Question about Dell 1710 Laser Printer
All available lights on printer are flashing
Hello to All! My Dad and I have been trying to figure out this printer problem all day. Normally we would just contact support, but our warranty just ran out and we're looking for answers! Problem: When we turn the printer on, all of the lights available starts flashing in unison. Things We've Tried: 1. (A) We've pushed the "Continue" button repeatedly, and found that the light sequence changes to the "Continue" button, the "Remove/Paper" light, and the "Error" light flashing in unison. (B) So we push the "Continue" button repeatedly again and the "Ready/Data" light and the "Error" light are the only ones flashing, or even lit up, now. 2. We've tried the Manual reset, but still got the same 'all lights flashing' code. 3. We've tried disconnecting and reconnecting the printer to the computer. 4. We've tried turning off and on both the printer and the computer separately. Any ideas anyone!? Do we just need to buy a new Printer!? Thanks for any suggestions!!!
  • Pat Rice Nov 09, 2007
    Same problem.
  • 3 Answers
Do what Thom361 suggests as the first alternative. But according to Dell svc manual for this printer the all lights flashing indicates a bad controller card. This is the brains of the printer. Once it is bad the printer is a large paper weight.
I agree with guest - avoid DELL printers, they are junk. I work with them everyday and our tech staff was very sorry when our company went with DELL instead of HP for our printers.
Posted on Jan 14, 2009
I did have the same problem until we powered the printer off, pressed & held the Continue button down while powering the unit back on. After holding the button down for about 10 seconds after it was powered back on the READY green light came on & the printer started printing again. Yea!!!
Posted on Jun 24, 2008
More or less your printer fuser has gone bad. Replace the fuse. I suggest that when buying a printer you don't with dell 1710N these printers gives a lot a problem. I work with them every day at work.
I suggest that you go with HP.
Posted on Dec 06, 2007
6ya staff
SOURCE:
Sony bravia KDL-46EX725 6 flashing red light
Check the power supply. IT might have bad caps.
Aug 30, 2013 | Televison & Video
About 2 weeks ago my check engine light came turned on so i drove home and told my dad about it but when we turned the car on it did not flash. But the the next 2 days it stayed on and the next morning...
Any time you get any check light, you should
be at a repair in a couple of days, or at least
check for codes. Still need it diagnosed and
repaired in a week
Otherwise you waste gas,polute the air or could
cause some damage,as you don't know what the issue
is that set the light
The fact the check light went out, doesn't mean
the problem went away.
Don't clear any codes you find,their needed to diagnose
the system faults
Apr 05, 2011 | 2006 Mitsubishi Eclipse
When i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked...
when i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked normally after being off for a couple of days, but now it is doing that again.
Amber light flashes 7 times, then green for a couple of seconds, then amber 7 times etc.
Jun 02, 2010 | Canon BJ I6500 InkJet Printer
I have the printer but dont have cd how can i download from web
Hello - it looks like this driver is readily available from the Canon website - go here.
Hope this helps!
-KC GTO Dad
Sep 18, 2009 | Canon FAXPHONE L80 Laser
Status light solid red not printing
Press the menu button for 20 sec and then try to turn on the printer
Sep 15, 2009 | Brother HL 5140 Laser Printer
Ink light and paper feed light are flashing alternatively, printer not responding at all !
I just had this same problem, and came here to figure out what to do about it. Turns out I had the CD/DVD tray in the out position, so all I had to do was flip the switch to stow it and the flashing lights stopped. Maybe it will work for you as well.
Aug 22, 2009 | Epson Stylus Photo R260 InkJet Printer
All the lights on my HP 1350 printer are blinking and it will not print. Normally where you could put the number of copies i " E" is in thaat spot.
In addition to providing information about current tasks, the lights on the front panel can also indicate error conditions, as described in the table below:
If the On light, Check Print Cartridge light, Check Paper light, and Start Copy, Black and Start Copy, Color lights are all flashing, do the following:
1 Verify that the front-panel overlay is attached to the HPPSC.
2 Turn your HPPSC off and on by disconnecting the power cord and reconnecting.
Alternatively,
All ights blinking: An error caused the HPPSC to stop functioning.
1 Turn the HPPSC off and then on.
2 Restart your computer.
3 If the problem is not corrected, unplug the HPPSC and plug it in
again.
If the problem persists, contact HP.
Apr 26, 2009 | Office Equipment & Supplies
Ink everywhere
You have to check if the waste pad of the printer is full. If this occurs, you have to call a technician to replace it (or yourself can do , if you are able to). With the waste pad replaced, you can reset the internal counter with this program :
http://www.ssclg.com/epsone.shtml
This program can show you if the waste pad is full, or what problem is happening.
Apr 19, 2008 | Epson Stylus C86 InkJet Printer
Printer stopped printing, all lights flashing
Sounds like a bad cartridge. 45's, 15's 23's & 78's seem to do that. Replace the cartridge, but try wiping the copper strips on the cartridge and where they fit into the printer as well with some alcohol on a paper towel. if , not, put the old ones back in. if it still does it, it might be simply dying.
Jun 05, 2007 | HP DeskJet 895cxi InkJet Printer
Dell 1710 Laser Printer Logo
265 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
