Question about Canon Pixma MX922
2500 code on mx922
Auto alignment has failed after several attempts to align them. error code 2500
SOURCE: print head alignment failed
Head Align Failed
Posted on Apr 17, 2008
sys_admin
  • 829 Answers
SOURCE: head align fail
Try cleaning the printhead with a cotton swab soaked in isopropyl alcohol.
Posted on Jan 14, 2009
57 varieties
  • 1653 Answers
SOURCE: auto head alignment
#1 of 2
Carryout a Manual Print Head Alignment If Possible.
If the results of Automatic Print Head Alignment are not satisfactory, follow the procedure below to perform Manual Print
Head Alignment.
1 Make sure that the machine is turned on, and then load three sheets of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Cassette.
Important. You cannot print the print head alignment pattern if paper of size other than A4 or Letter is loaded. Be sure to use A4 or Letter-sized plain paper.
2 Open the Paper Output Tray, and then open the Output Tray Extension.
(1) Put your finger in the rounded indent of the Paper Output Tray and open it gently.
(2) Open the Output Tray Extension.
3 Press the Paper Feed Switch to select the paper source where you have loaded paper.
4 Select Settings on the HOME screen.
5 Select Maintenance, then press the OK button.
The Maintenance screen is displayed.
6 Select Manual head align, then press the OK button.
The confirmation screen is displayed.
Note. If you select Head alignment print, the machine exits the process after printing the current head position adjustment values.
7 Select Yes, then press the OK button.
8 When the Print Head alignment pattern is printed, select Yes, then press the OK button.
9 Look at the printout. From the patterns, select the most even, least irregular patterns for each column and input their numbers. Press the OK button.
(1) Select a column to input the pattern number.
(2) Use the or button to input the number of the pattern.
(3) Repeat the steps (1) and (2) until you finish inputting all pattern numbers, press the OK button.
Posted on Oct 08, 2009
  • 78 Answers
SOURCE: Auto Head alignment has failed twice. Do I try
This depends on why it is failing. You can try to perform a manual alignment through the software if it will let you,(printers, properties, preferences, services, alignment) or just don't align the carts if not necessary (you don't see print defects). On this older model, it is possible that it is related to a scanner issue as well.
Posted on Sep 29, 2010
  • 71 Answers
SOURCE: Auto head align Fails screen says "change H
You need to print an alignment page. After you print it, you will be able to align the page using the up and down arrows.
Posted on Jan 27, 2011
I cannot get it to finish the "align print head." Keeps getting an error and support code 2500. This is getting to be very aggravating and I'm about to take it back the store.
Step by step Error code 2500 :
1. The printer is turned off, or die completely
2. Then your press the Resume Button, the button symbol or paper, hold down 3 seconds, not released.
3. Press the power button, Printer indicator Light Turn Green in the moments after the power button is on tap.
4. Remove the Resume Button but the power button still in a state of hold
5. Press and hold the power button, and the press the resume button as many as five times.
6. Release both buttons that you press simultaneously, or in parallel. usually after being released, the indicator is flashing or blinking while.
7. Seeing your computer, it will be detected that there is a new printer, wait until the computer has been detected such printer.
8. Turn off your printer, by pressing the Power button.
9. Wait until the printer completely dead in total, if it please Your Turn On Agai
Mar 24, 2016 | Canon Pixma MX922
I have a celestron Cosmos 90 GT Wifi telescope and so far haven't been able to use it. I struggle with aligning the telescope to 3 bright stars... if by chance it says its aligned when I choose a star
Aligning a scope requires several things to be correct.
1. You must follow the setup in manual 100%
2. You must pick the correct alignment stars. Most failed alignments are because you aligned on the wrong star. So alignment requires you to learn the names of a few bright stars and be able to spot them in the sky.
3. With many goto scopes there might be a "home position" to start the alignment. For example, tube pointed roughly North, and level. Check your manual for a "home position. Also time, date, and site must be correct.
Clear skies,
TelescopeMan
www.telescopeman.org and www.telescopeman.info
Feb 16, 2015 | Celestron COSMOS 90GT Wi-Fi Refractor...
I have changed all ink cartridges on my canon pixma ip4200 printer and it now doesn't work, the green and amber lights flash for 11 times and the cartridge carrier doesn't move. Please can someone advice...
From Canon Help Files.
Automatic Print Head alignment failed
Possible causes are as follows:
6128_image_6.gif A4 or Letter-sized paper is not loaded on the Auto Sheet Feeder.
Press the RESUME/CANCEL button on the printer to clear the error, then load one sheet of A4 or Letter-sized paper in the Auto Sheet Feeder.
Automatic print head alignment cannot be performed using paper from the Cassette. For automatic print head alignment, always load paper in the Auto Sheet Feeder.
6128_image_6.gif Print Head nozzles are clogged.
Press the RESUME/CANCEL button on the printer to clear the error, and then print out the nozzle check pattern to examine the print head condition.
For information on how to print a nozzle check pattern, see "Printing the Nozzle Check Pattern."
6128_image_6.gif The Paper Output Slot has been exposed to a strong light source preventing correct Print Head alignment.
Press the RESUME/CANCEL button to clear the error and move the printer to a darker location.
After carrying out the above measures, if the problem continues after aligning the Print Head again, press the RESUME/CANCEL button to clear the error, and then perform manual print head alignment. For details on manual print head alignment, see "Manual Print Head Alignment."
Sep 10, 2014 | Canon PIXMA Office Equipment & Supplies
Jan 27, 2011 | Canon PIXMA MP780 All-In-One InkJet...
I bought a new color print cartrige and since then my printer align cartridge keeps failing so I can't use my printer. I have reincerted them many times and ran the align cazrtride and I get the same thing...
Sorry to ask a dumb question but did you remove the protective tape on the cartridge when you installed it? If yes, then proceed to the following HP help page where the align cartridge error is outlined along with several solutions. Best of luck!
Greg
OfficeJet k60 Align Cartridge
Nov 06, 2009 | HP OfficeJet k60 All-In-One InkJet Printer
E16
press stop reset button for few seconds and you can use your black cartridge for printing,but do remember to put use black only setting in ur printer cartridge settings.
Nov 09, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Cartidge alignment
try to insert your old cartridge if you still have it...if the printer works then its your new cartridge that is having problem..its called factory defects.
Nov 01, 2007 | HP PSC 950 All-In-One InkJet Printer
Canon Pixma MX922 Logo
1,877 people viewed this question
old marine
old marine
