Question about Refrigerators
795.77546600 dispenser button assembly replacement?
Ripped the lever cover on my 795.77546600 Kenmore Elite dispenser. Think I need to buy 5021JA3020B to replace it but am unclear how I would take out the ripped piece and put a new one in.
    Novelist:
  • 126 Answers
Haven't worked on that one so I don;t know but you might find your answer in the repair manual here:
http://www.appliancefactoryparts.com/content/pdfs/123619-8.pdf
Posted on Nov 23, 2013
4 Suggested Answers
SOURCE: water dispenser lever on Frigidaire
My Frigidaire side by side is a little different from tech17's solution. It has no slots for a screwdriver to pry it off. It is a model FLSC23F6D55 manufactured 3/05. There is a semicircular spill tray in the bottom of the recessed water station. Just pry out the tray, from the bottom corner of the frame from the side and or bottom. (I did this with a knife blade.) This tray is a snap-in fit. Then you will see three phillips head screws in the bottom of the frame. Take out these three screws and remove the frame by lifting up on it and pulling out at the bottom. Then take out three more phillips mounting screws to remove the processor card and key pad. You will then see the top of the water lever mounting. The lever comes out by removing two more screws that hold the pivot shaft of the lever. (These last screws are a little more diffiucult to get to, but not anywhere near impossible.) I wish you well.
Posted on Jul 13, 2008
  • 9 Answers
SOURCE: I need to replace the Ice dispenser lever in ny
Unless the old one actually broke, you can re-install it if it merely fell off. Use a mirror and a flashlight to see the hole on the side toward you so that you can re-insert the lever that goes towards the front, then re-insert the lever into the back hole. If the lever actually broke, the new lever will come with directions on how to install it.
Posted on May 14, 2009
  • 39 Answers
SOURCE: only crushed ice comes out of dispenser
your model # is incomplete but here it goes.
1.take your ice container out and run hot water thru it. you want to defrost all of the ice build up inside of it's housing.
2. make sure the long lever under the container moves up & down when you press on it.
3.w/the container removed, you will see a fork like object and next to it amn openning w/a small plastic square part inside. make sure that part moves freely up & down. that solenoid is what gives cubed ice.
let's start there first
Posted on Jul 15, 2009
Soap dispenser motor turns but gets stuck and bends the arm up away from the dispenser. The washer makes clicking noises and stops. Took the top off to see the problem but then it did not repeat. I am...
this sounds like the same problem I am having. I think you need to just replace that arm which is called the dispenser lever. that plastic piece is too flimsy. hopefully the new parts are made better. I have to leave my top open and move it manually when it gets stuck.
Aug 08, 2013 | Kenmore Elite HE5t Washer
Kenmore Elite 5t shows an F30 code, water fill solenoid is making a noise like its not opening
This is a dispenser motor issue. If you pull the unit out and remove the 3 screws coming into the back of the top panel, you can remove the top panel to access the top of the dispenser. There is a motor that turns a plastic lever on the dispenser. you might be able to manually help the arm move to get past the error code, but ultimately you will need to replace the dispenser motor. Here is the part to order.
Dec 03, 2012 | Kenmore Elite HE5t Washer
I have a kenmore elite HE3 t and latley after it's
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 04, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Jul 24, 2009 | Refrigerators
Replace dispenser arm
on the bottom of the ice dispenser front cover is 2 slots insert a small screw driver into these slots and carefully pry the cover off (be careful not to scratch your door) one the cover is off there will most likely be a wiring harness that you can unplug and put cover out of your way. next you will need to move the white bracket out of your way there is either 2 thumb latches or 2 screws that seure it. it will not come all the way out so you may need someone to hold it out of the way for you. in the center of both of your levers you will see 1 screw with a cardboard spacer and brass spring BE CAREFUL NOT TO LOOSE THESE! remover screw spacer and spring afte that you should be able to work the levers right on out. the ice lever is a little tricky trying to get it around the ice door but it will come out.
Jan 31, 2009 | Refrigerators
Replacing the Ice dispenser motor on Kenmore elite refrigerator?
There is a small door under neath ice maker shelf (literally) w/ 2 small screws that keep it in place,or a button that can release ice maker on the rt. side of machine. Good luck!!
Dec 30, 2008 | Kenmore 53642 / 53644 Side by Side...
Replacing water fitting assembly
water dispenser continues to run too long after removing glass
Oct 23, 2008 | Refrigerators
Dispenser motor
Did the repairman replace anything? Do you still need assistance? If so...the dispenser motor and switch can be checked by removing the connector plug from the Central Control Unit (CCU). This is the 4th connector from the Left in the front of the control board. A resistance reading across pins 1 & 3 on the connector should read 1400 ohms. Readings across pins 5 & 6 should read 0 ohms. If any of the readings are abnormal, replace the dipenser motor and switch assembly. If the readings are normal, you may have an actuator cam on the dispenser that is not functioning properly. Or, spring lever & connection lever that are broken. All the parts combined would cost you less than $60 if you pursue the option of repairing this yourself. Searspartsdirect.com has the parts you need. Just type in your model number and the parts will be listed as items 11, 12, 13, 15 and 16 under the "Dispenser" heading. More than likely the motor is good and you have something wrong with either the switch or the spring lever and/or connection lever. I hope this helps you.
May 29, 2008 | Kenmore Elite 45986 Front Load Washer
Water Dispensing System
Check that the dispenser is not locked. Some models have a lock feature that deactivates the dispenser levers and control buttons. The lock button is on the dispenser front cover. This feature controls unintentional dispensing during cleaning. Press the "Unlock" or "Locked" button to reactivate the dispenser levers and allow dispenser function. You may need to hold the button for 2 to 3 seconds.
http://whirlpool.custhelp.com/cgi-bin/whirlpool.cfg/php/enduser/std_adp.php?p_faqid=110&p_created=1147725595&p_sid=lTIkCMOi&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MzEmcF9wcm9kcz0xOTkmcF9jYXRzPSZwX3B2PTEuMTk5JnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9d2F0ZXIgZGlzcGVuc29y&p_li=&p_topview=1
Oct 20, 2007 | Whirlpool GC5SHEXN Side by Side...
Refrigerators Logo
66 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
