Need driver for matsunichi external hard drive 1 tb for mac laptop
Matsunichi portable hard drive will not work on my macbook pro what driver do I need
  • 232 Answers
SOURCE: I am a new macbook pro owner. My new mac will not
Hello!!
The MAC is not recognizing HDD because it may not be in FAT or MAC OS X Journeled Format.
Please Follow below steps to Reformat the HDD to make it Compatible with MAC.
1. Connect the HDD.
2. Open Disk Utility from Applications -> Utilities
3. On left side of Disk Utility you'll find your HDD.
4. Click on HDD and select the Format TAB.
5. Reformat the HDD in FAT Format.
6. Click Apply.
7. Done.
Hope it Helps..!!
Posted on Jul 08, 2011
seekpcrepair
  • 39 Answers
SOURCE: One Touch 4 Maxstor 750 external hard drive installing on a macbook pro
If you have a hard-drive that is formatted as NTFS which stands for (New Technology File Ssytem), Mac OS X can only read the partition. It cannot write to it.
The trick is to use your drive manfacturer's disk-formatting software which will allow you to format your drive as one large partition. Formatting your drive as one large FAT 32 partition is the easiest way to make a drive so it can be used with both PC's and Mac's.
Another option is to use a third part utility so that you can read a MAC formated harddrive's from your PC. Here is one option: http://www.macdrive.com/.
Good luck.
SeekPCRepair
Posted on Feb 09, 2008
Clearercape
  • 38 Answers
SOURCE: Nexxtech usb external floppy drive
The simple answer to your question is yes. The trick is getting the external floppy drive.
If you have one you should be able to connect it to you mac and simply drag the files on to your desktop. Depending what the files are you should then be able to still read them and save them on the mac in a new format.
It really depends on what format the files are and what app they where created in.
Floppy disks! I have not come across them for years! The process is quite slow!
Posted on Oct 02, 2008
SOURCE: LaCie 1 TB Hard drive won't boot
I lave lots and lots of experience with LaCie Drives (I have 6 of the 2TB models). Every, every, every time a drive fails or runs slowly, it is the power supply. I have now replaced 5. They run very hot (so does the drive), and fail pretty often. It looks like the voltage drops just a smidge, and access times seem to increase, i.e., the drive "runs slow". Then it won't boot at all, and the blue light keeps blinking. Fortunately LaCie has replacement power supplies in the store. Buy a couple extra. I am married to the LaCie drives now, or I would probably switch brands. I kind of guess that they know about this because I contacted the help desk, and he wasn't surprised. Maxtor has a nice drive, and the Calvary drive is $150 cheaper. A drive is a drive I guess. By the way, if anyone is listening, how about building a QUIET, COOL drive with and INTERNAL POWER SUPPLY? GOT IT? All the cords and power supply bricks make me crazy. It might be nice to see a stackable drive where the top of one drive mates to the bottom of another, carrying network info as well as power to the drive above. Hint, hint. We all are building systems with ungodly amounts of storage. Too bad the manufacturers aren't building drives with the durability we need.
Posted on Oct 04, 2008
SOURCE: External hard drives not recognized by MacBook Pro using SIIG eSATA II 2 Port ExpressCard-M
Fixed- I purchased one of the following esata cards with the JMB360 chipset and it worked in my brand new Macbook pro 17" right out of the box.   My other eSata from SIIG, inc would not mount any drives or accept any drivers.    So the silicon based eSata's must have some type of hardware conflict with Macbooks.  (P.S.  I purchased the one from Best Connectivity for $20).   These cards all use the JMB360 Chipset:
  • ApioTek (1 port card) (EXTREME eSATAII Express Card)
  • Best Connectivity (1 esata)
  • GWC Technology (GWC BS1020) (2 ports)
  • nGear (Moved to the Sil3132 chipset list. See my more recent post about this)
  • PPA Int’l (2 ports)
  • VC (an original brand of Vintage Computer Inc.)
  • Syba (1 Port)
  • Sunix ECSA24J (Discontinued)
Posted on Feb 24, 2009
How do I fix my greyed out volumes in my Seagate 4 TB external drive?
Is it formatted to FAT by any chance?
Have you tried pluging it into another mac?
Or even a to a Windows PC?
Oct 15, 2016 | Apple Customized 15" MacBook Pro Laptop...
Drive does not appear on macbook pro
You need either need a driver to detect the hard disk or you will have to format hd.
Jul 25, 2014 | Western Digital WD Elements Portable...
How do I upgrade my macbook pro hard drive?
If this is the 2009 model with the DVD/CD drive, then you can add up to 8GB of RAM and a much larger hard drive. I have seen drives up to 1.5 TB, and they were not expensive (just over $100). Just search for an online retailer (or go to a local Apple service center) that specializes in upgrades for older MacBooks. You may need a special set of tools, and you can also buy a kit that will allow you to use your old hard drive as an external drive (but make sure you back everything up BEFORE you start to swap drives).
Jul 17, 2014 | Apple MacBook Pro MB991LL/A 13.3-Inch...
My Toshiba 250gb external hard drive model hddr250e03x is not recognized by my macbook pro but the light turns on. It works on my friend's macbook pro but not mine
I'm assuming you mean it doesn't appear in Finder. Open up disk utility and it should appear there if you say the MacBook is providing power to the hard drive light. You may have to reformat or reset your Mac if you want it in finder
Oct 14, 2013 | Toshiba Canvio 500 GB USB 3.0 Portable...
MacBook Pro 17'' Mid 2010 HEAT
if it doesn't get very hot, then everything's fine. Yes, you may try unplugging and see if it works.
Of course, it's better to call the Apple Support. Ask them about the problem and see if it is normal/not.
Jun 04, 2013 | Iomega eGo Portable 35814 1 TB External...
I just bought a Seagate 2 TB desktop drive for Mac and PC, it works on my PC but nothing happens on the MacBook
If the Seagate hard drive has been formatted on a PC in NTFS then the MAC cannot read and write to this hard drive.
To exchange data between the PC and MAC then the Seagate hard drive needs to be formatted on a PC in FAT32 not NTFS.
Dec 12, 2012 | Seagate FreeAgent GoFlex Desk 2 TB USB 20...
Is it possible to boot from an Iomega eGo Blackbelt Mac Edition Portable HD and also use it to clone an existing drive? I want to upgrade an existing 160GB Internal HDD in a Macbook Pro 17" to a...
It's possible to clone to this drive, but over the USB interface, it will be very slow. Firewire would be faster. It's also possible to boot from it, but again, it will be slower than an internal. What you've described, however, IS possible.
Feb 28, 2011 | Iomega eGo BlackBelt Portable Mac Edition...
I have placed this hdd into an external case to use as a portable drive but when i plug it in to my laptop (mac book pro) it starts to beep. Windows is installed on the portable drive i was hoping to plug...
at ATA hard drive there is no master or slave, if you want to make it master connect it at ATA slot 1 at mother board, and if you want to make slave connect it at ATA 2 at motherboard
i hope this helpfull
Jan 19, 2011 | Seagate MOMENTUS 5400.2 - HARD DRIVE -...
Hallo, I have a LaCie Grand 1 TP external harddrive. I cant work in mine hard drive. I cant throw anything away i cant rename documents or put new ones on it. Some background info A few months...
Hi
you may face this issue because of differences between mac and windows file systems/partition table and security attributes that may disallow any further changes.
1-try to connect you HDD to a windows Computer and Backup all your files before loses any data(use more newer version of windows like windows 10 build 1709 windows XP is old/out of services and has many problems)
2-after a full backup in windows try to connect your HDD to your mac and format it via your MacBook
3- after formatting your HDD try to reconnect your HDD to windows and copy your files to HDD(windows has a compatible file systems that could read/allow/write mac file systems/partition and its attributes)
4-enjoy
best regard
Sep 27, 2017 | LaCie Grand 1 TB USB 20 Hard Drive
My macbook pro does not recognized freeagent 1 TB. It sucks!!!!
You could contact Freeagent technical support at their website.
Jan 08, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Computers & Internet Logo
468 people viewed this question
David Payne
David Payne
