Question about GE Washing Machines
Wprb92200 repair manual
Replace tub seal
3 Suggested Answers
  • 262 Answers
SOURCE: tub seal repair
If you are talking about the front door boot seal it is not a fun thing to do but to replace the boot you have to remove the front cover by using a putty knife on each side once you have removed the pretty cover you need to remove the front door and the door boot from the door then the front panel 5/16" screws usually the cover usually wont come off all the way so you have to work around it it will come off but you have to finagle around under the top cover to get the screws.once you doo all this you have to pull the old boot from the tub. now going back with it is the fun part the boot locks on to the tub with a locking lip and if it dont lock it will come off while putting spring back on.Once you have the boot locked with the lips you have to put the wire spring into a groove and then put on the spring you you are able to get this far you are doing fine.after putting spring on pull alittle on the boot to make sure it is secure.If it is put front panel back on ,secure boot on the lip to the door and put on pretty cover then leak check.BUT GET READY TO SAY SOME UN GODLY WORD THIS IS NOT A EASY TASK AND IF YOU HAVE NEVER DONE THIS BEFORE PLAN ON A DARN NEAR WHOLE DAY JOB GOOD LUCK and let me know how it goes
Posted on Jan 08, 2009
dmftrucker
  • 1922 Answers
SOURCE: how to replace tub seal on Maytag sav4655eww
you need a 1/4" nut driver and a spanner wrench-start by taking 1/4" screw located toward lower part of agitator,its recessed,take it out,then lift out agitator, then mark where your drum is so you get replaced in that location(counter-weights)then take spanner wrench and loosen nut that holds the wash tub and lift out tub,turn tub over and w/rubber mallet driveout old seal,to aid in new seal install lightly lube with vegetable oil(wessonoil-pam cooking spray) and tap seal into place and re-install in reverse order
Posted on Jul 26, 2009
On a stacked 417 Kenmore,what is the best way to get to the seal-tub
Here is a service manual for the stacked set. The model may be a little different but the repairs will be the same.
Oct 22, 2012 | Kenmore 98702 Stacked Washer/Dryer
My plastic drum seal on my Whirlpool duet front-loading washer is chipping apart. The drum doesn't run true, is wobbly and has a rhythmic rub when turning. How do I replace the drum seal? Model GHW9100LW.
You have more serious problem than just your drum seal. The support arms in the wash tub are broken. The wash tub should always spin true. When it wobbles it is a sure sign that the suport arms or spider arms are broken. It is an expensive repair since the wash drum, the outer plastic tub and the door seal need to be replaced. Check your warranty, to see if some of these repairs can be covered. Get a few estimates before deciding whether to repair or replace it. Sorry.
Feb 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hi, My Frigidaire Clothes Washer, Model FES445RF, which has developed a leak around the shaft seal where it enters the outer tub. Is it possible to repair and can I get to it by removing the outer tub from...
Hi, what you are experiencing is problem with the Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
You can get the parts by contacting appliance help on 1-800-470-7119
Oct 06, 2010 | Kitchen Ranges
Kenmore washer leaking water out bottom in rinse or spin cycle.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details. All the time If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate. Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician. Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it. Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Jan 24, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
I have a frigidaire affiniy front load washer. After I washed a lightweight blanket i heard a laoud noise from the machine and water was below the drum not behind from the hose. The next time I used it...
check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further detail
Sep 18, 2009 | Washing Machines
My estate washer is leaking water when we turn it on. It is not holding any water in the tank. Any suggestions what I should look for and fix myself. Thank you
If the washer leaks when you turn on check these:
* Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
* Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
* Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
* Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Sep 02, 2009 | Whirlpool Washing Machines
Water spills all over the floor
Replacing Parts Second, Replace Leaky Internal Hoses
If the supply hoses aren’t leaking, open the cabinet and inspect the internal components. Belt-drive machines typically have a rear access panel that unscrews. Access direct-drive machines by removing the two screws on the outside of the control panel and flipping up the lid. Then pry up the cabinet clips and pull off the entire cabinet. With the cabinet open, restart the fill cycle to check for internal leaks. Look for additional clues like rust and calcium deposits. Most often you’ll find the leaks in the spots we show inFigure A.
Hoses tend to leak around a worn-out spring clamp. First try to remove the spring clamp with an adjustable pliers. If you can’t get it, you’ll need a special $15 hose clamp pliers available from your local parts supplier. Replace the old spring clamp with a new worm-drive clamp. If the hose itself is cracked and leaking, remove it and take it to the appliance parts supplier for a replacement.
CAUTION: Unplug the machine before performing any repairs.
Buying Parts
Washing machine parts are available at appliance parts distributors. (Look in the Yellow Pages under “Appliance Parts.”) Try to find a parts supplier with a well-informed staff, ideally ex–repair technicians, who can provide diagrams and help diagnose any problems specific to your brand of machine. A great Internet source is www.searspartsdirect.com. Enter your model number to access exploded-view diagrams and a thorough parts list for easy on-line ordering.
You’ll need the brand and model number for proper part identification. Model numbers are usually stamped on a small metal plate located under the tub lid or on the side or back of the machine. Copy down all the plate information and take it along to the parts distributor.
Third, Replace a Leaky Pump
Fourth, Replace Worn-Out Tub Fittings
The most challenging repair is fixing a leaking tub fitting, whether it’s the air dome seal ($5), the center post gasket ($8) or the tub seals ($15 to $20). Before proceeding, make sure that telltale drips are coming from around the tub. The details of this repair vary by brand and model. The details we show are for most Whirlpool and Kenmore belt drives. Study a schematic drawing or consult a parts specialist if your machine is different from what we show.
You’ll need a special $15 spanner wrench to remove the tub and replace the tub fittings on this type of machine. It’s available at your local appliance parts supplier. You can open the top of many machines by releasing the spring catches. However, on others you have to unscrew several screws and lift off the entire cabinet. Look in your owner’s manual or at a parts diagram. (See the manufacturer’s Web site or one of the sites listed in “Buying Parts.”) You’ll have to unscrew the water inlet and the tub snubber before unclipping the ring. Fastening systems for these vary by brand, as do attachment methods for the agitator and inner tub.
There are four tub seals that secure the outer tub to the cabinet, each consisting of a bolt with a rubber and metal washer. Rust often develops around one of the tub seals, causing a tub leak. A new tub seal kit will come with four new bolts and oversized rubber and metal washers that will seal small leaks. But if the tub is completely rusted through around the bolt, it’s time to buy a new washing machine. Replace all four tub seals.
If the leaking occurs only when the machine is agitating, a bad center post gasket (“doughnut”) is the culprit. Remove the outer tub to replace the center post gasket. While you’re at it, replace the air dome seal as well. Reassemble the washing machine and run a test cycle.
Jul 14, 2009 | Whirlpool Washing Machines
Kenmore Washer Water Leak
Pump is not repairable and yes your pump is shot. You can replace it farely easily and cheap at repairclinic.com
May 22, 2009 | Washing Machines
Small amt of water drips into tub after washer stops fisher payke
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
  • thanks and please do not forget to accept the solution
Apr 03, 2009 | Fisher Washing Machines
Washing Machines Logo
20 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
