Question about Canon PIXMA MX870 Wireless Office All-in-One InkJet Printer
Canon printer pixma mx870 makes loud grinding noise and does not print
websnail
  • 419 Answers
SOURCE: A loud banging noise from inside - as it adjusts post printing
I'd check that there's nothing that's fallen into the rear paper feed that is now causing the rollers to jam and release with the bang you mention.
If you're feeling brave I'd try holding the printer upside down (get a friend to help you and watch out for the scanner sliding out!) and give it a bit of a shake to see if anything drops out.
Posted on Jan 23, 2009
SOURCE: Canon PIXMA 530 grinds away
I had a persistant grinding noise about 30 seconds after the printer finished printing. It's been going on about 2 months. I did one thing which seemed to work. So try opening the cover on the back of the machine by lifting upward on the gray lever in the middle of the back of the machine. Leave this cover open during and after printing. The grinding noise went away.
Posted on May 25, 2009
SOURCE: my canon pixma mp530 makes a loud noise most times
My MP-530 would try to boot up making a noise like something slipping or grinding, ending with ERROR Code 5100.
Solution: Open the Lid. The drive belt was loose and not able to drive the carriage. There is a gear on the right side of the carriage and a pulley on the left side of the carriage. The spring which holds the pulley tight is missing or broken. I was not able to see the tension spring. To put tension on the pulley, to tighten the drive belt, I cut a Popsicle stick into a wedge and inserted it into the middle slot right of the pulley.
Close the lid and power back on. Runs like new. Hope this helps.
Posted on Aug 03, 2009
komguy
  • 2306 Answers
SOURCE: Canon MX7600 error 5100, 5C20
Yes, 5100 means the carriage is not moving back and forth properly or there is grease on the encoder strip behind the carriage assembly. Grease spots make it lose count and slam into the side and grind gears. You need to clean the strip with a Q-tip moist with alcohol, but very carefully, not too much pressure on the strip.
Posted on Dec 13, 2009
old marine
  • 2131 Answers
SOURCE: Canon PIXMA MX870 Wireless Printer works with Snow Leopard OS?
The MX870 is compatible with Mac OS X, all versions. I think the CD that comes with the unit will have the Mac Snow Leopard drivers on it, but if not you will be able to download them here.
Posted on Feb 05, 2010
Canon MX870 print alignment. Only occurs
Reinstall the printer driver. Sounds like it is corrupted.
May 09, 2017 | Canon PIXMA MX870 Wireless Office...
Canon pixma mx870 error B200
how to repair b200 error code on canon MX870 printer?
Sep 20, 2012 | Canon PIXMA MX870 Wireless Office...
Canon MX870 when trying to print freezes
mke sure that your driver is not corrupted by a virus
delete the driver look for a new one on the canon web support and intall it
good luck
Sep 15, 2012 | Canon PIXMA MX870 Wireless Office...
How do I disable the sound on my canon mx870 printer? It makes loud tones at start-up and at shut-down. My roommate is VERY bothered by it and I wouldn't mind the printer not announcing that I have turned...
I was having the same problem. This is how to fix it. Go to the actual printer, press the setup button, scroll and click on device settings, scroll down and select device user settings, select volume settings, then you can turn off all of the sounds of the printer. I also put it on quiet mode just in case. Hope that helps!
Mar 11, 2011 | Canon PIXMA MX870 Wireless Office...
I have just installed a Canon MX870 and it won't print - it keeps on saying the printer is offline... I have successfully established a wireless connection and when I go to printer and fax preferences (on...
I had the same problem and just fixed it by opening the Canon IJ Network Utilities and using the tool menu. It turned out that the printer had changed ports and the port was not compatible. That meant that the port it was using didn't have a printer driver associated with it so it couldn't work. As soon as I went into the configure menu and had it try the next IP port, it immediately printed. It's a matter of finding the correct port again or associate the driver the port you are now using.
Jan 04, 2011 | Canon PIXMA MX870 Wireless Office...
Dec 13, 2009 | Canon MX7600 Office All-In-One Printer
Paper is not being picked up and fed through.
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Nov 20, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Jan 11, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA MX870 Wireless Office All-in-One InkJet Printer Logo
359 people viewed this question
old marine
old marine
