Question about Philips Televison & Video
I have a Digitview L180S satellite reciever and a sky dish satellite (previously used for sky tv)....in last two weeks I have completely lost all signal during the day...it has now no signal from 9am
I have a Digitview L180S satellite receiver....it was bought on trade me about 2-3yrs ago...it has been working absolutely fine up until last month....especially last two weeks.......I am getting no signal completely for duration of whole day.......all channels are "lost".....then when it "decides" I get all channels back on again..... Do I need a newer sat receiver? I cant begin to tell you how many times I have Auto scanned.. I only get channels on OptusD1...Universal....LNB9759Mhz....10600Mhz..Symbol rate 22500 ....polarity H...DisEqC off....22K off What do I do?
    New Friend:
I can get my tv program
Posted on Nov 23, 2013
4 Suggested Answers
SOURCE: RCA Scenium HDLP61W151
RedRacer guy, you are awesome! I had the same problem as the 2 other people with this issue. I did the reset on the "reset all" on the ethernet connection not expecting this to do anything and as I exited this, the TV came on!
Thank you, Thank you, Thank you!
Posted on Mar 21, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: I can't change channels,message on TV says,'' no input available''.
Have you tried reprogramming the Dish remote with the Sharp code? That might bring back the TV control. Another option is to use the TV's control panel menu button (if available), go to the setup choices and have the TV scan for channels while the Dish receiver is on. It will find channel 3 then, and probably nothing else, so the set will stay on that channel.
Posted on Mar 20, 2009
satavlad
  • 405 Answers
SOURCE: SNOWY screen--can't find the right channel for Dish Network
Press INPUT button on your TV remote and select right input.
Posted on Nov 03, 2009
How to Set Up the Kbox Pro Digy (FTA Receiver)?
-Extract files (factory bin & version bin)
http://www.abadss.com/forum/983-kbox...te-v2-0-a.html
-from remote, menu-config-system recovery & select delete all channels then factory reset
-insert USB into port in front of reciever, menu-utilities-data transfer-data download (from USB storage)-factory bin (version 1.81)
-menu-config,system recover y and select factory reset
-menu-utilities. data transfer, data download from usb storage-select latest bin (version 2.18)
-menu-config-system recovery-factory reset
-plug khub into reciever using black serial cable, also plug into network cable running to your router or switch
-from controller-menu-utilities-data transfer-data download from USB storage, then select khub activation
-menu-installation-options and make sure all AU options are set off and mode is set to network
-menu-installation-dish settings & config satellites you have setup dishes, then press red button on each satellite to scan in channels
-menu-config-network and change mode to DHCP press green button on remote and wait for it to be complete
-once previous step is complete, turn reciever off with remote, then from back. Wait 30 seconds, turn unit back on
Oct 20, 2016 | Video Game Consoles & Games
I do not have a satellite sisgnal
check power and tv in correct mode -then check alignment of dish --if good and no large storms in area notify sky of problem it may be box or programming
Aug 16, 2016 | Televison & Video
Why does the picture do this. Press sky on remote and all colours seem to b wrong but when tv button is pressed the pic is fine but not hd
If you are getting your video picture (t.v) through a cable box, satellite dish etc. you will have to adjust the internal settings of that box to match the HD settings of the T.V. as well.
Nov 27, 2013 | Televison & Video
Sky hd box no satellite signal
Have you checked that the dish is still properly aligned? Could the recent storms in the UK have thrown it off? Likewise, have you checked that all the cables and plugs between dish and receiver are in good order? Lastly, if you have a Sky contract, have you called their customer support line?
Nov 05, 2013 | Televison & Video
My gm-1518 sounds like it is lining up on a satellite, but my receiver shows no satellites picked up. It has worked perfectly the last time I used it (July 4th week). Do you have any solutions to this...
This problem is a software glitch affecting 301, 311 receivers and the 5xx series DVRs. Even though the manual says not to, the solution is to select "Superdish" and "Alternate Dish" before doing a check switch.
Aug 30, 2011 | Winegard Gm 1518 Carryout (tm) Automatic...
How do i upload the operational directions for my 500 satellite computer on my computer
Sony Satellite Dish Antenna Operating Instructions
Operating a Sony satellite dish is a process that first requires correct dish placement to ensure strong signal reception. Additionally, the satellite receiver must be installed, and only then can you use it to put the dish in operating order via the use of its signal meter screen. Fortunately, you do not need to be a professional to complete these operations properly.
  1. Initial Sony Satellite Mounting
    • Look around for a suitable mounting area for your satellite dish. This mounting area should be free of any debris and also allow for a flat mounting area. It's best to utilize a hand-held level to measure and make sure that your Sony satellite dish lies flush with the mounting surface beneath it. Also, look to the skies above before settling on a mounting area, as obstructions such as trees, power lines and tall buildings can block signal reception for your Sony satellite dish. Once a spot is chosen, go ahead and crudely aim your Sony satellite dish to the southern sector of the sky above. This will save you some time later when you return for further adjustments
Read more: Sony Satellite Dish Antenna Operating Instructions ' eHow.com http://www.ehow.com/way_6312070_sony-dish-antenna-operating-instructions.html#ixzz1NYml5eFe
May 26, 2011 | Toshiba Computers & Internet
I have Dish 322 receiver. Everything was fine; a week or so ago satellite 119 reception was spotty, now we can't get 119 at all. We get 110 but only about 34%. Sometimes the receiver will power itself off...
hartpark
It looks like you have lost the signal for the 119 satellite from your dish. Are you getting an error message, either 002 or 015, saying the satellite signal has been lost or acquiring satellite signal? First, check the cables on the back of the receiver to make sure they are secure. You can also run a check switch test to see if there is a problem between your dish and receiver.
Press the Menu button on your remote. This will bring up the Main Menu on your TV screen. Input the numbers: 6 (System Setup), 1 (Installation), and 1 (Point Dish). On the right side of the Point Dish screen are 3 buttons. Select the Check Switch button. Within the 2 large boxes are satellite numbers and green or red boxes. Make a note of the satellite numbers (should be 119, 110), the trans, the device, and switch. Super dish and alternate should not be checked. Select the Test button on the bottom of the screen. If a box pops up with a warning about TV 2, select Yes. It will now run the check switch test. Let it complete the test. After completion, the screen will automatically go back to the Installation Summary screen. You may get a message stating that the Check Switch test has found fewer satellites than previously detected. If you get this message cancel out of each screen (do not save the results) till you are back to the TV screen and it is acquiring Satellite signal.
If you don't get that error message, see if the information on the Installation Summary has changed. Then select Done on the next 2 screens and cancel out of the others till you get the message, Acquiring Satellite Signal. After it finishes acquiring satellite signal and downloads the program guide, see if you are getting a picture - try different channels. If you still have problems, please email me at, ray.calo@dishnetwork.com. If you are still experiencing problems, we will need to send a technician to fix the problem.
Ray Calo
DISH Network
Apr 23, 2011 | DISH Network 322 DTV Receiver
Hi I purchased a Sony 60 inch T.V model KDL60EX703U. It is supposed to have built in free view. I have set it up the same as my previous t.v however when searching for channels it does not find any. ...
When you are searching for channels check what setting the channel search is in this model had DVB-T DVB-C and DVB-T2, If it is in the wrong search mode it will not find the channels. Also does your sky decoder use a dish? if yes then this could also be the issue as the TV uses Terrestrial signals and the SKY decoder will use a Satellite System.
Oct 25, 2010 | Sony Televison & Video
My 622 DVR dual (DISH ) receiver has lost 3 local channels in a row ( SAT 61.5) . Connecticut 7385,7386,7387 - (ch 20,24,26.) Other tv's/ HD box and old 310 box converters work fine. I have unplugged,...
Hello, my name is Daniel Busa with Dish Network customer service. Whats probably causing the issue would be that either you're not getting high enough signal strength on the 61.5 satellite. Otherwise there could be an issue with the box if you swap it with another reciever in the home, and the issue follws it you'll need a new box.
Oct 19, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Televison & Video Logo
119 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
