Question about InFocus IN26 Multimedia Projector
Infocus IN26 Projector
Runs fine at sea level but when running at an elevation of 8300 ft it powers down with what appears to be overheating. Specs say should run OK up to 10,000 ft. Not getting much help from the infocus tech group
  • 4,889 Answers
Yes the problem is due to over heating.It would be perfectly acceptable to have inlet air to the projector that ranges between 70 ? 76 Farenheit. Most projectors are designed to operate with inlet temperatures well above this value, usually up to about 90F.Set your air-conditioner to the value specified and it should work fine..
Posted on Oct 09, 2007
My Infocus IN26 has less than 900hrs consumption but the resolution is almost blurred.
Is the lens kept clean and the optical engine cleaned regularly. Is it used in a smoky atmosphere?
Mar 02, 2011 | InFocus IN26 Multimedia Projector
How do I replace the ballast in an InFocus IN26? And while we're at it, where do I get one? I've already replaced the bulb with a new one (direct from InFocus), reset everything to factory settings, and...
remove the front and rear bezels, remove the top cover, take a picture of the location of screws and ground wire on the metal frame. remove the top boards, remove the metal frame and there is the ballast/power supply. pay attention to the way the cable is routed to the lamp connection, also pay attention to which way the connection from the ballast is seated in the lamp housing. hopefully a new ballast will fix it for you, as to where to get one, that's iffy. you could try to find an in26 on ebay that has other problems but has a working ballast
May 11, 2010 | InFocus IN26 Multimedia Projector
Power in cable, but projector is dead - no light, no fan.
bad power supply. you can get the part from an infocus service center, or send it to them to repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Jan 08, 2010 | InFocus IN26 Multimedia Projector
After lightning storm, all lights flash, and projector doesn't come on
you fried the main board and/or power supply. you'll have to send it in for repair.
Oct 21, 2009 | InFocus IN26 Multimedia Projector
InFocus IN26 overheating
clean it out. use canned air and blow the dust out of it. sometimes after many overheating issues, the temperature sensor needs to be replaced. but first clean it out and make sure the fans work well. if they spin slowly, replace them.
Oct 03, 2009 | InFocus IN26 Multimedia Projector
InFocus LP130 Projector has intermittent power off
go into the menu to find out the lamp hours. it could be the lamp, but if the projector shuts down and not just the lamp, there is either an overheating issue, or a power supply issue.
Mar 07, 2009 | InFocus LP130 Replacement Projector Lamp -...
Infocus in26 fan runs continually
The fan does run continuously on this projector however it should be running very very slow when the projector has completed it's lamp cool down routine.
The reason for this is that a portion of the switching power supply remains energized (running) when the projector is at rest. But as I mentioned it should run very slow in this state. If it remains running full blast then most likely the fan speed control chip is shorted which can cause fail 2 ways, either the fan 1. runs full
speed or 2. remains stalled (then the projector will go over-temp and shut itself down) I hope this answers you question.
Cheers
Dec 18, 2008 | InFocus IN26 Multimedia Projector
LP 640 projector not able to display 1080p
The specs of the LP640 show that the maximum resolution it can handle is 720p. You are trying to make the projector do something it cannot handle
Oct 02, 2007 | InFocus LP640 Projector Multimedia...
Projector switches off after 30 mins
i found out that the, in26 that i have was one of many that was shiped with out thermal tape on the bulb. there tech department asures me that this is the prob and are send me out instruction and material to fix it.
Aug 17, 2007 | InFocus IN26 Multimedia Projector
InFocus IN26 Multimedia Projector Logo
127 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Jaime Hernandez
Marvin
Marvin
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
