when it enters the space around buttons, making it difficult to control the television. On certain sets, dust will cause buttons to stick or prevent them from engaging when pressed. Using compressed air to blow the dust out, or resorting to using only the remote control, will solve this problem.
  • Jan 24, 2011 | Televison & Video
    How can I get the dust out of the screen?
    your not stuck with it. dust blower spray might get in the small cracks. or just take to local retailer and they will clean it.
    Jan 16, 2009 | Nokia 7370 Cellular Phone
    Dust inside screen of Nikon Coolpix S51c
    You won't be able to get it cleaned with canned air. The dust that developed is underneath the screen. I recommend sending it to Nikon or the camera doctor.
    http://www.cameradr.com/
    He can clean it for you cheaper and faster than Nikon could do it.
    Nate
    Nov 18, 2008 | Nikon Coolpix S51c Digital Camera
    Motorola Q internal screen dust
    I had the same problem and I solved it by following the directions on this post. Click the link:
    http://pdaphonehome.com/forums/motorola-moto-q/90440-how-get-rid-damn-annoying-dust-under-your-screen.html
    Aug 06, 2008 | Motorola Mobility Q
    Dust behind screen
    take off the screen cover (the plastic) with a pin and clean it with a (magic) cloth.
    Jul 15, 2008 | Motorola Mobility RAZR V3m Cellular Phone
    Apple Cinema Display 23" HD - Dust on inside of screen.
    Well, I pretty much knew that the display would have to be disassembled to clean the dust out. I should have been more specific by asking if the display "could" be taken apart to clean it out, especially since the dust is in between the image and light source layers.
    Jan 15, 2008 | Apple Cinema Display 23" HD Monitor
    RIM BLACKBERRY TORCH 9800 TOUCH SCREEN DIGITIZER with LENS COVER REPLACE Logo
    20 people viewed this question
    Top RIM Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Longtime User
    Jason
    Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
