Question about Electrolux E42BS75EPS 26 CuFt Built-In Side by Side Refrigerator
Not running
I have a electrolux E42BS75EPS it does not run all lights works and front display works ..... the evaporator fan , condensing fan and compressor doesn't run i already replaced the main board and still the same . can somebody help me
    Sergeant:
  • 446 Answers
Make sure it is not in "Demo" mode
Posted on Nov 23, 2013
  • israel
    israel Nov 23, 2013
    I checked that is in normal operation mode I also checked all the wiring and everithing looks fine .
Electrolux diagnostics for refrigerator with freezer on bottom
Hey friend, thank you for your post!
Based off the information you have provided your Electrolux refrigerator is running but not cooling. It could be possible that your refrigerator is stuck in a defrost mode. I would suggest resetting your appliance which can be done by flipping the household circuit breaker for roughly ten minutes. If that does not correct the issue I would seek assistance from a professional to come repair your appliance. -Matt
Aug 18, 2014 | Electrolux EW28BS71IS (278 cu ft) Bottom...
Condenser fan not working
if evaporator fan inside refrigerator is running check for blockage at condenser fan, if no blockage condenser fan is the problem
Aug 24, 2012 | KitchenAid Superba Architect KSCS25INSS...
Mv450 scotsman high pressure
Check to make sure the condenser coil is clean, fan motor is running during freeze cycle. High Ambient temp, Ventilation, The higher the temperature entering the condenser coil the higher the head pressure. Fan motor failure, pressure switch failure. The cut out pressure varies 400, 450 or 500 PSIG. Water supply failure. not enough water running over the evaporator plate will cause high presser.
Jul 30, 2012 | Scotsman Cooled Modular Contour Cuber Air...
WRS6R3EW8 Refrigerator and freezer not cooling. Evaporator coil 60 deg. only. Compressor, evaporator fan and condenser fan running. Some frost on the tubing coming from condenser at the evaporator. ...
Where is it frosting, condenser or evaporator? If you mean frosting on evaporator line to compressor, probably iced up evaporator. If you mean frosting after condenser by capillary, unit short of gas/ blocked.
Apr 27, 2012 | Refrigerators
The fridge is working whit out stop
If the unit is running all the time and is not freezing everything then open the back fiberboard panel and clean out the coils in the back. Check to make sure the condenser cooling fan is running also. If the compressor is running and the condenser fan is not running there is a problem with the condenser fan. The compressor, condenser and evaporator fans all should be running at the same time. the condenser fan can be stuck... have dry bearings... of simply has failed. Before removing the back cover... touch the chassis were the doors close... it should be warm but not VERY warm to the touch. If it is VERY warm to the touch... for sure you have a problem with the condensor fan.
Since you did not say anything other than the fridge is working whit out stop, I have to assume at this point that the evaporator fan is running in the freezer compartment just fine.
I really need to know:
1. Is there ice in the back of the freezer compartment?
2. Is the evaporator fan running?
3. Is the condenser fan running?
4. Are the condenser coils clean?
One of the above has a problem... you just need to identify which one.
Thanks for choosing FixYa,
Kelly
May 14, 2011 | Sharp Refrigerators
I have a hoover 505 upside down fridge, it has the motor constantly running and the fridge is not getting cold
Hi and welcome to FixYa, I am Kelly.
Open the freezer and locate the door / light switch. Depress the light switch plunger / actuator and make sure the light goes off and the evaporator fan comes ON. Light stays on and fan does not run = bad door switch.
Next look for signs of ice build up on the back access panel / evaporator coils. Ice block noted on coils and back access panel = evaporator fan problem or possible door switch problem.
Last open the fiberboard cover on the back of the unit and check for massive amounts of lint on the condenser coils and that the condenser fan is running. Blocked condenser coils or condenser fan not running will cause the chassis to be very warm to hot when touched.
If you do not find anything wrong by performing the steps above:
  • Unplug the unit
  • Remove freezer contents
  • Direct an external fan into the freezer compartment for just over 2 hours (manual defrost)
  • Tend to the water mess as needed
  • After 2 hours wipe up any residual water and return the unit to normal service
  • Check to see that the evaporator fan is running.
After a 2- 4 days look again for any signs of ice build up on the evaporator coils. If you note ice beginning to build up on the evaporator coils there is a problem with the automatic defrost circuit.
Possible automatic defrost failure causes:
1. Defrost Control
2. Defrost heater
3. Thermistor (if so equipped)
4. Defrost thermostat
That is pretty much it runs all the time but does not cool troubleshooting. You should find something out of the ordinary by following the steps above.
Kelly
Mar 04, 2011 | Hoover Refrigerators
I am a different person with the same problem the compressor kicks on ,the light is on but it doesnt get cold it does seem like the fan at the top isnt working the one in the middle is thank you
The compressor is running, that is a good sign. If you notice any cooling that is not a good sign. Even with the fan not running , the evaporator should have produce some cooling. Could it be that you are a condenser fan running? well, the compressor makes a distinct sound when it runs and you need to confirm that is running and not just the condenser fan.
Firstly- If you confirm that the condenser fan is running; that is, if there is one, that is good. Secondly- Check and confirm that the compressor is running Thirdly- If there is an evaporator fan inside the unit, check and confirm that is running.
If all checks okay and there is no cooling, the refrigerant might have escaped through a leak, and there will not be any cooling. You can extrapolate from my troubleshooting steps to diagnose the wine cooler problem.
Good luck
Appliancewiz
Jacques
Dec 27, 2010 | Danby DWC257BL Wine Cooler
Refrigerator is not cooling
Dirty condenser, condenser fan or evaporator fan motor are not running, Ice build up on evaporator and restricted the air flow. If compressor, condenser fan and evaporator fan motor are running but not cooling, then either compressor or sealed system problem.
Mar 07, 2010 | Refrigerators
Freezer is not cold and evaporator fan (inside
ok well... those pipes coming from your compressor one of them should be hot. if not your compressor is not running.
Nov 10, 2009 | Amana Freezers
Vending machine issues
Only the fan at the compressor turns on and off with the compressor cycle. The evaporator fan runs steady to maintain air circulation and temperature balance and to affect evaporator defrost in the off cycle. Sometimes the condenser fan will run continuously to assist in the evaporation of condensed moisture from the evaporator drainage.
May 30, 2008 | Koolatron (785169015699)
Electrolux E42BS75EPS 26 CuFt Built-In Side by Side Refrigerator Logo
69 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
