Question about Health & Beauty
Changing the height and age on Thinner scale does not work
I may change the USER by selecting UP DOWN buttons but Height and Age are stuck at 170 cm and 27 years?
  • stan smith
    stan smith Nov 23, 2013
    Yes solution from jgoodm03 worked perfectly! Thanks jgood!
5 Suggested Answers
SOURCE: SCALE SETTINGS
To change the height/weight/age, hold the user # you want to change it for and the set/save button at the same time for a few seconds.
I am #2, so I hold the 2 button and set/save. Then you can use scroll to change the numbers/options, and set when you have properly set the digit.
First it does height, then age, then gender, then if you want a goal, and then what that goal is.
Posted on Jun 23, 2009
SOURCE: Changing user settings on Conair WW67T scale
1. Tap the scale
2. Wait for "0.0" display
3. Set
4. Use the up arrow then stop on the user you desire
5. Set
6 Using the up/down keys enter Height
7 Set
8 Using the up/down keys enter Age
9 Set
10 pick the little man or woman
11. Press SET - the scales will redisplay your profile settings for verification.
12. Wait Until the Display Goes Blank.
13. Tap the Scale.
14. Press USER, select desired profile, P-01 is the default.
15. Wait for "0.0" display
16. Step onto the scales and wait for all measurements to display
Posted on Jul 28, 2009
SOURCE: I can't program the WW78
To get into the program mode tap the scale to turn it on, while all characters are displayed press the set button. This will put it into the flashing program mode and you can enter data.
Posted on Jun 05, 2011
nope709
SOURCE: Hi. I just bought
bring the scale back. Even once you set the profile the scale gives errors in body fat and everything else. It was not well designed. Go figure, since it's using the WW logo.
Posted on Oct 20, 2013
How do I reset a user's height and age on Health o meter BFM884DQ1-60?
you have to hold down select and the number you want to reset. select erase and put in your own settings. Good luck
Jul 28, 2012 | Healthometer Health o meter Body Fat...
How do I change the age on my healthometer scale, model BFM676KD01
Press Left "Select" key; Press Right "Scroll" Key to select USER (Digital Display flashes to show USER #); Press and HOLD "Select" Key until "Height" flashes; Press "Scroll" to advance Height '; Press "Select" to move to next input. When "Age" flashes, press "Scroll" to your age, and you're done!
Nov 17, 2011 | Health & Beauty
I have a Health O Meter HDM560. I need to reset the #1 and #2 users and start over, can you help me there is nothing in the manual about it I can find.
Current Instruction Manual for the HDM560 can be found here:
http://www.healthometer.com/Manuals/MANUALS/HDM560-05_43_41816518.PDF
For resetting it would be similar to the initial setting process. FOLLOW these steps:
Lift display cover. Push "SET" button at bottom of pad. User "1" and "2" will appear.
User "1" will start blinking. Press the "USER" button to choose user "1" or "2". Once selected, press "SET" button to lock in information.
Both "HEIGHT" and "AGE" will appear on the screen. The "HEIGHT" will start blinking. Press the "UP" or "DOWN" arrows to find the correct height.
After entering height, press the "AGE" button. Use the "UP" and "DOWN" arrows to enter correct age and press "SET".
Both "MALE" and "FEMALE" images will be displayed. Press the "GENDER" button until the correct MALE/FEMALE image blinks and then press "SET". This will lock in the information.
Your correct information including User, Height, Age, and Gender will be displayed. Now you are ready to calculate weight.
Tap your person "USER" number (1 or 2) in center of scale with your toe. Your personal profile will appear. Wait until "000" appears. Stand on scale so bare feet are positioned over silver pad surface. "000" will blink your weight for approximately 3 seconds. "BF" will flash and body fat percentage will appear. The scale will turn off automatically in a few seconds.
May 21, 2011 | Health-O-Meter Health & Beauty
What is 5 foot 7 in cm?
Hi Tara, 5 foot 7 inches is equal to 170.18 Centimeters.
May 05, 2011 | Office Equipment & Supplies
I have a GoWalking by Sportline scale and right now it is set to kg but i need to set it to lbs how would i do that. i lost the manual pls help
Press I/O button to turn on.
While "1-10" is flashing, press "i" button once.
Use up/down arrows to choose a 'user number' from one to ten, then press "i" button.
Press up/down arrows to chose between male(bottom) and female(top) icons, then press "i" button.
Use up/down arrows to specify your height in cm. (inches x 2.54) Press "i" button.
Use up/down arrows to specify age, then press "i" button.
"1-10" will flash again. Using up/down arrows select the user number you've programmed and wait for your height and gender to display, followed by "0 lb." You can now use the "i" button to toggle lb/kg or step on the scale for your weight and body fat %.
Next time you turn the scale on, just use the up/down arrows to pick your user number then wait for the 0 display.
Jul 07, 2010 | Health & Beauty
No instructions. how do i set it up and what does
P zero to P 9 is just a user number to set it up... Instructions for set up are:
  • Turn it on.
  • Select user number using up and down buttons (P0 is fine).
  • Hit the Set button.
  • Choose gender using up and down buttons.
  • Enter your age using up and down buttons.
  • Enter your height (goes in 1/2 inch increments) using up and down buttons.
  • Hit the Set button. (Info is now saved.)
  • When scale changes to 0.0, you can step on, and get your weight.
  • It will blink and change weight possibly for a second or two. When it stops, it shows your weight.
  • Stay standing still on the scale after your weight, and it will gon to show your bodyfat percentage, then your body water percentage.
  • When finished, you can step off, and it will turn off.
Oct 17, 2009 | Taylor 5757 Digital Glass Body Fat Scale
SCALE SETTINGS
Apr 09, 2009 | Health-O-Meter Health o Meter BFM588DQ-81...
Unable to reset health o meter scale BFM676 need instruction man
I just got a BFM676 without instructions. I looked on Health O meter's home page. I then looked through various instruction manuals. One of them worked.
To adjust profiles. Turn on by pressing scroll. Choose profile number you want to edit with the scroll button. Hold down the Select button until the first height number starts flashing. Use the scroll button to change the numbers. Use the select button to change to the next field. Have fun. =)
Mar 09, 2009 | Health & Beauty
1. Tap the scale
3. Set
5. Set
7 Set
9 Set
13. Tap the Scale.
Oct 02, 2008 | Health & Beauty
Conair scale ww36gd err reading
I have a WW36DG digital scale and most of the instructions are the same, so far as I can see. When you tap on the scale, 888.888 appears. It is just seting itself. If you step on the scale before it reads 00.0 it wil give you a Err signal. If you stepped on the scale after it read 00.0, and an Err signal appears, either your battery is very low or it is malfunctioning. it does have a 10 year warranty on it. For the person wanting to set the scale, here are the directions. Good luck.
Customizing Your
Weight Watchers® Body Fat Monitor
1. Tap center of scale platform with foot to activate digital display (display will
flash).
2. Wait for "0.0" to appear in display window.
3. You are now ready to input your personal data. Firmly press the SET button
located below the display.
Enter User Number
• P-01 will flash in display window
• Press UP or DOWN arrows to select your individual user
number (Ten user numbers available: P-01 through P-10)
• When selected user number appears in display, press SET
button to save user number
• The scale is now ready for you to enter your height
Set Height
• "Ht" (height) will flash in display window
• Press UP or DOWN arrows to scroll to your height measurement
• Press SET button to save height
• The scale is now ready for you to enter your age
Set Age
• "Age" will flash in display window
• Press UP or DOWN arrows to scroll to your age
• Press SET button to save age
• The scale is now ready for you to enter your gender
Set Gender
• The gender icons will flash in display window
• Press UP or DOWN arrows to select male or female icon
• Press SET button to save gender
• The scale is now ready for you to weigh yourself and to
determine percentage of body fat
Nov 25, 2007 | Conair TAD1216PWT Digital Answering...
Health & Beauty Logo
91 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
