Question about Pioneer VSX-D710S Receiver
Pioneer vsxd710s no surround sound or digital signal
3 Suggested Answers
TotalControl
  • 23 Answers
SOURCE: pioneer remote for receiver
It's quite likely the codes are the same. Check the manuals for the models on Pioneer's website (www.pioneerelectronics.com) for the year/date they were issued. For most models issued around the same time the codes were the same, but they also post IR codes, so you can verify there as well. If you can't find any information I will give you info on ordering the exact remote you need and options for universal remotes that have your model.
Regards,
Vincent J. Bova
Total Control Remotes
Programming Remotes & Advanced Control systems
www.totalcontrolremotes.com
Posted on Dec 12, 2008
  • 33 Answers
SOURCE: how to hookup to u dvr dish reciever to pioneer surround sound
You will need to run the video cable to the telivision. You will need to take the digital feed from the dvr and run it into the pioneer digital input.
Posted on Jan 28, 2009
What does the button mean on this model mean simulated surround ,pioneer model vsx-9700s
It means that it takes a normal sound signal and turns it into surround sound.
Nov 29, 2016 | Audio Players & Recorders
I have a Pioneer VSX D412 S receiver with my Pioneer surround sound system The system SUDDENLY STOPPED RECEIVING SOUND SIGNAL FROM MY HD TV
  1. Turn the TV and receiver off and back on. This is called "power cycling" the devices.
  2. Check the menu settings to make certain the TV is still sending a sound signal out to the receiver.
  3. Disconnect the cable, blow both ends out, reconnect, and see if the cable was partially disconnected or has dust or lint interfering with the connections.
  4. Change the cable for another cable that you know to be working.
  5. Use a different source for the TV: DVD, Cable, different channel, etc.
  6. Connect the receiver to another TV.
Dec 16, 2015 | Pioneer Audio Players & Recorders
Pioneer M-EV51 surround problem.
TRY CONNECTING THE RCA JACK (RED,WHITE) AUDIO
INPUTS. MY GUESS IS THAT IT WILL WORK THAT WAY,
AND IF IT DOES CHECK ALL AUDIO SETTINGS ON BOTH
AMP & TV PCM digital audio / LPCM digital audio (LIMITED)
MAYBE BAD HDMI CABLE. SEEN IT SEVERAL TIMES B4
Nov 14, 2013 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Can I use my Pioneer VSX-D412 receiver to hook up my surround system to my new Samsung HDTV?
Yes, both receiver and tv have optical/digital connectors, or alternatively, the S-video connector. The Pioneer will decode the compressed 5.1 signal coming from the tv unit.
Feb 15, 2010 | Pioneer VSX-D412 Receiver
Pioneer vsx-519 no sound from center and surround
Make sure that the sound field/programme you have selected is dolby digital not stereo.(On the amp)
You also need to check on the display that is says DIGITAL not ANOLOUGE, as only a digital input, Optical fibre cable, HDMI, COAX will be a digital signal.
If you are using red and white rca connectors, it is not going to work, as this is an Anolouge signal.
Sep 08, 2009 | Pioneer VSX-818V-K Receiver
How to hookup to u dvr dish reciever to pioneer surround sound
Jan 28, 2009 | Pioneer Dolby Digital 5.1, Pro Logic II...
Reciever only allows 2 channels(speakers) at a time.
I had this problem too. Finally, after using the MCACC setup and making sure all the speakers worked, I found I had to set the source to FM, TV or whatever from the remote control and set the mode to advanced surround sound using the front panal button on the upper right. Had to fool with them a lot. Good luck.
Jan 03, 2009 | Pioneer VSX-818V-K Receiver
I have a jvc 1200 stero
As a general rule surround sound is only sent on HD signals for the dvd. Otherwise it comes to your home in basic stereo sound. Consult your user manual for ways to turn on simulated surround sound also known as Dolby ProLogic.
Mar 03, 2008 | Pioneer HTD-510 System
Hooking up to digital cable box
Darth,
There are 2 ways you can accomplish this.First is the least quality which is via coax.What you want to do is connect the cable service coming from the wall to the input on your cable box.Then the TV output on the cable box goes to the input on your surround sound then the coax goes from the surround sound to the coax input on the TV.The second is to Connect using the RCA AV1 input.what you want to do is look at the back of the digital cable box and locate the OUTPUTS for the RCA jacks(or AV output)connect RCA cables (yellow red white) to the 1st INPUT on your surround sound.depending on models you should have a couple of different INPUTS for a signal.Choose one and plug it in.After that take a second pair of RCA cables and connect them to video OUTPUT on the surround sound and connect them to your AV1 OUTPUT on your TV.With the original remote for your TV,NOT the cable universal one,Look for an INPUT button on the remote.Some are called input some are called SOURCE,TV/VIDEO basically it tells the TV what signal source to look at on the back of the TV.If you dont have the remote put the TV on channel 3 then press the channel down button and when the TV gets to channel 1 press it again and it should start cycling through the AV inputs,choose AV1.
Once you have done this you have correctly
hooked everything up,BUT Like I said depending on the model of surround sound you are going to have to CHOOSE or physically select or "tell" the surround sound receiver which input to RECEIVE the sound through.In general the INPUT on the back of the surround sound will be labeled with something like Video IN,VCR IN, DVD IN and so forth.Make sure the surround sound is selected to Receive the sound coming from the digital box.Sometimes there is a dial on the front of the surround sound that allows you to select which INPUT on on the back becomes active .make sure that what you have selected matches what you have your cable box is connected to.Hope this helps!
Nov 03, 2007 | Pioneer HTD-510 System
Pioneer VSX-D710S Receiver Logo
23 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
