Question about Jenn-Air JGR8850 Gas Kitchen Range
JENN-AIR CVG4380W SPARK IGNITER
I have a broken spark igniter on our CVG4380W cooktop. There are 3 igniters, and it's the one for the griddle section. I assume that to remove the igniter I must approach from underneith, but there doen't appear to be an easy access panel to the area. There's also a blower / exhaust fan assembly to contend with underneith. What is the best / easiest way to remove and replace the broken spark igniter? I appreciate any help you can provide! Tiseye
  • Tiseye Oct 13, 2007
    Thanks for your help.  I was in an auto accident, and have been unable to make the repairs yet. I can see how the blower will come out, and I am confident I can do the job because of your help.
    Thanks again!  Your post in response is appreciated!
    Tiseye
I appreciate your post. We had just become used to lighting the griddle area with a long handled butane lighter. It seemed easier than going through the labors involved. However, I like the sound of your approach, and because it is probably much easier than removing the whole unit, I will likely go ahead and replace the igniter. I was surprised at how expensive they are though!
Thanks for your post.
Tiseye
Posted on May 08, 2008
There are two panels to remove. One underlaying the grill with (7) 1/4 screws holding it up. This exposes the igniter Use an open end wrench to remove the igniter nut (it will hang on the wire). On the front of the stove top is a vertical black panel. Remove the cover with 1/4" socket. On the right side you'll see a blue relay. The white wire from the grill igniter will be plugged in there. You can tie a string on the end (that plugs into the relay) to ease the installation of the new wire. Or it's easy enough to fish under the upper panel to the control panel. Ensure that you replace the nut on the new igniter.
  • 473 Answers
You should be able to remove the hose from the blower and lift the unit out of the countertop. Then there should be screws around the sides to take out that will give you access to the inside.
Posted on Oct 10, 2007
SOURCE:
Gas Kleenmaid cook top, one igniter continues to
the switch for the ignitor is stuck. might need to free the switch, of
> call the repair man.
Oct 20, 2013 | Jenn-Air 30 in. CCG2423 Gas Cooktop
I have a jenn-air stove The igniter went out on all 4 eyes on the cook-top
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Dec 25, 2010 | Microwave Ovens
3 of the 4 burners clicks and sparks when I try to
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Jul 27, 2010 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
The igniter is out, how do we fix it
heatman101
Jun 23, 2010 | Jenn-Air JGD8345 Gas Cooktop
The spark igniter keeps sparking after the flame has been lite
spark igniter stays on after burners lit. can you help?
Jun 17, 2010 | Jenn-Air JGC8536 Gas Cooktop
Cooktop spark igniter will not turn off
This is usually a bad spark module that is not sensing that the burner is lit. You need to replace it. Is it still under warrantee? Good Luck, Appliance Specialists
Jan 06, 2010 | Jenn-Air 35 in. JGC9536 Gas Cooktop
Two of five cooktop burners fail to light
you can try to scratch the area where it grounds to with a wire brush or screw driver this will help sometimes. sometimes when it archs down try tighten the screws to lift up the ignitors into the hole better. or if this doesn't work replace the ignitors.
Jun 07, 2009 | Jenn-Air JGC8536 Gas Cooktop
Jenn-Air JGC8536 Gas Cooktop ignitor replacement
One burner doesn't consistently light. Igniter sparks but not the same as the other - "good" burners spark at top of igniter and moves around to light, "bad" burner sparks toward the bottom and doesn't move much. I can use the burner by lighting with a match and it works fine. Have tried cleaning with a toothbrush without much success
Dec 12, 2008 | Jenn-Air JGC8536 Gas Cooktop
Ignitors continue to ignite on other burners
the igniter switch are stuck /need clean contactor of the igniter .
Jan 08, 2008 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Jenn-Air JGR8850 Gas Kitchen Range Logo
384 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Thomas F. Schneider
Paul Carew
Ismael Rodriguez...
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
