Question about Hitachi 61SWX12B 61" Rear Projection Television
Set will not turn on!! please help
The LED on my 61swx12b will light for a split second, but then will shut down right away. I have the back panel off and the DP1X power board pulled out, and the convergence pwb pulled out. Can someone point me in the right direction as to what to test? I have my multimeter in hand, just no direction. Can I remove each board one by one and try to power up to see which board is the issue???
  • 1 more comment
  • beamik Oct 10, 2007
    There is only one LED on the front of this tv. It is the status LED that is lit when the tv is on and off when the tv is off.
    Are you talking about a different set of led's?
    I am not following what you're asking for.
  • Anonymous Dec 01, 2007
    When I turn on the tv the red power light comes on and immediately shuts back off again. ( in other words the power comes on and goes off again right away. What could be the problem?
  • texans Dec 02, 2007
    Our set has the same problem.
    What was the solution?
    Same television
    Genius:
  • 1,153 Answers
No, all you need to do is notice all led and see which goes off first and which stay on. Then I can help you.
Posted on Oct 09, 2007
Samsung UN46ES6500FXZA turns off by itself
I can not acces my Facebook deos not recognize or mail or password,how I can restart t.v to install and to atarte again please help me , thank you
Feb 10, 2014 | Samsung UN46ES6500 - 46" 3D LED-backlit...
Have a 55" pioneer rear projection tv, was working great, turned it off and when turning back on it comes on for a split second and it shuts off
Take the back of of your set. You should see if there are leds on the circuit boards that light up when you try to turn on set. Use these for reference.
If only D146 on the power supply lights up then the problem is the power boar.
If D1503 lights up then the problem is the audio circuit on the amp board.
If D2614 then the shut down is due to lack of vertical deflection. It could be caused by a defective amp assy or convergence control assy. Checj for convergence drive signal at CN2302 pin 1. If missing, IC2308 on convergence control assy is probably defective. You can confirm by checking blanking signal input on pin 1 of IC2308.
Good luck to you.
Mar 20, 2013 | Pioneer SD-P55A5K 55" Rear Projection...
Ps turns off straight away. was midway though a game when suddenly shut down and then when trying to restart the system, it automaticly turns off. no ejection option available ...or anything for that...
It sounds like yellow light of death. If you answer yes to these questions then thats what it is. I have a step-by-step instructions on how to fix it.
1. When you turn your console on, when it turns off does it beep 2 to 3 times before shutting down?
2. When it does shut down right before it does pay attention to the lights, do you see a yellow on blink once for a split second?
3. Afte the console shuts completely off does the red light just sit there and blink?
http://www.fixya.com/support/t8396931-ps3_turns_ok_but_turns_itself_off_after
Feb 25, 2011 | Sony Playstation 3 (PS3) Console
RCA DLP Model # M50WH74S Problem: Replaced blown lamp, when plugging it into AC, blue LED lights up right away for 2 or 3 seconds, then shuts off. Waited for a few seconds, and relay will click on and...
The blue led dies because the power source dies: it detects a big short on one of its outputs and shuts down to protect itself automatically. Since apparently it's a very big short and you just had to replace the bulb then the faulty part is the ballast board (the one that powers the bulb): when the bulb failed it has generated a power surge that fried it.
Replace the ballast and verify the power source board: if you're really unlucky when the ballast got fried it has in turn damaged the power board.
Oct 17, 2010 | Televison & Video
Insignia 32" begins to power up but shuts down right away
Unfortunately, your TV requires repairs. In-home service can be obtained by calling 1-888-237-8289 in the U.S. or 1-866-237-8289 in Canada.
Jan 06, 2010 | Insignia 26 in. LCD Flat-Panel HDTV
Jvc- 36f702. Powers up then shuts down right away and the red led blinks on the front panel?
Dec 03, 2009 | JVC AV-36F702 36" TV
Philips DPTV 60PP9753/17. Problem started when blue CRT seemed to "fuzz" out. Tried to increase the brightness via the Blue G2. Made no difference. The sound quit while the picture was running. Turned...
Hi my name is Roety,
I can help you with your issue ,
First of all lower the blue and any other screen controls or service menu settings back to where they were or lower.
Then see if it powers on again with a picture.
If it still shuts off, unplug the Blue CRT circuit board and see if it works.
If it does work the blue CRT may be shorted .
Your problem may have been corroded CRT pins.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Nov 02, 2009 | Televison & Video
Standby LED flashes red 4 times with pause then 4 times
You either have a bad fan or one of the rotation sensors mounted on one of the fans has failed. Take the back off the set and see it the main fan slightly right of center is rotating. If it is, there are two more fans, one mounted right above the lamp and another on the optical block itself. You will have to pull the optical block to check those.
Oct 25, 2008 | Sony KDF-E42A10 42 in. LCD Television
Lost power
The symptom you have needs to be looked at by a qualified technician for proper diagnosis. There are 9 LED`s ( 8 green, 1 red) in the power supply that light up under normal condition. These LED`s are used to help pinpoint the area of trouble. For example, when power is applied all LED`s but one lights up. The unlit LED may indicate the +27 volt source is bad. That will alert the technician to check components related to the +27v line. Since there are 8 green LED`s and 1 red, each having multiple suspects leads us to Mr Spock`s comment to captian Kirk." there are endless possibilities"
Nov 14, 2007 | Hitachi 50UX52B/53K 50" Rear Projection...
Mitsubishi vs50605 turn on and dhuts down and light flashes 3 time
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB
Mar 29, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Hitachi 61SWX12B 61" Rear Projection Television Logo
70 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
