Question about 3D4Medical.com Skeletal System
What are joints - 3D4Medical.com Skeletal System
Whats the part number for a front passenger side lower ball joint on a 96 dodge stratus?
SponsoredShop for Whats the part number fo... on Google
Moog K500007 Lower Ball Joi...
$33.26
Jet.com Moog K6117T Ball Joint
$27.79
Walmart Parts Master K9385 Lower...
$10.97
Jet.com Control Arm W/ball Joint Fr...
$59.70
eBay Ball Joint ? Lower/Upper...
$22.95
EPI Performa... Search Results
    Ball Joint - Lower at AutoZone.com - Best Ball Joint - Lower ...
    www.autozone.com/suspension-steering-tire.../ball-joint-lower
    AutoZoneShop for Ball Joint - Lower products with confidence at AutoZone.com. Parts are justpart of what we do. ... Duralast/Ball Joint - Lower, Part Number: FA1490 ...
    Dodge Stratus Ball Joints ' eBay
Dec 06, 2015 | Dodge Cars & Trucks
What is the difference between osteoarthritis and rheumatoid arthritis?
Osteoarthritis (OA) is a condition that affects the whole joint including bone, cartilage, ligaments and muscles.
Osteoarthritis may include:
  • inflammation of the tissue around a joint
  • damage to joint cartilage - this is the protective cushion on the ends of your bones which allows a joint to move smoothly
  • bony spurs growing around the edge of a joint
  • deterioration of ligaments (the tough bands that hold your joint together) and tendons (cords that attach muscles to bones).
Rheumatoid arthritis (RA) is an autoimmune disease that causes pain and swelling of the joints. The normal role of your body\'s immune system is to fight off infections to keep you healthy. In an autoimmune disease, your immune system starts attacking your own healthy tissues. In RA, the immune system targets the lining of the joints, causing inflammation and joint damage. RA usually affects smaller joints, such as the joints in the hands and feet. However larger joints such as the hips and knees can also be affected.
Sep 02, 2014 | Miscellaneous
Trying to change my upper ball joint. Passager side
For your problem,check out this few help links.
Click the link below to go through its procedure:----Upper Ball Joints inspection and replacement? http://howtobyme.blogspot.in/2012/02/upper-ball-joints-inspection-and.html------- How to Test Upper and Lower Ball Joint? http://repairhelpcenter.blogspot.com/2011/12/how-to-test-lower-ball-joint.html------- How to inspect Upper and Lower Ball joint? http://repairhelpcenter.blogspot.com/2011/12/how-to-inspect-lower-ball-joint.html------ How to Service Ball Joints on Car? http://repairhelpcenter.blogspot.com/2011/12/how-to-service-lower-ball-joints-on-car.html----------- How to Replace Ball joints? http://repairhelpcenter.blogspot.com/2011/12/how-to-replace-lower-ball-joints.html--------- Lower Ball Joints replacing on Mitsubishi car? http://howtobyme.blogspot.in/2012/02/lower-ball-joints-replacing-on.html
-------------These details will help.For more help,keep updated,with car brand,model and year.Thanks.Helpmech.
Oct 05, 2012 | Cars & Trucks
How to replace ball joints on a 1998 mercedes benz s420
For ball joints issue.Before replacing it,first inspect and test the ball joints to confirm the problem:----Click the help links below to troubleshoot the problem and replace the ball joints:----Upper Ball Joints inspection and replacement? http://howtobyme.blogspot.in/2012/02/upper-ball-joints-inspection-and.html How to Test Upper and Lower Ball Joint? http://repairhelpcenter.blogspot.com/2011/12/how-to-test-lower-ball-joint.html How to inspect Upper and Lower Ball joint? http://repairhelpcenter.blogspot.com/2011/12/how-to-inspect-lower-ball-joint.html How to Service Ball Joints on Car? http://repairhelpcenter.blogspot.com/2011/12/how-to-service-lower-ball-joints-on-car.html How to Replace Ball joints? http://repairhelpcenter.blogspot.com/2011/12/how-to-replace-lower-ball-joints.html Lower Ball Joints replacing? http://howtobyme.blogspot.in/2012/02/lower-ball-joints-replacing-on.html----------This will help.Thanks.
Jan 31, 2012 | 1991 Mercedes-Benz 420
Have had to replace ball joints 3 times on my 97 lumina, any ideas why
Always use original parts instead of aftermarket products.Original parts cost bit extra,but they are exact fit and last longer.Click this link below to troubleshoot the issue :----Upper Ball Joints inspection and replacement? http://howtobyme.blogspot.in/2012/02/upper-ball-joints-inspection-and.html How to Test Upper and Lower Ball Joint? http://repairhelpcenter.blogspot.com/2011/12/how-to-test-lower-ball-joint.html How to inspect Upper and Lower Ball joint? http://repairhelpcenter.blogspot.com/2011/12/how-to-inspect-lower-ball-joint.html How to Service Ball Joints on Car? http://repairhelpcenter.blogspot.com/2011/12/how-to-service-lower-ball-joints-on-car.html How to Replace Ball joints? http://repairhelpcenter.blogspot.com/2011/12/how-to-replace-lower-ball-joints.html Lower Ball Joints replacing on car? http://howtobyme.blogspot.in/2012/02/lower-ball-joints-replacing-on.html
Jan 17, 2012 | 1997 Chevrolet Lumina
Ball joint repair and how do you do it
To perform the following procedure, the lower control arm must be removed from the vehicle. Refer to Removal And Installation for that procedure.
  1. Using a screw driver or other suitable tool, pry the seal boot off of the ball joint assembly
  2. Position receiving cup, Special Tool 6758 to support lower control arm when removing ball joint assembly. Install Remover, Special Tool 6919 on the top of the ball joint assembly.
  3. Using the arbor press, press the ball joint assembly completely out of the lower control arm.
NOTE: When installing ball joint in lower control arm, position the ball joint in control arm so notch in ball joint stud is in the direction shown. This will ease assembly of the ball joint to the steering when installing pinch bolt.
  1. By hand, position ball joint into ball joint bore of lower control arm. Be sure ball joint is not cocked in the bore of the control arm, this will cause the ball joint to bind when being pressed into control arm.
  1. Position control arm with installed ball joint, in an arbor press with Receiving Cup, Special Tool 6758 supporting the lower control arm. Then center Installer, Special Tool 6908-4 on the bottom of the ball joint
  2. Carefully align all pieces. Then press the ball joint into the lower control arm until it is completely seated against surface of lower control arm. The ball joint is correctly installed when there is no gap between the ball joint and the lower control arm. Do not apply excessive force against the ball joint or the lower control arm.
  3. Install a NEW seal boot by hand as far as possible on the ball joint. Installation of the seal boot is to be with the shield positioned as shown.
CAUTION: Do not use an arbor press to install the sealing boot on the ball joint. Damage to the sealing boot will occur if excessive pressure is applied to the sealing boot when it is being installed.
  1. Place Installer, Special Tool 6758 over seal boot and squarely align it with bottom edge of seal boot. Apply hand pressure to Special Tool 6758 until seal boot is pressed squarely against top surface of lower control arm.
CAUTION: A replacement ball joint is not pre-lubricated. Properly lubricate the replacement ball joint using Mopar Multi-Mile grease or an equivalent. Lubricate ball joint after seal boot is installed but prior to top of seal boot being pushed down below notch in ball joint stud. Air must vent out of the seal boot at notch when grease is pumped into ball joint, failure to do so will balloon and damage seal boot. Do not over grease the ball joint, this will prevent the seal boot from pushing down on the stud of the ball joint.
CAUTION: After the ball joint is properly greased, clip the end of the grease fleeing off below the hex. The ball joint seal boot is non-purgeable and further greasing is not required and can result in damage to the seal boot.
  1. Reinstall lower control arm on vehicle.
Mar 07, 2011 | 2000 Dodge Caravan
Cv joint but the plastic thang that go around it
One would have to remove the half shaft to service the cv joint properly.
Oct 08, 2010 | 2004 Oldsmobile Alero
Front brake rotors.
1. Loosen the wheel nuts slightly. 2. Raise the front of the car and support it with safety stands in the proper locations. 3. Remove the wheel nuts and front wheel. 4. Remove the brake hose mounting bolts. 5. Remove the caliper bracket mounting bolts, and hang the caliper to one side. CAUTION: To prevent accidental damage to the caliper or brake hose, use a short piece of wire to hang the caliper from the undercarriage. 6. On ABS equipped vehicles, remove the wheel sensor wire bracket, then remove the wheel sensor from the knuckle but do not disconnect the wheel sensor connector. NOTE: Use ball joint removers to separate the ball joints from the suspension or tie-rod end. 7. Clean any dirt or grease off the ball joint. Remove the cotter pin from the tie-rod end ball joint castle nut and remove the nut. 8. Apply grease to the special tool on the areas shown. This will ease installation of the tool and prevent damage to the pressure bolt threads. 9. Install a 10mm hex nut on the ball joint. Be sure that the hex nut is flush with the ball joint pin end to prevent damage to the threaded end of the ball joint. 10. Adjust the jaw spacing by turning the pressure bolt. NOTE: If necessary, apply penetrating type lubricant to loosen the ball joint. 11. Once the tool is in place, turn the adjusting bolt as necessary to make the jaws parallel. Then hand tighten the pressure bolt, and recheck the jaws to make sure they are still parallel as pictured above. 12. With a wrench, tighten the pressure bolt until the ball joint shaft pops loose from the steering arm. WARNING: WEAR EYE PROTECTION. THE BALL JOINT CAN BREAK LOOSE SUDDENLY AND SCATTER DIRT OR OTHER DEBRIS IN YOUR EYES. 13. Remove the tool, then remove the nut from the end of the ball joint and pull the ball joint out of the steering/suspension arm. Inspect the ball joint boot and replace if damaged. 14. Remove the cotter pin from the lower arm ball joint castle nut, and remove the nut. 15. Install a 12mm hex nut on the ball joint. Be sure that the hex nut is flush with the ball joint pin end, or the threaded section of the ball joint pin might be damaged by the ball joint remover. 16. Use the ball joint remover, 32mm, as shown to separate the lower ball joint and lower arm. NOTE: If necessary, apply penetrating type lubricant to loosen the ball joint. 17. Remove the knuckle protector. 18. Remove the cotter pin from the upper ball joint castle nut, and remove the nut. 19. Install a 10mm hex nut on the ball joint. Be sure that the hex nut is flush with the ball joint pin end, or the threaded section of the ball joint pin might be damaged by the ball joint remover. 20. Use the ball joint remover as shown to separate the upper ball joint and knuckle. NOTE: If necessary, apply penetrating type lubricant to loosen the ball joint. 21. Pull the knuckle outward and remove the driveshaft outboard joint from the knuckle by tapping the driveshaft end using a plastic hammer, then remove the knuckle. 22. Remove the knuckle from the hub unit. 23. Remove the four flange bolts, then separate the hub unit from the brake disc.
Jun 08, 2009 | 1994 Honda Accord
Replace ball joints
Remove in this order: wheel, loosen the 4 lower ball joint set bolts, cotter pin and nut from tie rod, tie rod from ball joint bracket, ball joint from lower control arm, 4 lower ball joint set bolts, ball joint from suspension. Install is reverse but don't tighten the 4 lower ball joint set bolts.
torque is as follows:
ball joint to control arm- 112 ft-lbs
Tie rod nut- 67 ft-lbs
lower ball joint set bolts- 83 ft-lbs
remember to use a new cotter pin
Oct 08, 2008 | 2004 Toyota Tacoma
3D4Medical.com Skeletal System Logo
87 people viewed this question
Top 3D4Medical.com Apps Experts
Erin Wood
Erin Wood
Are you a 3D4Medical.com App Expert? Answer questions, earn points and help others
