Question about Schwinn 450 Elliptical Trainer
Remove shroud to check functions
Brand-new 450, the resistance adjustment doesn't WORK. Can't find instructions anywhere to remove the shroud so that I can at least LOOK at stuff... looks like you need a metric bolt-like puller to get the inner shroud out??? I can't find an in-depth manual anywhere that shows how to do this!!!
2 Suggested Answers
mendi593
  • 65 Answers
SOURCE: schwinn 450 elliptical not registering pedal movement
You will need to take the front stabalizer off before opening the machine.
http://www.treadmilldoctor.com/?utm_source=fixya&utm_medium=CPC&utm_campaign=Mendi
Posted on Jul 17, 2012
Radiator removal instructions
Remove the fan and shroud. Put a large (!) drain pan under the radiator and drain it - if you're lucky it'll have a drain petcock near the lower radiator hose. Unscrew the radiator hose clamps and disconnect the upper & lower radiator hoses. Disconnect the transmission cooler lines if they also go into the radiator (some do, some don't)... you'll want a second, small, drain pan to catch the transmission fluid.
Now unbolt the clamps that hold the radiator to the radiator support plate (across the front of the car). Lift the radiator straight up, being sure not to lose the rubber mount isolator pads. Remove it from the car.
Replacement is pretty much the reverse of disassembly - put the new radiator in place CAREFULLY so you don't damage it, put the mounting clamps back on, reconnect the transmission cooler lines and radiator hoses, check the petcock (if the new radiator has one) to be sure it's closed snugly, reattach the fan and shroud.
Now refill the cooling sytem with all NEW antifreeze/coolant and water mix, about 50/50. DO NOT reuse the old antifreeze. Take close note of exactly what brand and type of antifreeze you used, and never NEVER mix any other brand/type of antifreeze with it, only exactly the same brand/type.
After refilling the cooling system, start the car & check the transmission fluid. Top off if necessary.
Jul 26, 2014 | 1984 Buick LeSabre
How replace the multifunction switch
NOTE: Wiring for the multi-function switch is routed under the PRNDL cable.
REMOVAL
  1. Disconnect battery ground cable.
  2. Remove the steering column shroud.
  3. Remove two screws attaching the multi-function switch to the steering column casting. Disengage multi-function switch from casting.
  4. Disconnect the two electrical connections. Do not damage locking tabs.
INSTALLATION
  1. Install the two electrical connectors to full engagement.
  2. Align the multi-function switch mounting holes with the holes in the steering column casting.
  3. Install two self-tapping screws making sure to start the screws in the previously tapped holes. Tighten to 2-3 Nm (18-27 inch lbs.).
  4. For automatic transmission, verify that the PRNDL adjustment is correct.
  5. Install the steering column shroud.
  6. Connect the battery ground cable.
  7. Check the steering column for proper operation.
Oct 27, 2010 | 1997 Ford Aerostar Extended
The pedals have no resistance and drop to the floor...what do I do?
Possible low battery or RPM sensor out of alignment
Shroud removal 1. Remove the 4 screws on the inside front of the shroud and lift the shroud off the frame. 2. Remove the Shroud by unscrewing the 6 screws on each side of the shrouds. 3. Be careful not to pull on any of the cables as you remove the shroud.
Low Battery: Locate battery use multi meter to check for full of 6v DC if under 5.9v DC and does not charge then replace battery.
The RPM sensor and alternator adjustments are accessible from the right side. The gap on the RPM sensor should be approx. 1 credit card. If this does not correct the problem then the sensor will need to be replaced
May 21, 2010 | Startrac Fitness Products Sc4130 Star Trac...
The resistance on my Precor elliptical 5.17 will not increase. All other functions on the machine work. Any ideas?
open shroud and find the circuit board unplug and plug back in all connection this may sometime clean any oxidation off the connector. this is what I've in their 546's should work on the 5.17
Feb 28, 2010 | Precor EFX 546i Elliptical Version 4
How do i replace the ignition switch in my 94 couger
Removal & Installation
  1. Disconnect the negative battery cable. Remove the upper steering column shroud by removing the self-tapping screws.
  2. Unfasten the four bolts retaining the lower steering column shroud, then remove the shroud.
  3. Remove the lock screw, and detach the ignition switch electrical connector.
  4. Rotate the ignition switch lock cylinder to the RUN position.
  5. Remove the two screws retaining the ignition switch, and disengage the ignition switch from the actuator.
To install:
NOTE A new replacement switch will be set in the RUN position as received.
  1. Adjust the ignition switch by sliding the carrier to the ignition switch run position.
  2. Check to make sure the ignition switch lock cylinder is in the RUN position. The RUN position is achieved by rotating the ignition switch lock approximately 90 degrees from the LOCK position.
  3. Install the ignition switch assembly into the column actuator hole. It may be necessary to move the ignition switch slightly back and forth to align the ignition switch mounting holes with the lock cylinder housing threaded holes.
  4. Install the retaining screws and tighten to 53–71 inch lbs. (6–8 Nm).
  5. Attach the electrical connector to the ignition switch. Tighten the lock screw to 7–11.5 inch lbs. (0.8–1.3 Nm).
  6. Connect the negative battery cable. Check the ignition switch for proper function, including the START and ACC positions. Also, make sure the column is in the LOCK position.
  7. Install the upper and lower steering column steering shrouds.
Feb 10, 2010 | 1994 Mercury Cougar
I need instructions for replacing the turn signal multi-switch on my 1999 Dodge Dakota SLT.
  1. Remove the negative battery cable.
  2. If you have tilt remove the tilt lever.
  3. Remove the upper and lower shroud.
  4. Remove the lower fixed column shroud.
  5. Move the upper shroud enough to access the back of the multi-function switch.
  6. Remove the tamper proof Torx screws (Snap on TTXR20B2 bit or equivalent).
  7. Gently pull the switch away from the column to access the screw holding the instrument panel wire harness connector to the switch.
  8. Disconnect the connector and reverse to install new switch.
Jan 15, 2010 | 1999 Dodge Dakota
I need instructions on how to put a locksmart switch ingnition
Removal
  1. Disconnect battery ground cable. Remove the steering column shroud by removing the four or five self-tapping screws. Remove tilt lever (if so equipped).
  1. Remove instrument panel lower steering column cover.
  1. Disconnect the ignition switch electrical connector.
  1. Rotate ignition key lock cylinder to the RUN position.
  1. Remove the two screws retaining ignition switch.
  1. Disengage the ignition switch from the actuator.
Installation
  1. Adjust the ignition switch by sliding the carrier to the switch RUN position. NOTE: A new replacement switch assembly will be set in the RUN position as received.
  1. Check to ensure that the ignition key lock cylinder is in the RUN position. The RUN position is achieved by rotating the key lock cylinder approximately 90 degrees from the LOCK position.
  1. Install the ignition switch into the actuator. It may be necessary to move the switch slightly back and forth to align the switch mounting holes with the column lock housing threaded holes.
  1. Install retaining screws. Tighten to 5.6-7.9 Nm (50-69 lb-in).
  1. Connect electrical connector to ignition switch.
  1. Connect battery ground cable. Check ignition switch for proper function, including START and ACC positions. Also, make certain that the column is locked in the LOCK position.
  1. Install instrument panel lower steering column cover.
  1. Install the steering column trim shrouds and tilt lever (if so equipped).
Feb 26, 2009 | 1991 Lincoln Town Car
Ignition Switch 89 Ford Lariat Truck
Comment by 54harley, posted on Nov 13, 2008 Jeff;
First of all before anything else, disconnect the ground battery cable. Remove column shroud by loosening the screw on the underside, selecting position "1" for automatics and manual 3 speeds, then spreading shroud open and withdrawing out of instrument panel opening by pulling up and away from the column.
If the ignition switch is out of adjustment, that will keep it from working properly. It operates by a rod through the lock actuator rack and pinion which is driven by the key cylinder. To readjust the switch, first disconnect the ignition switch connector by carefully spreading apart the locking fingers and pulling the plug apart. Now rotate the key back and forth until you can insert a 5/64 drill bit, or something equivalent, through the locking pin hole as far as possible. The locking pin hole is located on the right of the switch next to the steering column tube. Next loosen the two ignition switch mounting nuts, turn the ignition to LOCK (feel for detent), and remove the key. Now move the switch up and down along the column to locate the mid-point of the rod lash and then re-tighten the mounting nuts, making sure to tighten top nut first to minimize any rod binding. Now remove the drill bit and reconnect the electrical connector.
If you need to replace the switch, first remove the column support bracket and lower the column. Disconnect the plug, remove the two nuts, lift the switch up vertically to disengage the actuator rod from the switch, and remove.
When you install the new switch, both the lock cylinder and the ignition switch must be in the LOCK position for correct adjustment. Turn the lock cylinder to LOCK and remove the key. The new switch will already be pinned in the Lock position with a metal shipping pin. Now install the new switch by first engaging the actuator rod to the switch, and then positioning the switch on the column and installing the nuts, but only finger tight! Move the switch up and down along the column, and when you locate the mid-point of rod lash, tighten the nuts, top nut first. Remove the lock pin, reconnect the battery ground cable, and check to see that it starts properly in Park and Neutral, and will not start in Drive or Reverse. Raise the steering column back up into position, and put bracket back on. Reinstall the shroud by spreading it around the column and through the instrument panel opening, making sure that the pin on the shroud is aligned with the upper hole on the column before installing the shroud screw.
I hope this works for you. Although I've done this before, these instructions are from the Ford Truck Shop Manual, and a Haynes Repair Manual. Good Luck!!!
Nov 12, 2008 | 1989 Ford F 150
Schwinn 450 Elliptical Trainer Logo
44 people viewed this question
Top Schwinn Exercise & Fitness Experts
Steve
David Payne
David Payne
Matt Olenzek
Matt Olenzek
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
