Question about Bosch PowerStar AE115 Tankless Water Heater...
Water is cold and the light keeps flashing need to troubleshoot it
  • 30 Answers
Light flashing while water is flowing means you have a bad control board. Needs to be replaced. They can be purchased online
Posted on May 06, 2014
Got central heating but no hot water
I had a lot of issues with my water heater last month as well. However, it was really cold outside and it turned out that pipes were freezing up. If it's really cold at your place, try letting the water drip lightly out of the faucets to keep the water moving. That's what I did. How cold is the temperature and how long have you been dealing with this issue? If it lasts for more than a couple of days, then you should have a plumber come and check it out. Plumbing and Electrical Contractor in Virginia Beach Virginia
Dec 15, 2015 | Water Water Heaters
Thanks for that mike, it is a worcester bosch combi 24cdi heating and water can stay on for an hour then everything goes off and the red light flashes. it will come straight back on when reset, but then...
Check the pressure reading, should be about 1 bar when system is cold. Various models in the range of 24cdi. If you do not have a manual, go to,
http://www.centralheating.co.uk/Boiler-Manuals/worcester-bosch-boiler-manuals/worcester-bosch-discontinued-boiler-manuals.
Get the manual for your unit, to wards the end of install manual it has a fault finder, Also has a basic 1 in the user manual. Number of flashes how fast the light flashes which one flashing can all mean different, So get the manual and check, Some parts are easy to fix, as long as you do not touch the gas side the rest is plumbing. Come back if needed.
Mar 05, 2013 | Water Heaters
Not hot water or heating
Good luck with the repair.
We always stand ready to support success.
Also post the brand and model number and type of product so expert can identify if you have electric or natural gas or propane energy, and identify if there is basic information online about your product.
Aug 24, 2012 | Water Heaters
Have to keep resetting E2 is what keeps flashing?
Check wires coming from cold water line valve. Make sure incoming water is above freezing
Jan 16, 2011 | Bosch & Tankless LP Hot Water Heater
The red light on the water heater keeps flashing
Attached to the water heater is a troubleshooting chart for your sequence light. 1 flash means..., 2 flashes means...., and so forth. Find the chart, count the flashes and see what it means and we'll go from there. Douglas
Sep 18, 2010 | Reliance Natural Gas Water Heater Control
Water heater keeps cutting off and flashing code 12, will work great for hours then do this, i have checked electrical and ground all ok.
If you are on LPG try your regulator. The cheaper ones tend to stick, especially in cold mornings.
Sep 03, 2010 | Water Heaters
Sometimes the hot water just goes cold
Here are a couple things to look for:
1) flashing burner light - a flashing burner light indicates the unit is getting an error code
common error codes:
A. continuous flashing - ignition failure or abnormal combustion; look for visible water in the machine indicating a leak, check gas pressure, debris or buildup on flame rod/igniter plug, or clean unit with compressed air
B. 3 flashes - error 16, abnormal outlet water temperature; typically this code indicates you'll need to descale you unit
C. 4 or 5 flashes - exotic error codes; you should contact Noritz technical support to deal with these codes
2. If there is no flashing code, try increasing the hot water flow. In the summer time you typically use less hot water; this can result in intermittent operation of your tankless heater. Increase water flow by either: A. cleaning your showerhead and removing scale deposits B. widening your flow restrictor C. Remove your flow restrictor in the showerhead
3.If none of these resolves your problem, you probably have debris in your flow sensor. Contact Noritz technical support for a walkthrough on removing debris from a flow sensor.
Feb 18, 2010 | Noritz 6.3 Gallon Residential Tankless...
Lack of hot water from water heater
Unit needs a new "dip tube" It is cracked and allowing cold in water to mix with all hot water resulting in "lukewarm water". Need plumbing skills to change out at cold inlet top of heater,pull out old,buy new at hdepot 5.99 reinstall.
This has been a small manufactor recall on this matter
Please rate Thanks
jj505
Mar 29, 2009 | Whirlpool Water Heaters
Bosch PowerStar AE115 Tankless Water Heater... Logo
247 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
