Left speaker out on Kyocera A710
Have Koycera A710 w/ B&W 802 speakers. Original owner. Left speaker crackled and popped for a while and is now completely out - with any component. Right speaker perfect. What might cause this? Could I repair myself? If not, where is a good place to repair either in Charleston, SC or Savannah, GA? Or ship to? Many Thx.
  • 24 Answers
SOURCE: NAD 3020a crackle in right channel regardless of volume.
more than likely you have a bad transisitor on that side and the frequincey is distorted there's not much you can do except take it back if it's new or take it apart and check for the bad part but if you do that you had better know what your doing!! it may be just 12 volts but thru an amp it's a nasty shock
Posted on Jul 26, 2009
hardrocko
  • 1476 Answers
SOURCE: Crackling sound from right speaker only
I'm not familiar with that model but I am familiar with the problem. If your unit has a volume knob or a balance control which is a potentiometer you need to clean them. Go to www.mcmelectronics.com where you can find spray cleaner. I like to use blue shower as it works well and will not hurt any components. When you get the cleaner unplug your unit and locate the volume control and any others which have a rotating knob. Usually near the top is a small hole which you can spray the cleaner in. Rotate the control and follow through several times. Try the unit and it should be ok. If it isn't you will have to replace the controls as the resistance material has worn off and they cannot be repaired. Let me know how you make out or if you need anymore help.
hardrocko
Thanks for using FixYa
Posted on Feb 18, 2010
  • 17 Answers
SOURCE: crackling sound from speakers
Most probably, your volume control potentiometer is dirty or worn out.
Posted on May 19, 2010
SOURCE: I have 4 speaker wires,
4 speaker wires, black, green, red, white ;speaker left +speaker right +speaker left -speaker right. First see what pair of speaker wires go to left the channel of the amplifier. One of each speaker must be connected to each amplifierĀ“s channel, no matter of colors of the wires. Two wires for each speaker to each channel of the amplifier (rear panel + and -). Then you will have 4 wires connected to 2 stereo channels of your amplifier. Two wires for each speaker.
Posted on Sep 18, 2010
marcandreauc
SOURCE: Behringer EP2500 amplifier channel crackling noise
Got asilimar problemwit a behringer europower pmh 3000.
my
The Right channel began to crack up and drizzle now it seems completely dead.
Changed the cables both of input and seapkers , still the problem stays the same. Any suggestion before brigning for a month at the repair shop? And get out with a 200-400$ bill ?
Posted on Jul 22, 2012
Left speaker not working, system crackles if left side is active, alright when left side shut down.
Get a meter and check the resistance on the speaker. Looks like a speaker may be blown but with the description of the crackle noise from the slide controls you might have a bad pot in the unit or the pot has come loose from the board. This could explain why the speaker blew out
Jul 30, 2015 | Behringer Europort EPA150 Ultra-Compact...
I have a powered sub for my surround sound and every now and then its starts crackling and popping. i can make it stop by playing with the volume knob or even tapping it sometimes. my old sub did the same...
Does the crackling and popping sound comes only from the sub, or from the other speakers too? Try switching of to check. I think that it is problem on volume control potentiometer. In that case all the speakers must sound crackling and popping. If the problem is only in the sub you have to check its connections.
Stelios.
Feb 20, 2010 | Audio Players & Recorders
I have a CineMate GS series II system. All of a
the remote is programed to the come cast box but it wont turn it on or off im so frustrated some one help me plzzz
Jan 02, 2010 | Bose Cinemate Digital Home Theater System...
I have a crackling speaker on the left port of the bass box
The crackling sound on the left port of the bass box, indicates vibrating foreign matters inside it. Just open the box and clear it up. Put the sounds on. Listen if the crackling sound is audible. If the result is ok, then, close the box, and everything is alright..
However, if the result is otherwise, then, it is due to a defective speaker that needs to be replaced.
Nov 21, 2009 | Creative Labs Sound Blaster Live! 5.1...
Dell studio 1737 speakers crackle and pop.
My best guess is, if they crackle with the speakers but not the headfones,  then replace the speakers. Must be a lose wire or something of that nature.
Jul 27, 2009 | Dell Studio 1737 Laptop
I sometimes lose sound from my left speaker and it crackles.
this is a speaker input pin problem, like pin is dameg or input pin is not atech proparly in computer problem is still present remove the cable and install new one cable in speaker
Mar 11, 2009 | Audio Players & Recorders
Soundsticks have developed a loud intermittent annoying crackle
YOUR ONLY OPTION IS TO TAKE IT APART AND CHECK SPEAKER MEMBRANE I SUSPECT THIS HAS PARTIALY BECOME UNATACHED FROM THE SPEAKER IF THAT IS THE CASE IT WILL NEED TO BE REPLACED
Dec 28, 2008 | Harman Kardon SoundSticks Computer...
43 people viewed this question
 Grubhead
Grubhead
