Question about Acer Computers & Internet
Replace hd with used hd.
Acer aspire 5517-5997 wd 160 hd was not recognized. replaced with a wd 120 hd from acer aspire 4520-5950. both running vista. asks me to choose an operating system.keeps repeating.what can I do ?
  • William Walker Nov 23, 2013
    will not load windows.
    Top Expert:
  • Acer Master
  • 12,962 Answers
You just do not drop in a replacement hard drive from another working computer and expect it to work. The replacement hard drive is now in a "foreign" environment and often will not work to protect the existing operating system. If you have the operating system disks you may be able to do a "repair" operation where the OS is given a chance to adjust to is new environment and install new drivers. If not, then all you can do is format the replacement unit and re install all of the software; everything is one drive is lost and you start from square one.
Posted on Nov 23, 2013
mrsjill
  • 41 Answers
SOURCE: EXT HD UNRECOGNIZED BY LAPTOP
Which operating system are you using? Windows XP or Vista?
Here is the website that you can download the driver for your external harddrive.
http://support.wdc.com/product/download.asp?modelno=WD1600JB-00FUA0+WD+&x=1&y=11
Posted on Mar 26, 2009
Crankstart
  • 696 Answers
SOURCE: WD 1TB USB 2.0 EXT HD - NOT RECOGNIZED
Hi First things first, is the light on the front still coming on? If not try a new power supply or moving the drive to a new shell as the problem is either in the AC adapter or in the shell.
If the light is on it only confirms that you have power, but first try a different set of USB ports and if that doesn't work try a different computer. If it works on the other ports, no biggy, use it there. If it doesn't and works on a different computer then it's likely your registry entry for the device is damaged, get back to me if that is the case. If it doesn't work on other ports or another computer then it's likely the circuitry of either the drive or shell is damaged, take it to a computer store and have the techs swap it into a new shell(about $40). Then have them test it, if it works you're done, if not then it is the circuitry in the drive itself that is damaged and you will need to send it for data recovery if you want the files back.
Send me an update once you have tried these suggestions and let me know how you made out. If you require the help of a pro for the final steps, reply with your country and region and I will locate a reputable facility to assist you further.
Chris
Posted on Jun 04, 2009
Suricatta
  • 92 Answers
SOURCE: WD External Drive-USB recognize, but no icon, can't access
1. Right click on My Computer > Manage;
2. On the new window click on Disk Management, on the right side, right click in the USB Volume and chose "Change Drive Letter and Path..."
3. In the new window click on "Add..." to assign a letter to your USb drive.
Best Regards
Posted on Jun 24, 2009
etcrCustomPC
  • 61 Answers
SOURCE: WD Elements USB drive not recognized
Try going to Disk Management and see if they show up there.
  1. Click Start
  2. Right Click My Computer
  3. Click Manage
  4. Click Disk Management
If your computer is recognizing a mass storage device they should show up in disk management and you can just assign them a drive letter.
Posted on Sep 15, 2009
Testimonial: "Brilliant solution. Worked like a charm. Thx."
  • 3 Answers
SOURCE: My WD Essentials external HD will not power down
sounds like an MBR or partition table issue - if you need to restore data from the disk I'd suggest testdisk
Posted on Jan 04, 2010
Acer aspire video problems
I just sold my AS5103 with a new HD exhibiting the same problems, as i said replaced the HDD, have you tried running a manufacturers HDD testing utility and if you do only 2 don't have to be changed to IDE in the bios before testing, WD & i think its Hitachi.
Jun 11, 2014 | Acer Aspire 5100-5022 Notebook
DVDR3575H doesn't recognize replacement HD
Unable to FORMAT the HDD in the device? Perhaps remove the drive - hook it up to a working PC temporarily, and using a partition software program or you could burn a CD (I use PartitionWizard), delete any or all partitions on the new 160GB WD and make that drive UNALLOCATED and UNFORMATTED. Apply the actions as needed - only to that drive (this will at least allow your unit to recognize it properly). Once done, remove the drive from the PC, and put it back into your recorder - see if it recognizes it this time, then try and format it (in accordance with the type of file system the unit uses - which may differ from that of a PC). Replacement drives should be formatted to suit the unit they are intended for AFTER they are fitted, not before. Otherwise you run into compatibility problems (e.g. the drive won't allow recording/doesn't read etc., but might work in a PC). If this is the case, it may explain greyed out options and not being able to record to it. If you still have the original drive, check the jumper setting to be sure. If both old and new are set to CS - leave them as is - don't change that.
Dec 18, 2017 | Philips DVDR3575H/37
My lapptop Acer Aspire 5315 (Vista O/S) crashed. I
you can try hiren's BootCD, it's can fix MBR or re-format using this cd.
Dec 18, 2009 | Acer Aspire 5315 Notebook
Replace the Vista Home Premium with XP on ASPIRE M1202
Your best option is to upgrade to Windows 7. It is free for (I believe all) Vista users, and you can run programs in XP compatibility mode.
Dec 04, 2009 | Acer Computers & Internet
Hdd problem
the normal thing it will be to read minus 5 percent from it ...I mean 160 ....to see 150 just about ..the rest it is use for system requierments..and stuff , so ..if you are running like this ..it means that you format it like this ..or you left a part of the memory unformated......or ...there is another possibility if it has any jumpers settings on it ...like at the old ide hdd it might be limmitated from there ..or maibe has other limmitations .
there is possible to be setted to use a percent from each partition for different porpouses ..like system restore ..or else...and it will not show all in the partition propieties..
anyway ...its not a reading problem
Mar 24, 2009 | Acer Aspire 3000 Notebook
Acer 5100 PC
Pretty simple. You'll just need to determine whether the system uses SATA or IDE for the hard drive interface. Many machines manufactured in the past couple of years use SATA, but any 2.5" drive will be compatible providing you have the correct interface. ATA drives for laptops are generally called PATA and if it's such an interface any ATA-6 drive will be compatible.
You might need a SATA driver for the Vista installation, so bear that in mind. You'd specify additional drivers during the setup process.
Good luck.
Ben
Sep 17, 2008 | Acer Aspire 5100-3357 Notebook
Usb
your usb device is use less now.
replace it if u have warrenty of it.
Mar 24, 2008 | Computers & Internet
Drivers for my acer aspire 4720z
acer.com eneter your model in dl vista drivers all to folder on hd ok
Mar 12, 2008 | Acer Aspire 5100 Notebook
Acer Vista Lap Top Won't Recognize USB Flash Drives
If Acer screwed up fixing your problem the first time (and it's evident that they did) they are obligated to fix it a second time, and if they cant, they are obligated to replace your laptop.
Dec 31, 2007 | Acer Aspire 5100 Notebook
Computers & Internet Logo
78 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
