Question about Gateway LP2207 LCD Monitor
I CAN'T WORK THE BUTTON ON THE MONITOR
NEED A MANUEL
How do I connect and get started with a dell core 2 duo desktop pc
You may NOT receive an instruction manuel with your computer.
You SHOULD have received a "quick setup" inside your computer box and your monitor box.
You may follow the pictures in that also.
Verify that you have a valid service provider/internet account
Connect your monitor to your desktop with the cords that should be with the monitor.
One goes in the back of the desktop
One goes to the monitor usually in the back or underneath the screen.
Be sure to look at the shape of the connectors or the colors and match colors to what is on back of the machine.
If you have a power cord connect that to back of the desktop
Plug the other into electrical outlet.
Press the round POWER button on the front of your desktop and it should turn on and start running and you would see the Windows icons on the screen.
Feb 07, 2015 | Dell Computers & Internet
I got a wristech jb5538,i don;t have a manuel,can;t find 1 online.i need to know how to switch between kpa and mmhg
i got a wristech jb5538,i don;t have a manuel,can;t find 1 online.i need to know how to switch between kpa and mmhg.
the solution is when the unit is off, press and hold the left (<) button
until you see a kpa or mmhg in the display.
release then press and hold the same (<) button to choose between
kpa and mmhg .
press the start stop button to start measuring.
I also requested a manual from
info@jobar.com they sent me one.
Aug 10, 2011 | Asseenontvguys Wristech Blood Pressure...
How do you adjust the brightness on a LG monitor
check this Manuel http://www.free-service-manuals.com/Computer_Monitors/LG_Monitors/LG_Flatron_L1951S-SN_Service_Manual_L25095/
Oct 17, 2010 | LG Flatron L1951S 19" LCD Flat Panel...
PC is not working. Monitor message says 'monitor
Check to make sure that you have it plug all the way in to the video card. Also make sure that the video card itself is seated or pushed in good.
You could possibly need a new video card or the pins on the plug coming from the monitor could be bent.
Oct 13, 2009 | Computers & Internet
Can not power up monitor
Hi there
you have a couple of options you can find the website of the manufacture of the monitor and they should have a troubleshooting section or in your manual there may be a number that u can call.. my new dell monitor i had to hold the power button in for 30 seconds
Mar 09, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
AOC LM729 17" LCD Monitor - Manuel
I assume you only found the 4 mount screws in the back... You also need to take off the front silver edging - it pops off with some negotiating, but if you find the right spots and don't pry hard it will come off clean without too much difficulty. Then take out the screws that hold the screen inside and it should drop out.
Jan 26, 2008 | AOC LM729 17" LCD Monitor
Too bright
I just bought an Acer 19 inch this morning and I am assuming you have the same controls on the bottom of monitor. On mine I push the menu button twice....the left arrow once to select the brightness slider.....push the menu button again to turn slider red and active...then use your left or right arrows to adjust brightness...afterwards you use the menu to get you back to the exit button and that's it....I hope Don
Dec 07, 2007 | Acer AL2016W 20" LCD Monitor
Gateway LP2207 LCD Monitor Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
