Master gear PA66-GF40 - Office Equipment & Supplies
98 gmc sonoma part # pa66 what is it for
We can't know this.. Most of us know what the part is when we see it on the vehicle. pa66 is an after market part. Manufacturers number are longer and say GM on them. If it electrical, what happens when you unplug it.. Or what the problem now?
Oct 03, 2016 | 1998 GMC Sonoma
PA66 Diagram
That's a bit better. Where did that plug come out of? Looks to be under dash. And My guess guess is the resistor plug for the blower resistor. Could be the control panel.. Guessing though.
Oct 03, 2016 | Cars & Trucks
Fiat x19 1.5 unoturbo motor & gear box, how do I adjust the gear cables on gear box , as I cannot get 1st gear , I do have clutch , and installed new clutch & master cylinlinders. There are two...
were the master cylinders bled when you installed them..if not the clutch is not fully releasing..this will keep the gears turning and the syncronizers will not allow first or reverse as these are both extremely low and the car needs to almost be completely stopped..before they will go in..
Dec 23, 2013 | Lincoln Mark VIII Cars & Trucks
Pa66 gf33 on 2004 Dakota it has a leak. what is it
purge selenoid for evap system. try pluggin your vacume line
Aug 05, 2013 | Cars & Trucks
Where can I get the selector switch XK2 series 25T125 U.PA66 part
Im looking for exactly the same thing. Any luck locating it?
Nov 08, 2011 | Holmes Products HWH2605-U Heater
2001 olds bravada airpump part PA66-M40 BROKE small vaccum attachment
that is not a part number for your olds, that is the number that was molded into the plastic part. pa66 is a plastic resin used on many automotive parts.
Apr 16, 2010 | 2001 Oldsmobile Bravada
Reel mower isn't engaging -- blades aren't rotating and cutting
Remove the wheels and check the gears inside.
It sounds like they are worn or sheared and need
renewing
Jun 05, 2009 | Great States Corp. 16 In. Scotts Elite...
Radiator Water Distribution Hose
this is called the upper radiator hose.it comes with the plastic elbow and hose,all you have to do is install it.see pic;w01331625721.jpg
Jan 13, 2009 | 1999 BMW 328 Series
297 people viewed this question
jasbo
jasbo
