Question about HP Computers & Internet
Error code 0x80070037
Hi! I try to copy file from my laptop to my Hp external HDD. It's just keep sayin Error code: 0x80070037 : the specified network resources or device is not available. how should i fix it? anyone can help?
micromaster
  • 3614 Answers
SOURCE: error copying file or folder
One of the most important yet overlooked elements of PC maintenance is data backup. If you do not perform regular backups, chances are your productivity will eventually suffer from data losses or a failed Windows installation.
All versions of Windows after 3.1 ship with a free backup utility called Microsoft Backup. It is not the best backup program available, but it may be sufficient for your needs. (Backup is better in later versions of Windows. Microsoft recommends Win98/Me users purchase a third-party utility.) If you want more control over your backups, consider purchasing a third-party program.
Backup is part of the System Tools utility. However, Setup does not install it by default in Win98/Me/XP Home. If you cannot locate Backup, visit the Microsoft support site and query for article No. 152561 (Win98), No. 264541 (WinMe), or No. 302894 (WinXP Home).
In Win98/Me, click Start, select Programs, Accessories, System Tools, and click Backup. To create and run a backup, click the Create A New Backup Job radio button and click OK. Follow the prompts to create a full or partial backup. If you want to create a backup set and run it later or run an existing backup set, open Backup and click the Open An Existing Backup Job radio button and click OK. You can now access the main Backup dialog box.
In Win2000/XP, navigate to the System Tools utility and select Backup. Click the Backup Wizard button. If you do not see a Backup Wizard button, click the Welcome tab. In WinXP, the wizard will start automatically if you are in wizard mode. Follow the prompts to create your backup set.
When you reach the last dialog box, Completing The Backup Wizard, you can click the Advanced button to create a backup schedule (this option is not available in Win98/Me). When you reach the When To Back Up dialog box, select the Later radio button and click the Set Schedule button. Perform data backups on a schedule that is appropriate to the importance of your files (once a week is a common timeframe). You should also perform a system backup at least once a month.
If you do not want to use the wizard, or you are working with an existing backup, open Backup and click the Backup tab to access the main Backup dialog box.
Posted on Feb 11, 2008
  • 39 Answers
SOURCE: cannot copy large files onto my WD passport
Your drive is probably in FAT32 format.  FAT32 has a 4GB file limit that is why your 5GB movie isn't saving.  You will have to format the drive in Mac OS file format (HFS) using Disk Utility.
Unfortunately once its in Mac format the drive will not be recognized by windows PCs.  What I do is have a program called macdrive installed on my windows computers so that they can access mac format hard drives.
i hope this helps!
Posted on Nov 26, 2008
Rajan Solank
  • 62 Answers
SOURCE: Write Protection on Hard Drive
I think your machine could be affected with a virus. Most of the viruses do that to block you to access the hard disk or any external media. Try this good antivirus that i have come across the net its a demo version that works for 30 days but it will do you good.
Here is the download link:
http://download4.quickheal.com/builds/eval2009/tsntevl.exe
You can also visit the website at www.quickheal.co.ke
And the forums at
http://support.instaconnect.co.ke/forum
Thanks
Posted on May 24, 2009
  • 10406 Answers
SOURCE: Error code 0X80070571 with the external HDD
The Seatools test has verified that the "physical" hardware is working fine, which is good news.
However, the error-message "disk structure is corrupted" means that there is a "logical" problem. Compare it to a book with a Table of Contents that has been overwritten by a two-year-old with crayons;
the pages are not physically torn nor missing, but you cannot "read" the original Table of Contents information.
Connect the drive, and note which drive-letter that Windows assigns, e.g., 'E:'.
Click Start
Click Run
Type CMD and press ENTER
Type CHKDSK E: /F and press ENTER,
and let Windows try to reconstruct the Table of Contents on the disk.
Posted on Jan 02, 2010
Testimonial: "Master ikkenom,there is a reason for your titel!FYI,it worked perfectly fine on my computer but I had to start the same procedure on a different comp?"
Jack_Dawson
  • 287 Answers
SOURCE: I`m using Windows XP and trying to transfer my pix
1. 'Take no Action' option is OK!
2. Try to connect again the data cable to passport HDD and check whether the driver for passport is installed properly!
tell me if it helps...tc! :)
Toshiba multimedia error 0x80070037
if you want to know what this is the error code is related to
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
hope it helps
Jun 19, 2012 | Toshiba STOR.E EDITION 1TB USB3.0 blk
Archos AV700 I/O Error
Offhand, I would suspect that the remaining files were somehow corrupted. Is it possible for you to verify those files using the external HD and a PC?
Either that or the format of the Archos AV700 was not that "clean" and would require a redo.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 15, 2008 | Archos AV700 Digital Media Player
I can not copy or remove files tot mine extern harddisk Maxtor and the error shows 0x80070571. What can i do? How to repair I have already done cksdsk but is does not help
There are several things that come up for this error message.
1. The files you are trying to copy over to your external maybe corrupt. (What type of files are you trying to copy, windows files or just personal data ?)
2. Your External HDD is either damaged, or not hooked up correctly. Make sure all cables etc are secure and working, try a different set of cables if possible.
3. You can try this tool that will analyze your hard drive for problems. CLICK HERE.
Post back if you have any questions or comments.
Mar 21, 2011 | Computers & Internet
Having problems with my Dell laptops' hard drive so I ran diognostics and came back with the 2000 0146 error code and after a bit of research found out a good way to try and save my files is with a "USB...
Hi Lofimodernis
Regarding your inquiry unsing a USB 2.0 external or HDD enclosure is basically used to connect a laptop HDD to another computer to be used to extract or back up files on to new HDD or another device. regarding with the error 2000 0146 as far as i can remember as a technician when it comes to dell laptops it would really be a HDD replacement
Hope I have answer your inquiry about the USB 2.0 external enclosure
Thank you for choosing fixya support
Sep 15, 2010 | Dell Vostro 1710 Notebook
Blue screen error
I see ..either teh installation didnt complete the loading of the files..or you didnt format the Hdd proper...try to reformat it in the NTFS normal mode...and change the installation cd ..cause in the proces there might have been a file it couldn't copy ..and skip it ...keep trying cause sometimes it does that ...if the server went fine ..this means that the HDD its ok ..and the problem is the installation disk ...with xp on ...
Aug 04, 2009 | HP Pavilion zd8000 Notebook
Cannot read/write
Try both moving it to different computers and reinstalling drivers.
Feb 14, 2009 | Vantec 1 Bay NexStar 3 USB 2.0 External...
I/O device error Lacie mini ethernet drive
- Try to install proper drivers for your operating system.
- Check if your device is supported with that server/pc ? does server supports USB2.0 ?
Update NIC drivers to the latest level
Aug 02, 2008 | Computers & Internet
Install of IBM infoprint printer drivers
make sure you are logged on a the Administrator to the computer then try installing..
Dec 26, 2007 | Office Equipment & Supplies
Computers & Internet Logo
82 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
