Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Odbcint.dll and odbccp32.dll version mismatch in microxp error
Where can I get a free download for windows xp 3 ksuser.dll?
The ksuser.dll file is one of many files contained in the DirectX software collection. Since DirectX is utilized by most Windows based games and advanced graphics programs, ksuser.dll errors usually show up only when using these programs.
Resolution
Important Note: Do not download the ksuser.dll DLL file individually from any "DLL download site." There are a number of excellent reasons that downloading DLLs from these sites are never a good idea.
Note: If you've already downloaded ksuser.dll from one of those DLL download sites, remove it from wherever you put it and continue with these steps.
1. Restart your computer if you haven't yet.
The ksuser.dll error might be a fluke and a simple restart could clear it up completely.
2. Install the latest version of Microsoft DirectX. Chances are, upgrading to the latest version of DirectX will fix the ksuser.dll not found error.
Note: Microsoft often releases updates to DirectX without updating the version number or letter so be sure to install the latest release even if your version is technically the same.
Note: The latest version of DirectX should be installed no matter if you're running Windows 7, Windows Vista, or Windows XP. The installation may include DirectX10 and DirectX9 files but they run side-by-side without problem on all of these operating systems.
3. Assuming the latest DirectX version from Microsoft doesn't fix the ksuser.dll error you're receiving, look for a DirectX installation program on your game or application CD or DVD. Usually, if a game or other program utilizes DirectX, the software developers will include a copy of DirectX on the installation disc.
Sometimes, though not often, the DirectX version included on the disc is a better fit for the program than the latest version available online.
4. Uninstall the game or software program and then reinstall it again. Something might have happened to the program files that work with ksuser.dll and a reinstall could do the trick.
5. Restore the ksuser.dll file from the latest DirectX software package. If the above troubleshooting steps haven't worked to solve your ksuser.dll error, try extracting the ksuser.dll individually from the DirectX downloadable package.
6. Update the drivers for your video card. While it's not the most common solution, in some situations updating the drivers for the video card in your computer could correct this DirectX issue.
Oct 30, 2012 | Microsoft Windows XP Home Edition Service...
It has DINPUT.dll error
Dinput.dll errors usually appear when a game or other software program is started. and are caused in one way or another by an issue with Microsoft DirectX.
The dinput.dll file is one of many files contained in the DirectX software collection. Since DirectX is utilized by most Windows based games and advanced graphics programs, dinput.dll errors usually show up only when using these programs.
Solutions:
1. For Dinput.dll not found. Reinstalling Direct X should fix this.
2. Install the latest version of Microsoft DirectX. Chances are, upgrading to the latest version of DirectX will fix the dinput.dll not found error.
Note: The latest version of DirectX should be installed no matter if you're running Windows 7, Windows Vista, or Windows XP. The installation may include DirectX 11, DirectX 10, and DirectX 9 files, but they run side-by-side without problem on all of these operating systems.
3. Assuming the latest DirectX version from Microsoft doesn't fix the dinput.dll error you're receiving, look for a DirectX installation program on your game or application CD or DVD. Usually, if a game or other program utilizes DirectX, the software developers will include a copy of DirectX on the installation disc.
Uninstall the game or software program and then reinstall it again. Something might have happened to the program files that work with dinput.dll and a reinstall could do the trick.
Restore the dinput.dll file from the latest DirectX software package. If the above troubleshooting steps haven't worked to solve your dinput.dll error, try extracting the dinput.dll individually from the DirectX downloadable package.
4. Update the drivers for your video card. While it's not the most common solution, in some situations updating the drivers for the video card in your computer could correct this DirectX issue.
Here is a good link for DirectX info on how to download and install:
http://support.microsoft.com/kb/179113
Jun 04, 2012 | EA Sports Cricket 07 for Windows
The ordinal 120 could not be located in the dynamic link library iertutil.dll
iertutil.dll is a dynamic link library used by Internet Explorer. Ordinal 120 refers to something inside the dynamic link library. These errors typically occur when the file is corrupt or there is a version mismatch (eg. IE 9 using iertutil.dll from IE 8). A reinstall of IE should fix this problem
Ericthecmh
Oct 05, 2011 | Microsoft Windows XP Professional for PC
Unable to initialize adlm
Unable to initialize adlm error after uninstalling Service Pack for 2014...
Solution:
There are 2 solutions available, either of them can help you to resolve the license issue.
Option #1:
Uninstall and reinstall the Service Pack (any of the Service Pack if you have more than one) that you want to keep. This will restore the mismatched file versions to the correct one.
Option #2:
Copy and replace files manually
1. Download the LicenseCrash.zip attachment below, unzip to your local drive, and then unzip the 32-bit or 64-bit package according to your platform.
2. Unzip the package
3. Close all running Autodesk products
4. Stop the FlexNet Licensing Service from the Task Manager:
  • Click Start ? Run
  • Type taskmgr and the Windows Task Manager will open.
  • In the Windows Task Manager, on the Services Tab, right-click FlexNet Licensing Service ? Stop Service.
5. Replace the following 5 files from the unzipped folder into the following locations:
a. Replace adlmact_libFNP.dll and adlmact.dll with the ones (version 11.11.0.3 and 7.0.51.100) in the unzipped folder.
b. Replace adlmint_libFNP.dll and adlmint.dll with the ones (version 11.11.0.3 and 7.0.51.100) in the unzipped folder.
Note: Most products put this file under the root folder of "\Program Files\Autodesk\#Product name#\" i.e. AutoCAD2014, but some other products put this file under subfolder, i.e. Inventor /Alias in \Program Files\Autodesk\#Product name#\Bin folder.
c. Confirm and if necessary replace FNPLicensingService.exe with the one in the unzipped folder to avoid file version incompatible issue.
6. Launch your products.
Mar 20, 2011 | Autodesk AutoCAD 2010
Can't download Skype error d3d9.dll
You are definitely using Windows XP as your operating system. Skype latest versions like 5.1 are not compatible with Windows XP. You need do download older versions to make Skype work on Your Windows XP. I recommend the version SKYPE V4.2.0.169. Try to download and install this.
Good Luck!
Feb 25, 2011 | Computers & Internet
I got problem with d3dx9_29dll was not found.anyone could help?
There are quite a few different ways that d3dx9_29.dll errors may show up on your PC. Some of the more common d3dx9_29.dll errors are listed here:
  • "D3DX9_29.DLL Not Found"
  • "File d3dx9_29.dll not found"
  • "Error while starting game executable - couldn't load DLL file d3dx9_29.dll."
  • "D3dx9_29.dll is missing"
  • "D3DX9_29.DLL is missing. Replace D3DX9_29.DLL and try again."
  • "D3dx9_29.dll not found. Reinstalling the application may fix this problem."
  • "Missing component d3dx9_29.dll"
  • "This application failed to start because d3dx9_29.dll was not found!"
D3dx9_29.dll errors usually appear when a software program, most often a game, is started. Occasionally, d3dx9_29.dll errors will display after a game is loaded but right before the game begins. Unlike many other dll errors which can have complicated causes and fixes, d3dx9_29.dll issues are caused in one way or another by a single issue - some kind of problem with Microsoft DirectX. The d3dx9_29.dll file is one of many files contained in the DirectX software collection. Since DirectX is utilized by most Windows based games and advanced graphics programs, d3dx9_29.dll errors usually show up only when using these programs.
Resolution
Important Note: Do not, under any circumstances, download the d3dx9_29.dll DLL file individually from any "DLL download site." There are a number of different reasons that downloading DLLs from these sites are never a good idea.
Note: If you've already downloaded d3dx9_29.dll from one of those DLL download sites, remove it from wherever you put it and continue with the following steps.
1. Restart your computer if you haven't yet done so.
The d3dx9_29.dll error might be a fluke or one-time issue and a simple restart could clear it up completely. It's unlikely this will fix the problem, but restarting is always a good first troubleshooting step.
2. Install the latest version of Microsoft DirectX 9. Chances are, upgrading to the latest version of DirectX 9 will fix the d3dx9_29.dll not found error.
Note: Microsoft often releases updates to DirectX 9 without updating the version number or letter so be sure to install the latest release even if your version is technically the same.
Note: Are you a Windows Vista user with DirectX 10? Your game or program may still need DirectX 9 files to run properly so give the installation a try. Don't worry, both versions of DirectX can be run side by side in Windows Vista.
3. Assuming the latest DirectX version from Microsoft doesn't fix the d3dx9_29.dll error you're receiving, look for a DirectX installation program on your game or application CD or DVD. Usually, if a game or other program utilizes DirectX, the software developers will include a copy of DirectX on the installation disc.
4. Uninstall the game or software program and then reinstall it again. Something may have happened to the files in the program that work with d3dx9_29.dll and a reinstall could do the trick.
5. Restore the d3dx9_29.dll file from DirectX 9. If the above standard troubleshooting steps haven't worked to solve your d3dx9_29.dll error, try extracting the d3dx9_29.dll individually from the DirectX 9 package.
May 12, 2010 | EA - Electronic Arts Command & Conquer 3:...
D3drm.dll promblem
Go to the following site, copy the d3drm.dll and save it to your c:\windows\system32 folder
Nov 07, 2009 | Microsoft Windows Vista Ultimate Edition
What is a error C2563: mismatch in formal parameter list in c++ language
ok, look at the following example
void Run(string* message, char& type)
in the program I put
Run("help");
this will result in the mismatch error as there are two parameters not one.
Regards
gewiz.co.uk
Oct 28, 2009 | Microsoft Visual Studio 2008 Professional...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
19 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
